2015 tundra vibration/grinding in gas pedal
Discussion in '2.5 Gen Tundras (2014-2021)' started by geobltrn, Jan 11, 2022.
  1. Jan 11, 2022 at 8:55 PM
    geobltrn
    geobltrn [OP] New Member
    Jovany
    2015 silver tundra SR5
    2015 tundra SR5, haven’t changed anything since I bought it and drove fine till 2 months ago I feel a vibration/ grinding feeling in gas pedal, when I’m slowing down and let off the gas pedal a little while slowing down I feel it. TIA!!
  2. Jan 11, 2022 at 9:09 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) do you get steering wheel shake?
    2.) do you also feel it while braking?
    3.) when you get on it then let of the gas quick is there a clunk or pop
    so far I'm leaning towards the carrier bearing for the two piece drive shaft to check first. but a lil more info could steer it to a different direction. :)
    geobltrn[OP] likes this.
  3. Jan 12, 2022 at 5:05 PM
    geobltrn
    Jovany
    No steering wheel shake and not while breaking, and there’s no clunk or pop at all I do have MT tires on it which is my first guess at the vibration but I will check the carrier bearing
  4. Jan 14, 2022 at 1:39 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    MT tires will vibrate, some more, some less depending on RPM. If they are a new addition, that may be it.
