2016 limited crewmax
Discussion in 'New Member Introductions' started by Walleye1875, Jan 10, 2021.
  1. Jan 10, 2021 at 2:51 PM
    Walleye1875
    Walleye1875 [OP] New Member
    16 Limited Crewmax Midnight Black
    I’ve checked out this site a few times but finally decided to register. On my 2nd tundra and currently running a 2016 limited crewmax with 37k miles. Now that she’s paid off I want to do a few mods since I have no desire to trade it in. I have new Toyo AT3 tires on the way and plan on possibly some running board steps, new grill and headlights.. nothing to crazy. Anything else else should consider?
  2. Jan 10, 2021 at 2:53 PM
  3. Jan 10, 2021 at 2:54 PM
    Walleye1875
    I forgot to mention she is bone stock with exception of taking off the trd decals.
  4. Jan 10, 2021 at 2:55 PM
    Other things to consider, color matching, pro headlights
  5. Jan 10, 2021 at 2:58 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Jan 10, 2021 at 2:58 PM
    Walleye1875
    I’ve considered that but not sure how tricky it is to replace door handles.. for some reason this truck came from factory with a stock black bumper so that’s already done.
  7. Jan 10, 2021 at 3:03 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Now that last question is loaded! The only easily visible mods I've done is the tonneau cover and the driver's side grab handle, but I've done about a dozen. They are all functional and help me to enjoy my truck even more. If you stick around here you WILL find more things you want to do!
  8. Jan 10, 2021 at 3:11 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC. Door handles and drivers side grab handle are usually a breeze to change. I've done both on mine with no issues. But stick around this crowd and you'll be changing more and more things. Believe me this site has cost me a lot of money, lol.
  9. Jan 10, 2021 at 4:02 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  10. Jan 10, 2021 at 4:26 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  11. Jan 10, 2021 at 8:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA. I’m amazed you went 37k miles and 4 years and you’re still STOCK! :eek2:
    A little level/lift (some Bilsteins seems to be the most recommended for that at a reasonable price). Steps or rock sliders. DECHROME (unless you like chrome). Debadge. LED headlights. Full overland setup. The sky (and your budget) are really the only limits.
    As for swapping door handles - on the pre-2020’s, that’s an easy mod (and fairly cheap). I’m sure there’s a writeup on it in the DIY section.
  12. Jan 11, 2021 at 3:37 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  13. Jan 11, 2021 at 10:46 AM
    Walleye1875
    I think I am one of the few that think the chrome handles and front bumper look good on my truck. But I do agree I think it would look sharp de badged with possibly black mirror caps and door handles
  14. Jan 11, 2021 at 12:58 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from PEI!
  15. Jan 12, 2021 at 2:44 AM
    Welcome from Ohio
  16. Jan 12, 2021 at 3:43 AM
    Welcome from NY.
  17. Jan 12, 2021 at 4:53 AM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Welcome from NH!
  18. Jan 12, 2021 at 5:32 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  19. Jan 12, 2021 at 6:09 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Those are some nice mod plans. You can fit 275/70-18 tires on your stock truck. They are 33s and fill out things much better than the stock 32 inch tires, but moving to a larger size on a Tundra generally means moving to E load tires, so be aware.
    Lots of good running boards out there in prices from a few hundred to 1000 depending on what you like.
    As far as any other mods, you should look at the TRD rear sway bar- it makes a big difference in drive-ability and handling. It is one of the best additions for the $, less than $225.
    BTW- great truck! I also have a 2016, very similar to yours and love it.
  20. Jan 12, 2021 at 6:14 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Welcome. Another 16er. The most required changes for me was the drivers handle,new running boards, trd sway, led headlights/fogs and flasher module, center console safe, bedliner, bed cover, and maybe a new head unit...and tires. The swaybar made a difference.
    frichco228 likes this.
  21. Jan 12, 2021 at 12:13 PM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  22. Jan 12, 2021 at 1:59 PM
    Walleye1875
    Very nice, it did come from factory with the spray in Bedliner and I added a truxedo cover. I am diggin the rhino foot boards. Think I will be ordering the rb20s. I will look into sway bar for sure. Is it something a shop has to install?
  23. Jan 12, 2021 at 2:38 PM
    frichco228
    Not at all, simple install that you can do in your driveway. I did a review of the TRD swaybar and in my tread posted a great install video I found, just look at my posts.
    Tierhog likes this.
  24. Jan 12, 2021 at 2:39 PM
    frichco228
  25. Jan 12, 2021 at 2:40 PM
    Walleye1875
    Thank you
