2015 SR5 Brake controller
Discussion in 'Towing & Hauling' started by tacouser, Mar 26, 2015.
  1. Apr 25, 2015 at 1:38 PM
    spepi
    spepi New Member
    Mansfield MA
    2015 Tundra Dbl Cab 5.7
    What I tow 2016 Jayco Eagle HT 29.5 BHDS Fifth Wheel 2010 Keystone Outback 300BH - 32' 8" 8200lbs - TRADED
    So this is how it turned out. I used some black foam in the back, then I used some Gorilla Tape and wrapped it. Plugged it in, and it was done.
  2. May 12, 2015 at 12:21 PM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I just picked up my 2015 CM yesterday and didn't see a brake controller harness like my Tacoma came with (to plug into the factory harness and the other end gets wired to the controller). Has Toyota stopped including these?
  3. May 20, 2015 at 3:38 PM
    LM_Tundra
    LM_Tundra New Member
    Richard
    Southern California
    Tundra 1794
  4. May 21, 2015 at 8:06 AM
    tacouser
    tacouser [OP] New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    The brake controller wiring was right behind the tow/haul panel on my 2015
    NewImprovedRon likes this.
  5. May 21, 2015 at 8:37 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Correct - all of the 3rd generations have it there. But my frustration is that you have to buy an aftermarket wiring harness with a plug that matches your brake controller on one end and the Tundra plug on the other. Without that, you'd have to cut off the factory plug and hardwire the controller.
    LM_Tundra and UPSed like this.
  6. May 27, 2015 at 6:18 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Can you tell me where you got the foam, or what it's original purpose was? My panel arrived yesterday and now I need to secure the brake controller in it.
  7. May 29, 2015 at 5:49 PM
    spepi
    spepi New Member
    Mansfield MA
    I had a box from HP from a laptop repair, and it had this foam in it.
  8. May 31, 2015 at 10:37 AM
    tacouser
    Chicago
    When I did mine I used some 1/2inch weather sealing foam. It's just to fill in the gap around the controller and the plate where you installed it.
  9. May 31, 2015 at 6:34 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks for the info, guys.
  10. Jun 1, 2015 at 9:33 AM
    Schillout
    Schillout New Member
    2015 Sky Silver CM 4x4 Xp package
    De badge, TRD Pro grill with color match, P3 brake control with ESP install kit, Weathertech front and back
    I went with the P3 installation kit from Earl at ESP truck accessories. I think it is the best way to get a stock looking install with the P3 controller. I spoke with Earl personally he was very helpful and product was delivered quickly.image.jpgimage.jpg
    NewImprovedRon, tat2ude39 and UPSed like this.
  11. Jun 1, 2015 at 12:04 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    That looks really nice. I might have to contact him to see if he can accommodate a P2.
  12. Jun 2, 2015 at 5:58 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Do you happen to have Earl's contact number? I don't see one on his website. I sent him an email, but haven't gotten a response.
    Thanks
  13. Jun 2, 2015 at 7:22 PM
    Schillout
    I'll look around when I get home tomorrow. He will probably respond by then anyway.
  14. Jun 3, 2015 at 5:34 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    I did the same thing Schillout did with the panel from ESP. It is the most professional install of all of them for the P3 that I could find. No extra bracing needed. It fits very snug, and ESP provides two screws that go into the P3 bracket holes to hold the controller in place from the back side.
    http://www.esptruck.com/#!
  15. Jun 4, 2015 at 4:56 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    So others don't think Earl was being unresponsive - I got an email from him last evening saying that he had sent a message the previous day. Apparently it didn't come through and was likely a problem with Hotmail.
  16. Jun 4, 2015 at 8:12 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    I never had any issues with him or the company. I received the panel quickly after placing the order online.
  17. Jun 4, 2015 at 9:59 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    The miscommunication was my fault - his first email didn't make it to me.
    Earl and I talked for quite a while this morning. Super guy. I was very impressed. He's working on some things that I think will be VERY well received by the Tundra crowd. I'll let him elaborate if he wishes.
  18. Jun 4, 2015 at 8:52 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Thanks Tim. I posted a different thread on the 2nd version of the underseat storage. As far as other things go, we have had a lot of questions if our panel will work with the prodigy P2. In its current design, it wont. We are going to however make a plate that fits the P2. I am hoping to have that available in 2-3 weeks. Hopefully all goes smooth.
  19. Jun 30, 2015 at 5:55 AM
    #49
    ToyotaTim
    ToyotaTim 2015 5.7L Tundra Crewmax TRD
    Locust Grove Virginia
    2015 Tundra
    Brake controller, custom seat covers
    Read this post a while back, ended up going through etrailer.com to get the correct wiring harness and p3 controller. They were very helpful and fast shipping. Everything works great, compared to what I got from Toyota. They sold me everything wrong, like they had no idea that the wiring harness had changed.
    UPSed likes this.
  20. Jun 30, 2015 at 6:53 AM
    #50
    UPSed
    UPSed New Member
    2015 Crewmax SR5 TRD 4x2
    Where did you mount the controller?
  21. Jul 2, 2015 at 4:32 PM
    #51
    ToyotaTim
    2015 Tundra
    Having a hard time uploading the photo, under the dash just above the pressure reset button. I'm aware of the airbag and all, I was loosing money for everyday I couldn't haul my trailer. So I made the decision to mount there.
    UPSed[QUOTED] likes this.
  22. Jul 2, 2015 at 4:35 PM
    #52
    ToyotaTim
    2015 Tundra
    finally figured it out, the controller is out of the way and the light blends very nicely with the other dash lights.
  23. Jun 2, 2017 at 12:56 PM
    #53
    spepi
    spepi New Member
    Mansfield MA
    I am going to be selling my P3 and panel very soon. Upgrading truck to a 2500HD
