2016 Lowering Kit: Do they exist???
Discussion in 'Suspension' started by texas2888, Oct 21, 2015.
  1. Oct 21, 2015 at 3:17 PM
    texas2888
    texas2888 [OP] New Member
    Michael
    I'm considering purchasing a 2016 Crewmax and I want to do a 2"/4" drop on it. I'm having trouble finding a kit for the 2016 models. I also emailed a company asking about it and they said that they don't show any kits for this year model. Has anyone seen or heard of a kit for that year model?
    Thanks
  2. Oct 21, 2015 at 3:46 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    It will be the same as a 2014 or 2015. Nothing has changed except adding of a OEM trailer brake controller on the 16's.
  3. Oct 21, 2015 at 3:50 PM
    texas2888
    Michael
    Thank you mdavis. Any suggestions on which one to buy? There sure aren't a lot of them om eBay!
  4. Oct 21, 2015 at 4:14 PM
    mdavis
    Michael
    Rock Hill, SC
    Sorry I don't. I'm not into lowering so have not done any research on them.
  5. Oct 21, 2015 at 4:18 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Honestly there is nothing about the suspension that has changed since the 2007 MY Tundra, so any kit 2007-16 would likely be identical. They probably just havent confirmed/test-fitted on a '16 therefore it's absent from the compatibility chart.
  6. Oct 21, 2015 at 4:30 PM
    texas2888
    Michael
    I had a 2007 as well. This was a 2"/4" drop. I've owned a lot of vehicles in my life and NEVER had more heads turned than with this truck (except maybe my Triumph Thruxton). Man, I miss that thing!!!
    http://www.michaelmarek.net/2007_Toyota_Tundra.htm
    flynbyu2, alalmcgrath and T-Rex266 like this.
  7. Oct 21, 2015 at 8:35 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    That does look good.
  8. Oct 22, 2015 at 3:46 AM
    GQ 66
    GQ 66 (Input clever saying)
    Lake Jackson, TX
    2014 CM Limited
    Tinted Tails, hard wired passport escort, Magnaflow 50 series,
    They are correct on 2007-2016 Tundras having the same suspension.
    When I get mine lowered, I'm going with the 2"/4" kit from McGaughys which is a spindle drop in front and a flip shackle kit in the rear. I was told this is the best kit for still having a smooth ride.
    You might also consider a kit from Tundra Racing - http://sosperformance.com/ This was my first choice, but I had a local shop quote me $850 installed for the McGaughy kit. My installing days are over with... and $100 labor isn't too bad IMO.
  9. Oct 22, 2015 at 7:27 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I installed a lowering kit a while back on a they 2wd dbl cab. Wasn't too bad... handle corners rather well at 60 mph:spy:
    Search Google for kits. They are out there
  10. Feb 8, 2016 at 3:09 AM
    decade
    decade New Member
    BC, Canada
    2011 Blue Tundra SR5 TRD
    - None.... (yet)
    How was the handling after dropped?
  11. Feb 8, 2016 at 7:16 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I lowered a 12. Same kit should work for a 16 no problem
  12. Jul 5, 2017 at 8:52 AM
    Tundra2024
    Tundra2024 New Member
    2017 Sr5 black crewmax
    Did you lower your truck? And what kit did you use?
  13. Jul 5, 2017 at 11:51 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No. I did a customers... not sure what kit. It went from soa to sua tho
