2015 tundra brake controller harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1G3-TRD, Feb 11, 2015.
  1. Feb 11, 2015 at 10:24 AM
    1G3-TRD
    1G3-TRD [OP] New Member
    Aaron
    2014 double cab TRD off road
    For some reason Toyota decided to change the plug and location so i thought I would share some info for anyone trying to hook up a brake controller to a 2015 tundra.
    Step 1: remove the 10mm. Bolt under dashbelow tpms reset button
    Step 2: pull lower lash pannel out carefully
    Step 3: carefully pull out the pannel with traction control button and tow haul button
    Step 4: the white plug is located behind this pannel. Plug in brake controller and replace dash pannels, and install brake controller and be sure to clear the knee airbag
    Btw it takes a different plug than previous years and they don't come with the trucks anymore
  2. Feb 11, 2015 at 11:10 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Thanks, I'll be adding one to my truck this spring
  3. Feb 11, 2015 at 1:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good write-up! Thanks for the info.
  4. Feb 12, 2015 at 8:25 AM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    If you want the factory controller, these are the part numbers needed: Controller(They call it a relay) 89547-0c010 and the panel it goes into is 55447-0c020-c0 Pretty slick and you dont have to mount it below the panel. It also comes up on your info screen in the middle of the gauge cluster.
    Tundra505, JKTundra01 and George14 like this.
  5. Feb 14, 2015 at 6:17 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Do you have any pics of this installed?
  6. Feb 22, 2015 at 6:32 PM
    havasubud
    Earl
    Corona, California
    Its not available from Toyota yet, bummer. I have a 14 so it wont work on mine anyways. I bought a Prodigy P3 and also bought the 15 dash panel for the controller. I had a trim plate cut out and I mounted the controller in there. It is so much safer than mounting it at the bottom of the dash. What people do not realize is that there is an air bag there for the knees. If you are in an accident and that air bag is deployed, the controller is going to be part of your shins. Here is what I have:
  7. Feb 22, 2015 at 6:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  8. Feb 23, 2015 at 5:18 PM
    mdavis
    Michael
    Rock Hill, SC
    Thanks for the pics. That looks great! Do you have any idea when the OEM one will be available? And what is different between the 14 and 15? Sorry new to Toyota.
  9. Feb 23, 2015 at 7:17 PM
    havasubud
    Earl
    Corona, California
    The 2014 has the plug in the driver side kick panel. The 2015 has a different plug to the right of the steering wheel behind the panel with the trac off button. The 15 also will have the info screen in the center of the dash letting you know the trailer brake info. Should be pretty slick, but not sure when it will be out.
  10. Feb 23, 2015 at 7:48 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    @havasubud
    So I am a new truck owner and have yet to ever haul anything. What is the purpose of this controller, how does it work, what situations warrant this need? Is it above and beyond what the "tow haul" button does?
    Thanks in Advance!
  11. Feb 24, 2015 at 10:25 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    It adjusts/controls the trailer brakes, when set up properly the trailer will slow down at the same rate as your truck. The controller sends the signal to the ttailer to activate the brakes, and how much. Some controllers also have a feature in which you can manually activate the trailer brakes to "cut the slack" and reduce sway.
    Not all trailers have brakes, usually only bigger trailers or trailers meant to haul heavy loads.
  12. Feb 24, 2015 at 11:20 AM
    Relentless
    Eric
    Yes, what MotoTundra said.
    Typically states will have a law that says trailers under 2000lbs or so do not require their own brakes whereas those of higher capacity require their own brakes. This is for the safety of the vehicle and those around you. Brakes on a truck are designed to stop more than just the trucks weight, but not all that much more. If you tow more than 2000lbs you need assistance of brakes on the trailer to stop in a safe distance and time. As they sit, most trucks do not have a factory brake controller, though they have become more commonplace in the last 5 years or so on the HD and now 1/2 ton trucks. The Tundra has been one of the very last to adopt a factory trailer brake control/trailer sway control system. Its about time. Kind of disappointed they didnt introduce it in '14 with the redesign, but would just happen to be my luck they're adding a factory option on the 15's. :rolleyes:
    Edit- controller is for electric brakes, usually rental trailers and boat trailers have a 'surge' brake system that applies brakes as the trailer tries to push the tow vehicle. They do this because not every vehicle has a controller as you can see, and on a boat trailer electric brakes dont like being submerged plus the loaded/unloaded weight of the trailer varies a lot.
