2014+ Tundra XB LED Headlight Group Buy!
Discussion in 'Lighting' started by Headlight Revolution, May 1, 2020.
  1. May 1, 2020 at 1:39 PM
    Headlight Revolution [OP] New Member Vendor
    Atlanta, GA
    Hey all!
    Back at it again with the Group Buy! This one is for you 3rd Gen. guys that have been itching to change up your Lighting game. Are you ready? I suggest you scroll down... :thumbsup:
    No Substitutes: If you don't have LED powered headlights on your Toyota Tundra, then you're just behind the times! Thankfully the new Morimoto XB LED headlights: Look great. Are well-built. Have a virtually infinite life span. An unbeatable warranty, and out-perform the alternatives. Easily making them the best Toyota Tundra LED headlights on the market today.
    Performance: We've always been blown away by the fact that the other brands don't even consider how well their headlights perform on the road at night. Most often, they're a downgrade compared to even the standard halogen setup, and that's a shame. The good news is that Morimoto's XB LED headlights produce a well defined beam pattern with a great amount of width, intensity, and a proper distribution of light. :fistbump:
    DOT-Approved: Make no mistake, these Toyota Tundra LED headlights from Morimoto will produce a much different [better] result than slapping some LED replacement bulbs into your stock housings. Their quad-projector optics meet & exceed all SAE, DOT, and FMVSS108 regulations when aimed properly...and that's easy to do with their integrated vertical/lateral adjusters. :D
    Plug-n-Play: Wiring is easy too! The XB Tundra LED headlights are designed to work without any modifications. They will plug into the factory connectors for the stock headlights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No error codes, no flickering, hyper-flashing, or radio interference. They can easily be removed, and will not void your factory warranty. :cool:
    Sequential LED DRL: Game Changer! Their LED daytime running light is powered by Osram 5000K LEDs and is insanely bright, easily visible during the day. At the top of the housings, a row of amber LED's provides the turn signal function. You can set them up to run as sequential or solid signals according to your preference. :)
    Well-Built: Their UV-coated polycarbonate lens will resist the test of time, ensuring your Toyota Tundra LED headlights will look good as new for many years to come. The PPS plastic housing is light-weight and much stronger than comparable alternatives. The die-cast aluminum heat-sinks inside the housings provide more than an adequate amount of cooling for the OEM grade Osram LED chips that produce the light. These complete headlights may be new to the market, but Morimoto's XB LED fog lights have proven themselves perfect after 5+ years out now, which is confidence inspiring. :hattip:
    They Look: Amazing. At least in our opinion! The subtle elements incorporated in their design are more than enough to make them stand out, but they're clean enough to be considered original equipment to those who don't know any better. The piano black trim and smoked gray reflectors keep the color scheme neutral, and the quad kuria-optic projectors are as modern as it gets. :amen:
    NOTE: If your truck has the DRL on the turn signals (amber) and not an LED strip at the bottom of the headlight, you will need to order a factory non-DRL relay (PN# 81980-0C020). This is a factory Toyota part that replaces the stock turn signal relay under the steering wheel, and eliminates the DRL on the turn signal circuit. The XB LED headlights have a fuse tap to add the DRL function to the lights by default. :headbang:
    Customizable: Thinking about paint-matching some OEM LED headlights from Toyota? Forget it man. Those things are nearly impossible to open up and then reliably re-seal. Going that route, you’ll be facing hours and hours of labor and a high probability for "hack job" status in the end. With Morimoto's Tundra LED headlights, that job is painless! Since they're sealed with Butyl Rubber, they are much easier to open, customize/paint and then reseal! :taco:
    What's Included:
    -HEADLIGHTS: TUNDRA XB LED (Set - L/R)
    -WIRING: Plug and Play Harness
    -LED DRIVERS: XB LED Driver Modules
    -WARRANTY: 5 Years
    Youtube Review: https://www.youtube.com/watch?v=-Q8cj-T3hQ0
    Website Listing: https://headlightrevolution.com/2014-2020-toyota-tundra-xb-led-headlights/
    Is this something that you would be interested in? Let me know! I need to guage interest on this post for Bossman. The more that are interested, the bigger the Discount amount! :yay:
    Thank You for your time,
    -Caleb @ HR
    Lowgybear, TheBeast, Ostrich and 3 others like this.
  2. May 4, 2020 at 6:08 AM
    Atlanta, GA
  3. May 4, 2020 at 10:58 AM
    Col_Guy
    Col_Guy New Member
    Colin
    2014 Silver Tundra TRD
    These look sharp I'd be interested
  4. May 4, 2020 at 11:01 AM
    CCLJ03
    CCLJ03 New-ish Member
    Craig
    Timnath, Colorado
    2018 Cement Tundra TRD Off-road
    I haven't watched the video so you'll have to excuse the ignorance, but is there any benefit to these over the LED headlights that come on most 2018+ tundras?
  5. May 4, 2020 at 11:06 AM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
  6. May 4, 2020 at 11:11 AM
    TXTundra2722
    2015 Black Tundra
    Benefit? No, looks different and has sequential turn signals. I don't remember how the lights compare over the LED headlights
  7. May 4, 2020 at 11:33 AM
    Atlanta, GA
    That is a very popular question! Check out this video we made on these bad boys, we compare them on a Wall @ 20 Feet to the OEM Halogen, as well as the OEM LED!
    OEM Halogen:
    Low beam: 410 Lux @ 20ft
    High beam: 780 Lux @ 20ft
    OEM LED:
    Low beam: 960 Lux @ 20ft
    High beam: 2,650 Lux @ 20ft
    (WOW!)
