2016 Toyota Tundra's rough ride
Discussion in 'Suspension' started by Almay, Jun 21, 2016.
  1. Jun 22, 2016 at 7:58 AM
    Almay
    Almay [OP] New Member
    Allen
    2016 White Tundra
    Can you tell me where, what area? I just looked and only say one for a 4 runner. Thanks.
  2. Jun 22, 2016 at 9:19 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You'll find the rear shocks very easy to install. The front coilovers are a little more difficult and more than likely will require an alignment after install.
  3. Jun 22, 2016 at 9:21 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Pro suspension is on "Tundra Crew" classifieds Face book.
  4. Jun 22, 2016 at 10:11 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Is it bed bounce? Is it all the time or on certain roads or highways? If you're planning on upgrading to the Pro suspension, I would go test drive a new Pro first. A free test to see if it makes any difference before pouring more money into it which may or may not fix the problem. Also try putting a couple of hundred pounds of stuff in the bed and see if it makes any difference. And definitely try airing down a little bit.
  5. Jun 22, 2016 at 2:09 PM
    TheBeast The Beach
  6. Jun 22, 2016 at 3:24 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Hey Allen, here's the instructions for the TRD Pro suspension kit.
    IMO the front coil-overs are not a driveway job. But at least you can read and decide for yourself.
    The install steps for the front would (in general) apply to any brand pre-assembled coil-over, i.e. with the spring installed and compressed.
    Same for the rear, but these are shock absorbers, not coil-overs.
    Best Regards,
    Almay[OP] likes this.
  7. Jun 22, 2016 at 6:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Another advantage to the pro suspension as a complete package is the toyota engineering that went into the design tuning everything for optimal performance on this specific truck. For a lot of motor heads and wrench turners it's a bummer it's not easily tinkered with. Yes I believe that you can do this yourself. Toyota has issued some 'how to ' videos on installing all of the various Pro specific components on non pro trucks.
    Almay[QUOTED][OP] likes this.
  8. Jun 23, 2016 at 5:01 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    KING 2.5" coil overs and 2.5" smooth body's in the rear.
  9. Sep 21, 2020 at 8:49 PM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    What did you end up going with? My honest opinion about the Bilstein TRD Pro suspensions that came on my 2016, is that they are the absolute roughest suspension I’ve driven on. Hitting city pot holes shake up the entire truck violently and I only have 33k miles on my truck. I get pretty jealous when my girlfriends 2013 Hyundai Elantra goes through the pot holes as if it were riding on clouds. I just expected a lot more I guess. I need to test a 2019 TRD Pro to see if the Fox suspensions have better dampening abilities than the Bilstein