    MotoTundra[QUOTED] likes this.
  13. Feb 24, 2015 at 11:53 AM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
  14. Feb 24, 2015 at 11:55 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Same here @Relentless , figures after I buy a 14' they make the change.
    Relentless likes this.
  15. Feb 24, 2015 at 5:34 PM
    mdavis
    Michael
    Rock Hill, SC
    Thanks for the info. I will have to keep my eye out for it. Thanks for providing the part #'s.
  16. Mar 1, 2015 at 2:47 PM
    1G3-TRD
    Aaron
    Personally I think the 14 was easier
    erm626 and MotoTundra like this.
  17. Mar 8, 2015 at 4:22 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
  18. Mar 8, 2015 at 4:33 PM
    havasubud
    Earl
    Corona, California
    dkahs05[QUOTED] likes this.
  19. Mar 8, 2015 at 4:41 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
  20. Mar 8, 2015 at 4:42 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Thanks havasubud
  21. Mar 10, 2015 at 5:47 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Just ordered my integrated brake controller and panel from EB Toyota best price I could find .
  22. Mar 10, 2015 at 9:00 PM
    havasubud
    Earl
    Corona, California
    The factory one? Last I checked it wasn't available.
  23. Mar 10, 2015 at 11:55 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Pretty sure. I use this part number. 89547-0c010
  24. Mar 11, 2015 at 1:21 PM
    havasubud
    Earl
    Corona, California
    That part is going to back order. I just checked again and all of the depots show 0 on hand. I think it will still be a while.
  25. Mar 14, 2015 at 6:04 PM
    sinevirtussinelaus
    sinevirtussinelaus New Member
    Caleb
    New England
    2014 Tundra 5.7L Silver Sky Crewmax Platinum
    LED bed lights, LED interior/exterior lights, console vault safe, line-x, tonneau cover, bed lights, Under-Seat Rear Storage from ESPtruck.com, Stealth 38" LED Hood Bulge Light Bar, Husky X-act Contour Mats, Morimoto LED Fog lights, LED Headlights
    will the integrated brake controller be available for the 14 crewmax? At some point...I know not right now
  26. Mar 15, 2015 at 9:55 AM
    havasubud
    Earl
    Corona, California
    Unfortunately not for the 14. They changed the configuration for the 15 model. I am one of those people that wants things to look as factory as possible.
  27. Mar 15, 2015 at 1:19 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    That's how I am also.
  28. Mar 27, 2015 at 8:21 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Hello, I found a nice panel to use to install a brake controller under the tow/haul switch. I did a write up. It's under the towing section.
  29. Mar 27, 2015 at 3:38 PM
    Sigma_Online
    Sigma_Online New Member
    2015 Tundra 5.7 SR5
    Hey everyone. Just purchased my 2015 Tundra 5 days ago (up from a 2006). I used this thread to really look into this and see how to get the integrated panel/controller. I called the parts department where I bought the truck and ended up talking with the manager. He said that Toyota is NOT going to deliver them. They were told that due to a legal issue, Toyota had to stop release of the integrated controller (he speculated that it was something to do with the integrated display). He said he understood that it was in the owners manual and all the marketing materials... they were just as surprised to hear it. He was told (and carries) to supply the Tekonsha P3 as the "certified" Tundra 2015 brake control as the alternative to the integrated. I called another Toyota shop around town and they said they had heard pretty much the same thing. I went ahead and bought the Tekonsha P3 (not from them...saved like $80) and I just read Tacouser's post on what he did with the panel. I may do that soon, but will do an old school brake controller mount in my brand new truck...little disappointing, but is what it is.
  30. Apr 18, 2015 at 7:47 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Here is my install. It was easy. And took maybe 30 to 40 min. at the most.
