2014 4x4 tundra snapped BDS Passenger from knuckle
Discussion in 'Suspension' started by Uzbek88, May 24, 2023.
  1. May 24, 2023 at 3:26 PM
    Uzbek88
    Uzbek88 [OP] New Member
    Hello everybody this is my very first form post I am very new to the community.
    2014 Toyota tundra 4x4 crew max.
    I purchased a wrecked tundra and the suspension is busted. The current lift is 4 1/2 inch BDS lift
    The impact was to the front right frame. Direct hit. Buckled the frame. My question is if anybody has tips or advice where I can find a front right, passenger side BDS knuckle and coil over. They sell them only in pairs.
    It’s gonna be a little bit over $2000 to buy the pair of coil overs and pair of knuckles. That’s excluding the ball joints and tie rod ends that I will replace because it was impacted that hard and it’s not wise for me not to replace the ball joints. I also need factory lower control arm.
  2. May 24, 2023 at 3:40 PM
    Rubberdown
    Well number one repair your coilover don’t replace. That’s probably most of the expense right there isn’t it?
  3. May 24, 2023 at 3:42 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I can't help with your issue, but welcome to the forum..:thumbsup:
  4. May 24, 2023 at 3:59 PM
    Uzbek88
    @Rubberdown yes it’s 1600 for the set. Fox won’t sell single
  5. May 25, 2023 at 1:48 PM
    Rubberdown
    So… get that one that’s damaged fixed. Any shock rebuilder can get you squared away.
  6. May 25, 2023 at 2:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I have a friend removing his bds lift on his tundra pm ill send you the info
