2015 4.6L Tundra
Discussion in '3rd Gen Tundras (2014+)' started by ghkluth, May 15, 2018.
  1. May 15, 2018 at 7:26 PM
    ghkluth
    ghkluth [OP] New Member
    2015 Tundra SR5 4.6L
    New to the group and I've but not able to find a serpentine belt diagram for a 2015 Tundra 4.6L. from what I've seen it looks like it's the same for 2007 and up but want to confirm. No diagram on truck or owners manual. belt broke and replaced but new one come somewhat apart and wrapped around clutch fan and tore up a small rubber hose in from of engine. before I replace just want to make sure I get it right. Any help would be appreciated. Also, recommend replacing idler and tensioner? Thanks!
  2. May 16, 2018 at 12:19 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    Have you searched google?
    I did a search on 'toyota 4.6 serpentine belt diagram' and found ones for the 4.6 with and without AC.
    As far as replacing the idler and tensioner, it wouldn't hurt because I've seen them fail.
  3. May 16, 2018 at 5:47 AM
    Nick T
    Nick T New Member
    Nick
    Google search for the 4.6 serpentine belt with a/c looks incorrect. Use the 5.7 diagram, they use the same belt. The 4.6 is a destroked 5.7, belt routing is identical.
