2015 bed vs 2013 bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Jan 23, 2018.
  1. Jan 23, 2018 at 9:00 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    will a 2013 Toyota Tundra crew-max bed fit on a on a 2015 Toyota Tundra Crew-max. are the beds the same or is there many changes.
  2. Jan 24, 2018 at 4:02 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    If I were you I would measure the dimension on the outside and , especially take good measurements where the mounting bolts are. I believe the bed is the same except for the design of the tail gate and tail lights, so you will need all that stuff as well.
  3. Jan 24, 2018 at 4:39 AM
    Ditto^^^^^
