2015 Front turn signal wiring
Discussion in 'Lighting' started by SpeshulED, Aug 20, 2020.
  1. Aug 20, 2020 at 10:01 PM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    So I’ve searched the inter-webs and couldn’t find the answer.
    Does anyone have the wiring diagram for the front left and right turn signals at the socket?
    reason is that I don’t want the bulbs to turn on when I switch the parking lights on. I just want the to come on during turn signal.
    Tundyfundy likes this.
  2. Aug 20, 2020 at 10:14 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You can snip a grey wire under the kick plate on the drivers side. Let me see if I can find some info
    SpeshulED[QUOTED][OP] likes this.
  3. Aug 20, 2020 at 10:17 PM
    Tundyfundy
    Bay Area, CA
  4. Aug 21, 2020 at 11:46 AM
    SpeshulED
  5. Aug 21, 2020 at 12:02 PM
    SpeshulED
    actually here is my situation.
    I have done the DRL mod by cutting the gray wire but anyone here know which wire from the light socket is for parking lights?
    I essentially want my front amber bulb to only come on when I use the turn signal.
    I want to prevent the amber bulb from coming in when I turn my parking lights on.
    Tundyfundy[QUOTED] likes this.
  6. Aug 24, 2020 at 12:08 PM
    AmericoSupply
    AmericoSupply New Member
    Don
    2014 Tundra Crewmax
    The purple wire is the running light and the one in the center is the common ground ( white/black ) the third should be your blinker. Be careful not to ground it and blow the fuse if you do it will be at least the # 20 fuse under the dash and possible two more. I did this unspeakable thing and now I have some strange things going on with my lights.
    Best of luck and keep me posted how it turns out.
  7. Aug 25, 2020 at 12:23 AM
    SpeshulED
    Is it the purple on both sides?
  8. Aug 25, 2020 at 10:26 AM
    AmericoSupply
    Don
    2014 Tundra Crewmax
    Yes, it should be the purple on both side . Check it with a meter by disconnecting the wiring harness from the light bulb that is the easiest access. The purple should give you 12v anytime the running lights should be on.
    SpeshulED[OP] likes this.
  9. Aug 26, 2020 at 9:20 AM
    SpeshulED
    thanks again!
