2016 oil leak…technician states it’s just “sweating” oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Adventundra, Apr 2, 2024.
  1. Apr 2, 2024 at 8:27 AM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
  2. Apr 2, 2024 at 8:37 AM
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    Started a second thread for this? Classic cam tower leak, man. "Sweating oil" is the dumbest thing the tech could have told you, they just don't wanna do the work.
  3. Apr 2, 2024 at 8:42 AM
    JohnWhicker
    JohnWhicker New Member
    I posted same thing on the other thread:
    Sweat and leaks are merely semantics now. If your issue is covered and they're resisting, seek out a dealership willing to advocate for you. Often, resistance comes from the service shop, possibly due to low compensation, and from Toyota itself, concerned about financial losses. It may be a tough negotiation. Consider mentioning your intention to involve a lawyer.
    I encountered a similar situation with my Honda Pilot, where they balked at performing a major engine rebuild covered by warranty, citing semantics. After my lawyer sent them an agreement outlining their accountability if the issue resurfaced post-warranty due to their refusal to address it initially, they promptly agreed to fix it.
    Adventundra[OP] and bulldog93 like this.
  4. Apr 2, 2024 at 9:10 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Sounds like a dealer is trying to talk you out of tying up a master tech on one job when he can probably blow several other things out the door making the same money in that time frame.
    Adventundra[OP] and JohnWhicker like this.
  5. Apr 2, 2024 at 9:17 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya. Thanks! I mean…does this dip stick look like it’s only 1/4 of a quart low??
  6. Apr 2, 2024 at 9:25 AM
    OhioCBtundra
    OhioCBtundra New Member
    ^^^This...def find a second opinion
    Adventundra[OP] likes this.
  7. Apr 2, 2024 at 9:29 AM
    That’s a quart, and a quarter of a quart low at least. You’re below the low mark, generally the low mark will take a quart of oil to fill it back to the high mark. Put in a quart and recheck it.
  8. Apr 2, 2024 at 12:23 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks! He said he added a 1/4 of a quart….when I pick it up I will check where the level is.
  9. Apr 2, 2024 at 12:30 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Sweating just sounds like weird terminology the tech is using. Not literally sweating through the metal.
    It's a leak through the cam tower seals and the oil is "sweating" through those seals. Sweating, seeping, choose your word whatever you want to call it.
    I agree with @ZappBrannigan on your other thread over this same thing. It's a very small amount and highly not noticeable with regular oil changes.
  10. Apr 2, 2024 at 12:39 PM
    2mchfun
    What viscosity oil is in the engine?
  11. Apr 2, 2024 at 5:01 PM
    PJSD
    PJSD New Member
    There's a video on this on Car Care Nut YouTube.... check it out.
  12. Apr 2, 2024 at 5:12 PM
    pursuit2550
    pursuit2550 New Member
    Yup, go get a 2nd, even a 3rd opinion on a that. The amount of oil on that paper looks really bad.
  13. Apr 2, 2024 at 5:24 PM
    Retired...finally
    If a casting is sweating that means it is porous and it's defective. Pack that fact in the dealership's pipe and see if they smoke it.
    That Tech should have been more careful with his wording.
  14. Apr 2, 2024 at 5:38 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If it’s not dripping on the driveway or exhaust I would not have the cam tower leak fixed personally. It is so not a big deal IMO. For one it’s an expensive repair if out of pocket, but it’s also like an invasive surgery on your truck. Mine had it fixed prior to my purchase which caused me problems down the road with an issue caused by the tech who repaired it. Guess what it was seeping oil again anyway less than 20k later. I never have to add oil or have any drips. I switched to 5w30 for other reasons but I believe that also would reduce the leakage. Just drive it and ignore it. Any white puff of smoke at startup is not related anyway. This is also not an area that is under high oil pressure either. It’s a shelf that oil splashes up onto and seeps out, under no more than crankcase pressure.
