2014 with JBL , Looking for a OEM amp harness to splice up
Discussion in 'Audio & Video' started by _SP_, Feb 4, 2020.
  1. Feb 4, 2020 at 3:34 AM
    _SP_
    _SP_ [OP] New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Does anyone make a harness that I can use to tap into to get the sub out and maybe a few other channels? I bought an
    AudioControl D-6.1200 with build in DSP. Its a sick amp and should power all the speakers int he truck including the center. As I recall the center and the dash are wired off the deck. But ill address that later. Right now im searching for ANY harness that will plug right into he JBL amp so I dont have to cut or splice them tiny things and ruin that harness. Some more slack would be nice. I just dont know what harness I need. Ive been looking on Amazon but still confused on what to buy. Even if the colors are not the same Ill figure out what is what. my Android HU has 2 sets of RCAs so think ill just tap the sub. Im going to run the OEM JBL speakers till they blow so I can justify buying new speakers :yes:
    Thanks guys. I picked up the amp used but like new off Ebay for 711$ retail is 1000$.
    https://www.youtube.com/watch?v=cj9T47VkPZ8
  2. Feb 4, 2020 at 4:03 AM
    _SP_
    Shawn
    2014 1794 Edition
    de-chromed
    EDIT: Never mind I read down the page and it's not for the JBL amp... If you can post a link to where o can get a cheap plug for the JBL amp of the outputs So I can splice them I would be grateful
    looks like taco tunes sells what I need. I just have to cut off there ends and splice from there. https://*********.com/shop/toyota-t...ra-stock-amplifier-harness-interface-adapter/
    I
    ts 50$ but if its what I need I dont mind buying it.
    U
    hh why is taco tunes getting blocked out... anyways here is a screen shot. [​IMG]
  3. Feb 5, 2020 at 3:15 AM
    _SP_
    Shawn
    2014 1794 Edition
    de-chromed
    anyone? I emailed James ar tech 12volt to see if he could help , I want to buy all new speakers from him anyways that was when I posted this but have not heard back from him yet.
  4. Feb 5, 2020 at 5:27 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    https://shop.tech12volts.com/product.sc?productId=533&categoryId=32
    Link to what James sells for this..... I know James will be able to help you out, if he hasn't responded to your email just hit him up again, as he always gets back to you, just may have missed it.
    ***Edit see you have an Android HU, so may be different all together**** guess i should read all the way to the end first :facepalm:
  5. Feb 5, 2020 at 6:37 AM
    _SP_
    Shawn
    2014 1794 Edition
    de-chromed
    Hummm I see that harness is to add a DSP and an amp. I have an AMP with built in DSP. Looks like to many plugs I don't need. Ill email James again thanks for the reply
    edit: I went with these 2 harnesses from here
    https://www.autoharnesshouse.com/41112.html
    as per the sticker thread at the top of this sub forum.
    LogCabins[QUOTED] likes this.
  6. Feb 5, 2020 at 7:35 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    I used that same harness on my install and it worked fine. My system however is non JBL.
  7. Feb 6, 2020 at 3:09 AM
    _SP_
    Shawn
    2014 1794 Edition
    de-chromed
    I dont need all the Pins. I was hoping to just tap a few. thanks
