2015 SR5 with 4.6L - with popup camper - enough engine?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MWD, Jul 18, 2019.
  1. Jul 18, 2019 at 5:32 AM
    MWD
    MWD [OP] New Member
    Pagosa Springs, CO
    2017 TRD Off Road Double Cab
    Camper frame mounted tie downs, Firestone air bags, E rated tires
    Double cab with 1200 lb popup PICKUP camper - ~2000# payload with people/gear. Looking at a good deal on a 2015 but it has the 4.6L. Would this be a bad idea for wandering around the Rocky Mountains? Or would the 5.7L be an obviously better choice?
  2. Jul 18, 2019 at 6:19 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Not towing anything? You're fine. If you plan to tow, get the 5.7.
  3. Jul 18, 2019 at 6:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What are you towing the pop up with now
  4. Jul 18, 2019 at 11:26 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I can't imagine a 4.6L DC rated at TWR 6800lb being unable to tow a 1200lb pop-up camper anywhere. Single axle without brakes? @ColoradoTJ
    Black Wolf and ColoradoTJ like this.
  5. Jul 18, 2019 at 11:30 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    This response is ridiculous. The OP was only asking about towing 1200 lbs. You don't need to get 5.7 to tow it. A 4.6L will tow it just fine like anything is hardly there. Everyone wirh a 5.7L says to get a 5.7L no matter what but complain about the fuel mileage or what they can do to improve it.
    jeremyd and AZTundra like this.
  6. Jul 18, 2019 at 11:34 AM
    MWD
    MWD [OP] New Member
    Pagosa Springs, CO
    Oops...popup PICKUP camper - slide in camper, not a trailer. No towing. Probably will be 2000# payload with people, gear, water etc. I plan to add air bags and E load rated tires. My only concern is going over passes here in Colorado.
  7. Jul 18, 2019 at 11:36 AM
    JohnLakeman
    Payload for 2017 4.6L DC is 1435lb. Check the door sticker on the 2015.
    Black Wolf likes this.
  8. Jul 18, 2019 at 11:38 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I used to tow a 1000lb trailer w quads on top (close to 1800 total) Indiana to upper Ontario Canada w a 3.3L 2001 xterra 180hp v6. No mountains but no problem towing. No experience w 4.6 but I would think a pop up would be easy.
    Edit: oh nm, just saw the added posts about being a pickup.....
  9. Jul 18, 2019 at 12:07 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you disagree that’s fine but no need to call it ridiculous then go on a soapbox to lecture the 5.7 owners complaining about mpgs. Get over yourself. Did you see that it’s not a trailer? About 2k loaded down...Hmmm
    Metro14536 and Devcom like this.
  10. Jul 18, 2019 at 12:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Im not sure if i would feel any better about a 1200 lb slide in camper in my 5.7 tow package truck. Thats really dang near max capacity without gear/ food/water
  11. Jul 18, 2019 at 1:09 PM
    LML 3500HD
    Since this is a slide in camper, I would say no. You will be over on payload, regardless of motors or configuration.
    Devcom, MGM2018OR, awq735 and 2 others like this.
  12. Jul 18, 2019 at 5:08 PM
    TundraTSS19
    San Antonio, TX
    So 2k you need a 5.7. Yeah you should get over yourself. Not on a soapbox. Just talking actual sense. You don't need a 5.7 for 2k.
  13. Jul 18, 2019 at 5:22 PM
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Towed this beast from Mississippi up to New York city area and back last September. Truck was a 4.6L (has since been totaled :( )
    Did fine. Had my MR2 in the back with some gear so probably around 6k pounds or so. Wind resistance was the worst thing.
    So pulling a pop up you'll be more than adequate with the 4.6L.
    jeremyd likes this.
  14. Jul 18, 2019 at 5:41 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Look up the payload capacity for it and get over yourself.
    Devcom likes this.
  15. Jul 18, 2019 at 5:43 PM
    TundraTSS19
    San Antonio, TX
    Somebody feelings hurt. It's OK
  16. Jul 18, 2019 at 5:46 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol you wish.
  17. Jul 19, 2019 at 11:40 AM
    JamesTkirk
    JamesTkirk New Member
    Moab UT
    2018 SR 4WD 4.6L
    I've had this 1300lb(loaded) pop-up in my 2017 Tacoma TRD for the last couple years. Tacoma has done fine with it. I beefed up the suspension with some ARB gear.
    I plan to put it in my new-to-me 2018 4.6l Tundra. I have no doubt whatsoever that it will handle it. Maybe a minimal suspension upgrade. But I bet I can get away with nothing if I wanted to...
    -Kirk Out
  18. Jul 19, 2019 at 12:01 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I actually can see both sides of the story here. This reminds me of something I learned a few years back when I had My Ram 1500 Hemi and towed a light weight 2k-3k pound camper for a friend that he was selling and we were bringing it to the buyer. My Ram had the 3.92s axle gears which were the best for towing and the 8 speed with a max tow rating of 10,200 pounds if I recall correctly on the rating. We went through the mountains and we were dealing with a nasty headwind and going up the grades were horrible the truck struggled hard core because the camper was acting as a sail against the truck. Just because a tow rating can be X doesn't mean there won't be situations that it will be a huge struggle fest and you wished you had a different truck. If I end up in a market for a camper I am going to look for one that is 5k-6k loaded for piece of mind just because I don't want a repeat of that. I think the 4.6L should in most cases handle that 1200 pound trailer ok though. If I were using it to tow through the mountains I might also want the 5.7 though. All depends on where you tow it.
