2014 Platinum
Discussion in 'New Member Introductions' started by Ram, Feb 23, 2016.
  1. Feb 23, 2016 at 8:51 AM
    Ram
    Ram [OP] New Member
    Ram
    2014 Toyota Tundra Platinum
    bought a 2014 tundra platinum and debating if i should get a 6 inch or simple 4 inch lift and also not sure to go with 35 or 33 tires.... Any feedback would be greatly appreciated...
  2. Feb 23, 2016 at 9:32 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I think 4" would be as high as I would go (3" if using spacers). That way I am still able to tow without a ridiculously long drop hitch. With a 3" or higher lift, 35" tires are almost mandatory. I went with a 3/1 and 285/65/r20 KO2s. If you are 4WD and go with a spacer lift, be sure and drop your diff to normalize the geometry. Rough Country makes a decent kit including diff-drop spacers.
  3. Feb 23, 2016 at 9:38 AM
    Welcome!
    3-4" is great for looks and functionality.
    Higher than 3-4" is looks. Also, if you are going that high, it may limit where you can park, and may have to cut the frame depending what kit you go with.
  4. Feb 23, 2016 at 9:50 AM
    Ram
    Ram [OP] New Member
    Ram
    Huge help! Thanks y'all
  5. Feb 23, 2016 at 7:05 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Welcome to the site. 3-4 inches is perfect. 6 is just too much.
  6. Feb 23, 2016 at 10:52 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
  7. Feb 26, 2016 at 10:28 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome! 3-3.5" lift is perfect.
