2015 DRL schematic
Discussion in 'Lighting' started by Shetto24, May 7, 2020.
  1. May 7, 2020 at 9:03 AM
    Shetto24
    Shetto24 [OP] New Member
    I’m wondering if anyone can provide a schematic or wiring diagram for a 2015 DRL/headlight. I’ve got a Limited trim. I’m brainstorming if it’s possible to do a pod DRL while keeping the headlight amber DRL as turn signal. Thanks.
  2. May 7, 2020 at 9:09 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    This video shows how to delete the drl. But it will show you the wire, you would need to tap into for your pod lights.
    https://youtu.be/5Vp4wjDK19I
  3. May 7, 2020 at 9:16 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    You could contact @iHacker and buy one of his PnP wire looms which takes all the thoughts and time probing wires and looking at wire colors and schematics.
    Save time look into it. Good luck.
  4. May 7, 2020 at 9:20 AM
    Shetto24
    Thanks. This procedure (and other posts) I've read and seen describe how to eliminate the amber DRL. To be specific, I'm trying to move the DRL function to an amber pod mounted in the grille assembly, and keep the stock amber signal function while momentarily turning off the amber pod when the signal is activated.
