2015 SR5 Crew Max - Magnetic Gray
Discussion in '2.5 Gen Builds (2014-2021)' started by 53flattie, May 20, 2015.
  1. Aug 13, 2015 at 12:30 PM
    53flattie
    53flattie [OP] New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    Well, I decided that I didn't like the looks of the Nfab step bars as much as I thought I would. So I sold them and picked up some Amp Research Powersteps. The installation went very good, thanks to excellent instructions and wiring diagram. They worked perfectly right off the bat, and I didn't have to go back through and chase down any electrical gremlins.
    Some pictures:
    https://vimeo.com/136239463
    geno0506 and NewImprovedRon like this.
  2. Aug 13, 2015 at 1:10 PM
  3. Aug 13, 2015 at 3:26 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very nice and clean on the truck.
  4. Aug 13, 2015 at 3:29 PM
    Definitely very clean' nifty looking. Reminds me of an airplane braking flap. Out when you need it. In when you don't.
  5. Aug 15, 2015 at 5:36 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Oh well, doesn't look like the video is working...
  6. Aug 15, 2015 at 6:06 PM
    I can see it fine via mobile. What browser are you using?
  7. Aug 16, 2015 at 3:52 PM
    Focker79
    Focker79 New Member
    05 4Runner Sr5
    Cut off mud flaps, that's it.
    Does your SR5 have any options? I'm Looking to get the sr5, mabye get the TRd. Looks good!
  8. Aug 19, 2015 at 4:44 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    The only factory options that I ordered were the all-weather floor mats (which I actually ended up replacing with Husky Weatherbeaters). Other than that, the SR5 had all the options I wanted.
  9. Aug 19, 2015 at 9:20 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Man that fold out step looks slick (good)!
    But it does kinda look like it might be a little flimsy? If a 240 lb guy stands on it does it flex?
  10. Aug 19, 2015 at 6:02 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    I haven't had a 240 lb person on them yet, but I'm 165 and they don't flex at all. They are rated for up to 600 lbs each. And the placement of the mounts is well thought out, in that they are right under where you step. I think that helps to stiffen them a lot.
  11. Aug 19, 2015 at 6:08 PM
    I haven't seen 165 lbs on a scale for myself since?????
  12. Aug 19, 2015 at 6:20 PM
    Lol x2. That was about my stage weight in 2011.
  13. Aug 19, 2015 at 6:22 PM
    Lean,mean, and green after USMC boot camp in 1978> 175 lbs. Now, at 59?. Don't give a Rat's A**
  14. Aug 20, 2015 at 5:25 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Lol! I've been blessed with a fast metabolism, and I'm very thankful for that.
  15. Aug 21, 2015 at 7:29 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks to Earl (esptrucks.com), I was able to move my Prodigy P2 brake controller from here:
    To here:
    Thanks again Earl!!
  16. Aug 21, 2015 at 7:46 AM
    Very nifty.
  17. Sep 2, 2015 at 8:12 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    sweeeeeet!!!
  18. Feb 14, 2017 at 7:40 PM
    geno0506
    geno0506 New Member
    Michael
    I agree with the look thing, I bought and installed the same steps but some how keep slipping because not enough step and I considering going with the AMP power steps!
  19. Mar 1, 2017 at 3:11 PM
    #49
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    $349.00
    ICI Magnum RT Steps RTS73TY
    RealTruck.Com
  20. Mar 1, 2017 at 8:08 PM
    #50
    geno0506
    geno0506 New Member
    Michael
    I bought the same steps and think I'll go with the AMP's instead! I keep slipping on the N-Fab's!
  21. Mar 1, 2017 at 8:11 PM
    #51
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Nice rig! I want a roof rack too bit might wait until I get my topper.
