2015 MGM Limited
Discussion in 'Sequoia Builds' started by S. Equoia, Mar 24, 2021.
  1. Apr 30, 2022 at 9:26 AM
    #61
    NFARIDI
    NFARIDI New Member
    So just got around to trying to install this. Did you use the supplied wire harness? (Looks like it has a built-in fuse). I was looking at the oem harness that comes out but it has 2 connectors at 90° from eachother while the Amazon charger has 2 connectors sticking straight out next to each other. Just wondering how you made the actual connection?
    S. Equoia[QUOTED][OP] likes this.
  2. Apr 30, 2022 at 9:44 AM
    #62
    S. Equoia
    S. Equoia [OP] New Member
    Ontario, Canada
    2015 Sequoia
    I just disconnected at the plastic connecters. Bent the ring connectors from the new usb adapter so they fit snug in the plastic connector from the truck. Not a proper install by any means but I didn't want to mess with it too much in case I ended up switching back. Plus, access to the wiring is very easy. I have two in the truck and they have been great so far.
  3. Apr 30, 2022 at 10:07 AM
    #63
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Just make sure its snug and won’t slip out. I taped up each connection individually first and then together with some electrical tape. Don’t short any fuses either!
  4. May 11, 2022 at 10:01 AM
    #64
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    $16.99 cdn on Amazon.ca Was hesitant on the quality and thought about waiting too see what happened with AJT’s petition to toyota but I needed to get up to $35 for free shipping on a different item. Happy with it so far, now to switch the two trim pieces to match.
    donellyd likes this.
  5. Jun 24, 2022 at 8:05 AM
    #65
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Wife just sent this... Dumptruck kicked up some debris! Not sure if I can fix it but hopefully I can come up with something...
  6. Jun 24, 2022 at 8:26 AM
    #66
    farnsrocket
    farnsrocket New Member
    Bastards! Is the piece still on there?
    S. Equoia[OP] likes this.
  7. Jun 24, 2022 at 8:48 AM
    #67
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I haven't been home yet to confirm but she says we have some larger pieces so I'm hoping for the best. A bit of superglue might do the trick.
  8. Jun 28, 2022 at 8:54 AM
    #68
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I think it's time for new pads and rotors. I haven't looked too closely yet but the pads look pretty thin and the rotors seem slightly warped as there is some pulsing when braking. I've looked at a lot of threads and I think I'm leaning towards OEM, stop tech or EBC.
    Anyone run these brakes that can give some feedback?
    StopTech - 934.51053
  9. Jun 28, 2022 at 9:24 AM
    #69
    farnsrocket
  10. Jun 28, 2022 at 11:16 AM
    #70
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    I had those in my cart, saw them recommended a lot. Ultimately backed out due to the drilled rotors. I like the idea of slotted rotors though.
  11. Oct 12, 2024 at 9:56 AM
    #71
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Needed new tires and Costco started carrying KO3's, so made the jump to 295/70r18. Considered 285/75r18 but wimped out. I'm thinking 2 of the 1/4" Dobinsons shims up front is all I need to even it out. So far, no rubbing and power is still there. Other than Costco gouging each of my wheels, I'm happy.
    Hellrazor, The Dude and donellyd like this.
  12. Oct 13, 2024 at 12:42 AM
    #72
    farnsrocket
    Wait, no rubbing the fender liner up front?!?!?! You're not lifted right??? Have you locked out the steering in turns. My 295/70/18's rub with a 2.1" lift up front. :facepalm:
  13. Oct 13, 2024 at 1:12 PM
    #73
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    Could it be because u guys have different offsets? Isn't yours +18 or 20?
  14. Oct 13, 2024 at 8:25 PM
    #74
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Yes, no lift at all. I'm thinking it's mostly the offset and the KO's are a bit skinnier near the outer edge of the tire which I think helps as well.
    I was worried I'd be too close to the uca or the skid plate but I clear and have not noticed any rubbing at all. There's no marking on any of the liner either. I meant to take some pics of the closest point.
    farnsrocket likes this.
  15. Oct 14, 2024 at 12:12 AM
    #75
    farnsrocket
    Yes, +18
