2014 Tundra TRD lift options
Discussion in '2.5 Gen Tundras (2014-2021)' started by zxilla, Feb 1, 2023.
  1. Feb 1, 2023 at 10:56 AM
    zxilla
    zxilla [OP] New Member
    Luke
    2014 Barcelona Red Tundra TRD
    Alpharex headlights, all lights led, rear lights replacement, black racing stripe, and wireless charging pad.
    Hello, I am currently figuratively spinning my wheels in the mud as I try to decide what lift I should install on my 2014 Tundra with the TRD Bilstein suspension package. The vehicle currently has about 140k miles, so the suspension is 'used' to say the least. I want a 3-3.5 inch lift as most of them seem to be fairly easy to install which is important because I will be (attempting) to do this myself. What I would like to know is with my current mileage and suspension package is it a better idea to run with a RC or Toytec block/spacer lift or should I buy the 3.5 RC shock bolt-on lift OR save up and buy a Toyec 3-inch lift. My budget would be my best bang for the buck under the $1500 mark. Thank you for your help and ideas.
  2. Feb 1, 2023 at 12:03 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    I'd go with toytec coilovers up front and shackles in the rear. The ride is unmatched compared to a block/spacer lift. Do it once, do it right - if you can afford to.
    Lemuel1 likes this.
  3. Feb 1, 2023 at 2:40 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Stay with 3" max lift, less headache. I was on 6112/5160 wth 1/4" CB spacer and 1.5 Toytech shackles with 37's. I'm now on Fox 2.5 DSC all around with same shackles and 37's.
  4. Feb 1, 2023 at 3:12 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    I’m on Toytec 2.5 up front with shackles and 5160s in the back. Running 37s as well
    mattyd170 and Lemuel1 like this.
  5. Feb 1, 2023 at 5:50 PM
    zxilla
    Luke
    For those running Toytec, did you do the installation, and if so was it overly difficult? Also how much trimming did you have to do for the bigger tires?
  6. Feb 1, 2023 at 5:53 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Toytec 2.5 aluma front and icon 2.5 internal res rear with toytec shackles. DO NOT GET BLOCKS. Get shackles. Super easy job. Shackles I paid to have done didn’t wanna do it. I’m on 35s.
  7. Feb 2, 2023 at 8:55 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    Yes, I did it myself. Depends on how mechanically experienced you are. If you have done a decent amount of work in the past, I'd rate it a 5/10 on the difficulty level. Just my $0.02...
    As for trimming, did a aggressive BMC. Before I had the aftermarket bumper, I trimmed about 2" off of the stock front bumper. Also installed SPC UCAs and got caster to 4 degrees.
  8. Feb 8, 2023 at 9:52 PM
    cs808
    cs808 New Member
    Utah
    2021 Sr5 crewmax, grey
    Nfab Rdms front bumper OME BP51 suspension and heavy duty leaf springs RCI engine and mid plates CBI rock sliders Method wheels/BF Goodrich T/A Ko2’s TRD pro grille, hood bulge, and sensor
    love the bronze 701s on red