    B.Ross, Mdl, Txexplorer23 and 7 others like this.
  15. Apr 2, 2024 at 5:44 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Synthetic 0W20
    2mchfun[QUOTED] likes this.
  16. Apr 2, 2024 at 5:47 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I would be totally good with ignoring it…if it doesn’t lead to future problems….but I have an extended warranty n maybe it would cover it…but I also understand some nimnoy could mess up the job and I would have bigger problems…which is my kind of luck. Should I go with a different oil than synthetic 0W20?
    2mchfun likes this.
  17. Apr 2, 2024 at 5:57 PM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    My 2011 has the cam tower leak. I first noticed it about 350,000 miles ago. I’m just shy of 500,000 now and it’s never been a issue.
  18. Apr 2, 2024 at 6:01 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Wow!! Comforting to hear!! Thanks!! And that sounds like one hell of a truck!!
    mlfarm and Tileguy[QUOTED] like this.
  19. Apr 2, 2024 at 6:07 PM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    It is a small business work truck but it is the best one I have had in 44 years of business.
  20. Apr 2, 2024 at 6:09 PM
    Silver17
    Eastern PA
    It could be beneficial to go with a thicker oil from the leak aspect. I also prefer 5w30 for additional reasons but would prefer your thread not devolve into an oil argument thread so I digress!
    B.Ross, Mdl, 2mchfun and 1 other person like this.
  21. Apr 2, 2024 at 8:49 PM
    2mchfun
    A slightly more viscous oil like 5w-30 will be less likely to seep through a very small passage. Even if it does seep, it will be a bit slower. Good luck!
  22. Apr 2, 2024 at 8:56 PM
    2mchfun
    BTW, PCV valve should be replaced about every 40-50k to avoid high pressure in the crankcase which leads to oil seal failures.
    Orions Dad and Adventundra[OP] like this.
  23. Apr 2, 2024 at 10:58 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I learned today I just wasted $5K getting my tower cam leak fixed.:rolleyes:
    And yes it was dripping oil, not just seeping it.
    I guess it was worth $5K not to have oil spots in my driveway and constantly checking my oil every time I parked the truck.....:thumbsup:
    And to @Adventundra ;
    My dealership has been telling me for years my tower cam has been 'seeping' and to keep an eye on it.
    It wasn't until the last maintenance visit that they sent me the video of it dripping that I posted in your other thread...
  24. Apr 3, 2024 at 5:38 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks 1LL! Was just a huge Debbie Downer for a $33k purchase for a truck I tried to find for over a year and truly loved….actually bought it on me and my wife’s anniversary…I’m much less likely to forget our anniversary again!! Lol. I will monitor it closely and keep you all posted!! Thanks to everyone for all the advice!!
    Tileguy likes this.
  25. Apr 3, 2024 at 5:39 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Any special instructions to switch out to 5W 30 at my next oil change? Just drain synthetic out and replace?
  26. Apr 3, 2024 at 6:28 AM
    2mchfun
    Nothing special, drain, replace filter, refill. If it's been over two years, change your PCV valve too. Change the oil every 6k.:thumbsup:
  27. Apr 3, 2024 at 7:03 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Sounds good!! Thank you!!
  28. Apr 8, 2024 at 7:00 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Sweating is the wrong word, you have oil weeping past the seal of the cam tower try adding a bottle of AT 205 with every oil change the product helps to recondition seals
  29. Apr 10, 2024 at 7:28 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    In your case it sounds like it was worth it, but if someone were not comfortable with that being done on something that may not get worse isn't that crazy either
  30. Apr 10, 2024 at 7:39 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I get it.
    I need to get at least 10 more years out of this truck.
    I also didn't want the dripping leak in the back of my mind or oil spots on my driveway..
    By the time it leaked all over my skid plate and cat shields and then to driveway, it would be a mess.
    It's done and fixed now, I can forget about it..
