2015 crewmax need help with tire and wheel pairings
Discussion in 'Wheels & Tires' started by big rig, Jul 3, 2015.
  1. Jul 3, 2015 at 3:30 AM
    big rig
    big rig [OP] New Member
    2015 tundra crewmax
    Hey guys, new to this website. I just picked up a 2015 crewmax SR5. Gonna install a 3" front and 2" rear leveling kit soon. Was wondering on some wheel and tire pairings that will not only look clean, but legal here in Hawaii. I believe the law here is little to no thread sticking out the fender. Im still debating on running either 18" or 20" wheels so suggestions for both sizes are welcome. 275/60 R20 seems a step up from stock as well as 275/70 R18 if i were to go that route. Any other sizes that could work with no rubbing and staying legal (hawaii law)?
    Any recommended brands for both wheels and tires?
    I really like the pro comp 7032 matte black 18x9 or 20x9 wheels, but again.....would like to know your thoughts or preference
    Was leaning towards an aggressive A/T tires or mild M/T
    maybe BFG A/T, Mickey Thompsons ATZ, open country A/T II,
    thanks in advance everyone.......stoked to be here
  2. Jul 3, 2015 at 5:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    PA has the same law. No tire tread can be outside of the fender.
    It seems that Pro Comp 7032 comes with 0 offset. That will make your tires stick way out of the wheel well. You want higher offset. Go with wheels with offset around 35. That will make the tires (275s) sit very close to the factory fender.
  3. Jul 3, 2015 at 5:16 AM
    Welcome from CO. I have 18X9 XD Monsters with a25 offset and they stick out an inch. You might want to consider Nitto to Grappler G2's for tires.
  4. Jul 5, 2015 at 12:39 PM
    big rig
    2015 tundra crewmax
    What would be the magic BS and OS set-up for 275/70 R18
    need a guide while still deciding on wheels.
    How bout 305?
    Thanks Chphilo for the specs on those 7032s. Will definitely look into that.
  5. Jul 5, 2015 at 12:44 PM
    big rig
    2015 tundra crewmax
    Someone at a wheel shop suggested with a 3" leveling kit, BS close to 5.5 and OS 12 and up to keep threads close to stock. Does that sound right. 25-35 sounds a lot better like chphilo mentioned.
  6. Jul 5, 2015 at 12:56 PM
    big rig
    2015 tundra crewmax
    Whats the BS on your setup? Your rig looks sweet.
  7. Jul 5, 2015 at 12:59 PM
    big rig
    2015 tundra crewmax
    Thanks for the response. You got pics of your rig
    st: 30734, member: 774"]PA has the same law. No tire tread can be outside of the fender.
    It seems that Pro Comp 7032 comes with 0 offset. That will make your tires stick way out of the wheel well. You want higher offset. Go with wheels with offset around 35. That will make the tires (275s) sit very close to the factory fender.[/QUOTE]
    Im also worried abo
  8. Jul 6, 2015 at 9:34 PM
    chphilo
    Western PA
    Thanks.
    The offset is 18 mm. With 9 inch width, that comes out to be 5.7" (BS).
  9. Jul 7, 2015 at 8:09 AM
    Rwchief
    Rwchief New Member
    3-1 level kit, imige dynamic speakers, taco tunes recurve EZQ, trd exaust
