2015 Tundra headlight lightbulbs
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnnyMow, Feb 21, 2020.
  1. Feb 21, 2020 at 7:11 AM
    JohnnyMow
    JohnnyMow [OP] New Member
    What are some good bright bulbs to replace the factory dim bulbs?
  2. Feb 21, 2020 at 8:56 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Replace the whole headlight assembly with the factory LED assemblies form the 2018 and newer Tundras. You will be happy.
  3. Feb 21, 2020 at 9:59 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I would go with replacing with the factory LED headlight replacement. I went the other route and wasted money IMO. I have OEM headlights with installed micro-evolution LED’s installed from my 2016 I would part with for cheap. Truthfully, your best bet is to save and get a set of OEM led headlights used here or new and get the ihacker harness and you will drive happily ever after.
  4. Feb 21, 2020 at 10:33 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Get in touch with @Headlight Revolution - They are an Official Vendor on this site. Im sure they can help you.
  5. Feb 22, 2020 at 12:02 PM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Yep @Headlight Revolution, or vleds, or if you just wasn’t the standard bulb, Philips h4 extreme vision 130% for headlight and Philips h11 extreme 100% for fogs. FYI on fogs takes a little time to get in housing unless you dremel the longer clip, which I don’t have. Also add a hidden light bat from rough country and your set. Also don’t forget your in cab adjuster.
    Headlight Revolution likes this.
  6. Feb 24, 2020 at 5:20 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
