2015 Tundra Front Side Marker replacement
Discussion in 'Lighting' started by irishpride114, Jul 12, 2015.
  1. Jul 12, 2015 at 6:06 PM
    irishpride114
    irishpride114 [OP] New Member
    Travis
    2015 SR5 TRD Double Cab
    Has anyone replaced their front side marker with LED's on their 2015 Tundra? Did you go with: 360° firing, straight ahead firing, or flank style firing?
    I am hoping someone has went through this before. My headlights and switchbacks are on backorder, and I really don't want to take apart the grill to get to the headlight assembly to see if I like the flank style I have. My problem is, I don't think they light the whole area of the side marker area. And since I have other LED bulbs to return, I was hoping someone would tell me if I need to stay with flank's or go with 360's or straight firing.
    Thanks.
  2. Dec 4, 2019 at 5:33 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Tundra TRD nonPRO
    Methods, Toyos, Kings, TCs
    Old post, but it's got the right thread title I need so...
    Is there any way to replace these bulbs without removing the entire assembly? I just don't want to pull the dang grille off to replace a tiny bulb.
    Thanks for the help
    (And for the 4 yr old OP question, I previously used a 360 bulb and it worked fine.)