    XB LED:
    Low beam: 1,170 Lux @ 20ft
    High beam: 1,470 Lux @ 20ft
    Video Link: https://www.youtube.com/watch?v=-Q8cj-T3hQ0&t=26s
    -Review begins at 8:30
    TLDR: The OEM Halogen is Garbage, that's why you're here.
    The OEM LEDs are Awesome options, but are so Common. The High beam on these is Unreal though so if you use High beam often, OEM is the route for you!
    The XB LED packs a hefty Low beam, while offering a good High beam focus too. The Aftermarket appearance sets you apart, all while sporting a 5-Year Warranty in a DOT-Approved Housing.
    Flyinryank and iHacker like this.
  8. May 4, 2020 at 11:34 AM
    Atlanta, GA
    There's certainly benefit to the XB LEDs, it really just comes down to your Priorities and what you use most with your Headlights! :)
    TXTundra2722 likes this.
  9. May 4, 2020 at 12:09 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I have the OEM leds but do like the looks and sequential turn signals. But not at the price compared to oems. So what would the discounts be? I think if you put out some numbers might get more bites. Say..
    10 = %
    20 = %
    30 = %
    Etc..
  10. May 4, 2020 at 12:32 PM
    Atlanta, GA
    The discounts are really To Be Determined still, it comes down to how many folks can get in on the deal! I have to push pretty hard to get approval for a Group Buy so the more people that Share this around and get others in on it, the better the sale price.
    Just to Spit-ball some numbers:
    10 ppl in = 15%
    20 ppl in = 20%
    30 ppl in = 25....%? (To be Determined)
    iHacker and TXTundra2722 like this.
  11. May 4, 2020 at 12:51 PM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    I'd be interested depending on the discount :popcorn:
  12. May 4, 2020 at 1:36 PM
    Atlanta, GA
    We'll have to see what happens! I'm down to Send it, just need more support on this now!
  13. May 4, 2020 at 1:37 PM
    Atlanta, GA
  14. May 4, 2020 at 1:54 PM
    CCLJ03
    Craig
    Timnath, Colorado
    Thanks for the info! I think starting at $1,150 for headlights that look similar to, and are only marginally better than the stock headlights is going to be a tough sell.
    Motor71, Haggis777 and 16TRD like this.
  15. May 4, 2020 at 2:12 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Is the msrp on these still like $1150?
    Tundyfundy likes this.
  16. May 4, 2020 at 2:31 PM
    Atlanta, GA
    With the 20% off pulling them down to that $900 mark, I think that's pretty fair for a whole Front-end upgrade with a fresh 5-Year warranty! :)
  17. May 4, 2020 at 2:47 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Is it a limited 5 year warranty or pro-rated warranty or total replacement warranty.
    So let’s say a rock from a gravel truck chips the out side lens, or some other situation that happens? Out of your control. How is customer service, easy to talk to and deal with. Can some fine print be disclosed? If you can add link to warranty or some sort numbers for support. This is a investment for me. Sorry times are hard at this point for many.
    Ely010606 likes this.
  18. May 4, 2020 at 3:25 PM
    TXTundra2722
    2015 Black Tundra
    If you get $900 or better then im in
    Inquiringone and 16TRD like this.
  19. May 4, 2020 at 3:44 PM
    Inquiringone
    Ter
    NorCal 408
    I’m hoping for $800
  20. May 4, 2020 at 3:50 PM
    TXTundra2722
    2015 Black Tundra
    Why stop there? :)
    TheBeast likes this.
  21. May 4, 2020 at 5:56 PM
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Supercharger, Corsa, 5100’s
    I mean can’t we just throw the 07-13’s in on this too :)
  22. May 4, 2020 at 6:43 PM
    TheBeast The Beach
    you should add the gen 2 guys in the mix..I got no dogs in the fight, already have my XB headlights on :)
  23. May 5, 2020 at 5:38 AM
    Atlanta, GA
    I was thinking of that earlier too... more planning with Bossman I think.
  24. May 5, 2020 at 6:00 PM
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    I like the way your thinking, got a hole burning in my pocket :D
  25. May 5, 2020 at 6:14 PM
    Haggis777
    Haggis777 Luke 12:15
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Those are sweet!
    Do they come with a dental plan?
    Mama will knock my teeth out if I spend that much on headlights...
    Motor71, Mountun Goat, WFD473 and 5 others like this.
  26. May 5, 2020 at 11:59 PM
    Mauitundraguy
    Mauitundraguy New Member
    I’ll be interested in this
  27. May 6, 2020 at 5:57 AM
    Ostrich
    Nikki
    Marion, Texas
    I found moisture in my passenger headlight this morning.. I might be more in on this than I originally thought.
  28. May 8, 2020 at 6:08 AM
    Atlanta, GA
    Nooooo! Check your bulbs to make sure they're seated properly. How much water got in roughly?
  29. May 8, 2020 at 6:26 AM
    Ostrich
    Nikki
    Marion, Texas
    Not much, just a little condensation. I have some backup headlights just in case, but I'm still in on this for the right discount.
  30. May 8, 2020 at 8:03 AM
    Atlanta, GA
    Ah I see. Just incase it's a easy fix, I'd try replacing the O-Ring on the bulb itself, or just throw a fresh set of bulbs in there, H4 Halogens are pretty affordable! This could also be the case for the Side Marker bulb, or the Turn Signal. If it still gets condensation, remove the housing from the truck and run some smoke/Fog through the housing like a Pressure test. That should help source any holes or cracks that might have developed, a bit of Silicone is a quick fix and would save some $$$ over new housings! (Unless you wanted the Upgrade!)
    Ostrich likes this.
