2014 5.7 Losing power Intermittently
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cruzinn, Jan 10, 2021.
  1. Jan 10, 2021 at 10:17 PM
    Cruzinn
    Cruzinn [OP] New Member
    Shawn
    2014 White Tundra 1794
    One month ago I started losing power while driving at a variety of speeds and temperatures. It would simply die down and idle while the accelerator was still depressed. If you release the accelerator then reapply it would pick up again then cut out shortly after. I took it in to pull codes and left it with the dealer for the week. They ran it for 300 miles without reproducing the same failure. Without incident I made a 2,000 mile road trip with a trailer. One month later it stated the same failure. I changed the Mass Airflow Sensor. Now the RPM's take a dive when it starts (almost cuts out) and I have check engine indicator. Is there something about the sensor I need to adjust or do I need to start looking somewhere else?
  2. Jan 10, 2021 at 10:51 PM
    Welcome to the site.
    What were your original codes?
    Did you change the MAF out with an aftermarket one or OEM?
    Saltyhero13 likes this.
  3. Jan 11, 2021 at 6:00 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Welcome from the Texas Hill Country.
    Intermittent, non-repeatable issue sounds like accelerator pedal or throttle position sensor/throttle control motor problems to me. Accelerator pedal is fly-by-wire. Diagnosis of throttle body problems can be done with Techstream, but your dealer has to hook it up for it to work.
  4. Jan 11, 2021 at 6:15 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    How many miles on your truck?
  5. Jan 11, 2021 at 6:20 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I had a similar issue with an older Honda Accord; turned out to be the ignition coil. Not sure if that’s possible in these trucks but had the exact same symptoms
  6. Jan 11, 2021 at 6:36 AM
    blanchard7684
    blanchard7684 New Member
    How old is battery?
    HulkSmurf14 likes this.
