2016 Crewmax Amp Connectors
Discussion in 'Audio & Video' started by TundraTex, Sep 18, 2016.
  1. Sep 18, 2016 at 5:30 PM
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I've ordered the components for my next mod - the Audio system. The one thing I am missing is an adapter plug for the 12-pin connector feeding the non-JBL amp.
    This picture indicates J145 in the center of the image and J144 to the right. I believe the Metra 70-1761 will mate with the 10-pin J144 but I can't find a mate for the 12-pin J145.
    MrTuRDPro showed a method of using two 1761 connectors and cutting one of them, but I'd really like to find the mating connector. ********* sells a harness with this connector for $30 but that is an outrageous price considering I'm getting the 1761 for "free" from Crutchfield.
    Who's got the magic part number!?!?!
  2. Sep 19, 2016 at 6:10 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    More Info...
    I think I found the Toyota part numbers for Female J144 (10-pin) and J145 (12-Pin) harness connectors. They are 90980-10801 and -10803 respectively. I may have identified the Toyota Male connector for the -10803 but I will wait for confirmation before I post that number.
    I've got one on order from a local dealership... should be in later this week. This is turning into a quest!
  3. Sep 23, 2016 at 7:36 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Firemedic1428 and joonbug like this.
  4. Jul 22, 2017 at 6:34 PM
    Rob123
    Rob123 New Member
    Hey Tex, Can you tell me where you got / the part number for the 12 pin "Y" cable? I need the same thing so I can bypass my amp without cutting the harness.
    Thanks
  5. Jul 23, 2017 at 5:54 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Rob123. There are a couple ways to get these connectors now. As indicated above, I got the 10-pin connector from a Metra 70-1761 lit - free from crutchfield - and then found the 12-pin y-adapter from a company called Apps2Car on Amazon. Its part number is Y-TYT02.
    Check out my Audio Build thread here for more info on pin connections and wiring in a new amp.
    Enjoy your project!
    Do58 likes this.
  6. Jul 23, 2017 at 7:33 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
  7. Jul 23, 2017 at 7:37 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes, meant to post that source as well. If you don't get a freebie 10-pin (i.e. Crutchfield) then the two connectors from autoharnesshouse is a good deal.
  8. Jul 24, 2017 at 2:07 PM
    birdman076
    Chuck
    Montana
    No worries, just figured as many sources as we can get for items is a good thing. :thumbsup:
    Need a sticky in this section for info like this instead of having to thumb through posts or google.
  9. Aug 3, 2019 at 5:31 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I'm doing this same mod on my 2016 Tundra.
    Is that harness and exact match for the 10 and 12 pin factory amp harness/plugs?
  10. Aug 4, 2019 at 2:32 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes.
    purplenova[QUOTED] likes this.
  11. Aug 8, 2019 at 1:16 PM
    purplenova
    Tom
    Ohio
    Can anyone tell me what gauge wire is used with the 4438 harness ?
    Thanks
    Nevermind I got it.
    The Yellow, Black, and Red wires are 18 AWG. All the other wires are 20 AWG.
  12. Aug 19, 2021 at 10:11 PM
    Revan
    Revan New Member
    2018 Toyota Tundra CM SR5
    none
    These are not an exact match. An exact match means the wires are the same and they plug and play. These you have to determine or dare I say guess on what you want to do. Frankly all this knowledge here and we still have to ask the most basic questions.
    Do58 likes this.
  13. Aug 19, 2021 at 10:13 PM
    Revan
    Revan New Member
    none
    I'll Do As I suspected all along and test each speaker wire until it works in the appropriate location. Beyond annoying. Yea Ill get blasted by so what this entire thread has been little to no help.
    Do58 likes this.
