2014 Tundra Clicking sound
Discussion in '2.5 Gen Tundras (2014-2021)' started by dtasci53, May 26, 2018.
  1. May 26, 2018 at 9:05 AM
    dtasci53
    dtasci53 [OP] New Member
    2014 Toyota Tundra Sr Double Cab 4.6
    K&N Cold Air Intake New rims same size Falken Wildpeak At3 275 65 r18 New u joints carrier bearing New shocks and struts
    Hey Everyone
    I'm trying to figure out a problem I have with my truck. I have a clicking/slapping sound when I am traveling at speeds from start to 30 35 mph. Its definitely metal on metal sound as if something rotating is slapping against another metal piece not sure. It happens on acceleration and deacelerration sometimes it's a single tap sometimes its multiple. I recently changed u joints, carrier bearing, shocks and struts. Also had the driveshaft rebalanced. I still have the problem. I have 66,000 miles warranty up at 60,000. Lol go figure. I have seen similar threads saying something about CV joints or shaft, or differential crosspin somehow being loose and slapping around. Or differential bearings. If someone has an idea or having same issue please help out
    thanks.
  2. May 26, 2018 at 9:18 AM
    Welcome from Texas, have you crawled under to see anything loose or out of ordinary?
    dtasci53[OP] likes this.
  3. May 26, 2018 at 9:31 AM
    dtasci53
    Thanks coming from New Jersey. To be honest I haven't. Not entirely for sure what I need to be looking for as far as something being loose.
  4. May 26, 2018 at 9:46 AM
    Check your entire Drive Line shaft check your CV axle joints if it's a four-wheel drive
  5. May 26, 2018 at 9:48 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Is the clicking pretty consisted, almost timed? Is it sporadic and out of time?
  6. May 26, 2018 at 9:51 AM
    dtasci53
    Thanks ARamirez I'll be sure to do so. What should I feel, like loose? Etc... or have professional look at it?
  7. May 26, 2018 at 9:56 AM
    dtasci53
    Hey Backslider,
    Yea it's pretty consistent after I got ujoints and carrier bearing changed they also rebalanced the shaft, the guy said the shaft was really out of whack which explains slight vibration I had. Now no vibrations but that slapping sound isn't consistent. I seen someone with similar problem said it was their differential crosspin got loose. It happens accelerating from dead stop and coming to a stop. It happens when I turn at a dead stop too. I thought maybe transmission but clipping/ slapping sound doesn't happen same time with shifts.
  8. May 26, 2018 at 12:08 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sorry no help here but welcome from Las Vegas!!
  9. May 5, 2024 at 12:03 PM
    Bluemoon84
    Bluemoon84 New Member
    Kike
    2014 Tundra
    I was having this issue after I changed the transmission fluid on my 2014 Toyota Tundra 5.7L. This was driving me insane and the clicking sound would happen when the truck was down shifting between 25-35 miles. I took into the dealership and like always they could not mimic the sound so what I did is add another half a quart of transmission fluid into the transmission and the clicking sound went away. I hope this resolves this issue problem because it was literally driving me insane…
    Good luck!
