2014 tundra won’t crank
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike_Stanley, Jan 28, 2024.
  1. Jan 28, 2024 at 10:40 AM
    Mike_Stanley
    Mike_Stanley [OP] New Member
    2014 Tundra SR5
    My 2014 Tundra SR5 won’t crank. This is the third time it’s happened, it’s intermittent and a day or two later I have no problem starting it for a few months. I have had It towed to a dealership and it cranked with no problem for them. They found nothing wrong. Any suggestions.
  2. Jan 31, 2024 at 6:54 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    First thing to check is battery (do a load test) and all battery and ground connections. If the battery is 3 years or older, I would just replace it.
    Your starter could be on its way out too, but checking battery, positive and ground connections to battery and starter would be the first step
    ZappBrannigan likes this.
  3. Jan 31, 2024 at 7:53 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    What he said ^^^
    When my truck was doing this it was corroded battery cable terminals. I replaced the terminals and the battery and haven’t had an issue sense.
