2014 Platinum Offset/Backspace Help!
Discussion in 'Wheels & Tires' started by Chris_Customs, Feb 29, 2016.
  1. Feb 29, 2016 at 4:33 PM
    Chris_Customs
    Chris_Customs [OP] New Member
    Dartmouth, MA
    2014 Platinum
    3/2 Zone Lift, Powertraxx bed cover, 20x 9 Fuel Wheels, 33 inch Duratracs
    2014 Tundra Platinum w/Zone 3/2 Lift. I want to buy wheels and tires. I went to the store and they asked that i provide the backspace and offset from the lift manufacturer. Zone said i have 5 inch Backspace and didn't know the offset? I have been to 3 different places and they are not helping. They are basically saying find the wheel you want and we will order it for you. All of the online wheel sites are asking for the offset? Does anyone own a 2014 Platinum with fuel wheels or something comparable? Can you help me with the backspace and offset. Everytime i think i have it, someone tells me different. I am looking to put 285/60/20 Duratracs on a 20x 9 wheel. Thanks
  2. Feb 29, 2016 at 4:53 PM
    Chris_Customs
    Dartmouth, MA
    2014 Platinum
    I'm am guessing my offset is Zero. Am I correct?
  3. Feb 29, 2016 at 5:41 PM
    @jberry813 has a plat. He might remember the OS and BS
    Edit: presuming you're talking about stock wheels, which if it came with that lift they probably aren't.
  4. Feb 29, 2016 at 6:01 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    Beside being 20" are platinum wheels different from the SR5 or pro wheels? I'm 99% sure the 18's are +60mm offset. I added spidertrax 1.25" to the pro wheels to get rid of the tucked look. I was told when I get around to new wheels I'll want to order around a +25-35mm to match the look. (Doing the math that puts me around +30mm now) I'm not great with keeping the wheel numbers straight but I believe the closer you get to zero and head into negative offset the further the wheel sticks out from the truck.
    When I've been browsing wheels I check the bolt patterns in the size I like and see what offset is offered.
    Not sure if this helps at all. Hopefully one of the wheel experts will be along shortly
  5. Feb 29, 2016 at 7:11 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yeah what you have now is a +60 offset. The offset range that will work best with minimal trimming would be +35 to +18 and the trimming or even body mount chop will depend on your tire size.
    How far do you want your tire to stick out?
    Will you run fender flares?
    33s or 35s?
  6. Mar 1, 2016 at 3:04 AM
    Chris_Customs
    Dartmouth, MA
    2014 Platinum
    No Flares, 33 tires, dont want to trim. I have the stock tires and wheels on now and i've run into this road bump with the offset and backspace
  7. Mar 1, 2016 at 7:04 AM
    ToyotaTundraMike
    2015 Tundra
    As others have mentioned, our stocks are +60. You want between +18 and +35 offset on your new rims (depending how far you want them to stick out). These paired with 33's and there will be no rubbing/trimming/mods (you MAY have to remove the front mudflap).
    +18 Will stick out about 3/4" - 1" from the fenders. The higher up you go the less they stick out, the lower you go the more they stick out. I wouldn't recommend lower than +18 though if you don't want to do any mods. I'm going with a +18 or a +25 whenever I order mine.
    jberry813 likes this.
  8. Mar 1, 2016 at 7:22 AM
    chphilo
    chphilo Tundra addict
    Western PA
    35 mm offset will give you less rubbing problems than 18 mm (assuming that the wheels are 9 inches wide). I have 18 mm offset wheels and 3.5 inch of OME lift. I have 34.5 inch tires and they are very very close to the body mount. I could not get any larger than my current tires without doing some serious cutting. I know some guys have successfully installed 35x12.5 tires on 35 mm offset wheels without out any modification only with Bilstein 5100 (less than 3 inch lift).
    If you are not getting some fender flares, do not get 18 mm. To give you some idea, this is a picture that shows how much tires stick out (295/70/18).
  9. Mar 1, 2016 at 8:58 AM
    Chris_Customs
    Dartmouth, MA
    2014 Platinum
    Thanks for the info, I think i finally found a competent wheel/tire dealer so we shall see. I'll post some pics after i get the new shoes
  10. Mar 1, 2016 at 6:10 PM
    TruckyTruck
    Gary
    Honestly I feel like a +20 sits just right, of course that's what I have though. But I went thru hundreds of pictures before I bought mine. If you do 33s that are 12.5 wide, your tires will stick out like my 12.5 wid in the bottom picture, but most likely with a 33, you won't have to worry about the body mount and probably won't have to trim, but it's possible the skid plate might need a trim.
    The first picture has a width of 11.7 inches and had zero problems. Just so you can see the difference.
    Not a great pic, but the only one I have that shows how far a 285 55 20 sticks out. Exactly flush with the body.
    12.5, about an inch and a half
  11. Mar 13, 2016 at 11:43 AM
    Chris_Customs
    Dartmouth, MA
    2014 Platinum
    :amen:Boom
    Cutter29 likes this.
  12. Mar 13, 2016 at 2:46 PM
    Cutter29
    Cutter29 ...
    Utah
    Specs? What offset & backspace did you end up with?
  13. Mar 13, 2016 at 2:56 PM
    Chris_Customs
    Dartmouth, MA
    2014 Platinum
    5 backspace, +20 offset....had to remove the baby front mud flap
