2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Sep 9, 2023 at 6:00 AM
    #1891
    Retired...finally
    I got an email telling me the switch is out for delivery so I tore into it. Funny thing: With the switch removed, key on and in reverse I got a good picture of the rear view. This makes me think it might be the relay..... If so, I'll dig deeper into the dash and see if it's a common piece with RCA jacks soldered on.
    I've seen both relays and switches fail if the voltage and/or current is low going through the contacts. A well designed switch or relay wipes the contacts when they close to help keep them clean.
    Update in a bit.
    bulldog93 and MadMaxCanon like this.
  2. Sep 9, 2023 at 7:05 AM
    #1892
    Retired...finally
    Well. Isn't this just great. New switch installed and it works fine. Swapped back to old and it works fine.
    Here's the relay. I'm going to see if any auto parts stores have this locally. May as well change it while I'm in there.
    https://www.amazon.com/Zlirfy-Automotive-Multi-Purpose-Replacement-Accessories/dp/B0C4DGLWHX?crid=Y4OO2ECOCY1X&keywords=mini+30+amp+12+v+relay&qid=1694267874&sprefix=mini+30+amp+12+v+relay%2Caps%2C293&sr=8-32
    MadMaxCanon and bulldog93 like this.
  3. Sep 9, 2023 at 8:03 AM
    #1893
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I'm going to try a couple things later this morning to see if I can narrow it down. I'm doubtful of the relay being the cause only because I've only ever had 1 relay go bad in the 20 years I been tinkering with cars. I'm thinking it's a loose connection somewhere which is odd because I taped everything
    bulldog93 likes this.
  4. Sep 9, 2023 at 8:11 AM
    #1894
    Retired...finally
    I found a relay at NAPA. AR385. Cost me 36 bucks:eek2:
  5. Sep 9, 2023 at 9:03 AM
    #1895
    Retired...finally
    All back together and if it will fail it will be in two weeks when I leave to go south for the winter.
  6. Sep 9, 2023 at 9:19 AM
    #1896
    coTony
    Tony
    Montrose, CO
    This is starting to sound like what I have been experiencing. It is not consistent by any means. Sometimes the pic is rock solid, other times it is black and then others it is so pixelated from being so distorted that you could not see anything. Then if I would turn it on/off/on it would clear up or get better. Just weird
  7. Sep 9, 2023 at 10:54 AM
    #1897
    Retired...finally
    My experience is when so little current passes through either relay of switch contacts they tend to fail over time. I don't know for sure but think these cameras take very little current. Yeah, $36 was a tough price when you can get four inferior quality relays from Amazon. Had I thought this out before I ordered the switch I would have replaced the relay first.
  8. Sep 9, 2023 at 11:44 AM
    #1898
    MadMaxCanon
    So I noticed today that the front camera was acting up not the back this time. I switched to the front and it went black. Did it again and it was fine. I tried it sporadically a few times while driving and noticed a delay sometimes. Also when the front camera was displayed and I hit bumps the picture was getting interference. Maybe it's my battery, it's at 9.5v on cold crank so I need a new one.
  9. Sep 9, 2023 at 12:08 PM
    #1899
    Devdog86
    Devdog86 New Member
    Brad
    Pennsylvania
    2021 Lunar Rock Trd Pro CM
    Possibly the camera RCA connection? I had mine pop out during the installation and had a black screen and rear camera still worked, I ended up taping the RCA connectors in just for added stability.
  10. Sep 9, 2023 at 12:37 PM
    #1900
    Retired...finally
    I did too since using two feet to cram the HU back in place with all those additional wires and doohickeys I figured they pull apart if I didn't.
    bulldog93 and Devdog86[QUOTED] like this.
  11. Sep 9, 2023 at 2:15 PM
    #1901
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC harness does not use automotive relays like the pics above. I believe that is one of the FRAC copycat systems. I can’t speak directly to how those systems work but for this issue they are probably similar.
    If you have a FRAC harness installed and you see a black screen when you should see camera video, it means the the FRAC circuit has switched the HeadUnit to video display mode but there is no camera video to display. In those cases, I would check all the power, ground, and video connections to the cameras. Seeing lines across the image or seeing an unstable image also indicates the same issues. Either a loose RCA or power/ground that is not providing enough signal strength for the video sync function.
    Hope this helps.
    MadMaxCanon, bulldog93 and Devdog86 like this.
  12. Sep 9, 2023 at 3:08 PM
    #1902
    Retired...finally
    I have the Anytime Backup Camera package.
  13. Sep 9, 2023 at 3:22 PM
    #1903
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm thinking it's either the RCAs going into that black box coming loose or the RCA receptacles within the box getting janky :notsure:
    So, here's a question though since we were not seeing anyone talking about these issues until recently... Are you guys (that are having the problems) all running the newest updates in hardware??
    IE>>> Do you have the Jan 2023 and forward versions which came w/dimmable switch wiring built into the units, or pre-2023?? I'm not referring to the switch itself as those have been capable to have been wired in to be dimmable but you had to tap another dimmable switch to make to that feature work; the new units can be wired that way into the supplied harnesses... (hope that makes sense)!!!!
    Devdog86[QUOTED] and bulldog93 like this.
  14. Sep 9, 2023 at 3:47 PM
    #1904
    Retired...finally
    I've had my anytime system since early 22 and do use it often.
    Tripleconpanna likes this.
  15. Sep 9, 2023 at 4:07 PM
    #1905
    Tripleconpanna
    I've had mine since late '22, and I've not had any issues. I was just hoping to maybe identify a consistent issue (if there is one) to help Lou troubleshoot.
    It is quite possible that in the process of bending the wiring harnesses around and such as we are moving these things (head unit) from on top of the dash back into place that maybe those RCAs are coming just loose enough to have intermittent problems :notsure:
    Devdog86 and bulldog93 like this.
  16. Sep 9, 2023 at 4:31 PM
    #1906
    MadMaxCanon
    It seems to point to that it's just hard for me to believe since I taped it
  17. Sep 9, 2023 at 4:32 PM
    #1907
    MadMaxCanon
    Would a weak battery that needs replacement cause this?
  18. Sep 9, 2023 at 4:34 PM
    #1908
    MadMaxCanon
    I've had my system almost 2 years
  19. Sep 10, 2023 at 8:07 PM
    #1909
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Ok. That explains the automotive relays. I don’t know exactly how that system is wired but I think it’s slightly different than the FRAC based on some of the different functionality I’ve read about. But the head unit is the same so if the RCAs are solid, then I would trace and measure the power and ground. It is also possible that the relays are failing or that they could be going bad as someone suggested before. That’s the best I can suggest since the ABC is not my design and I’m not sure how it’s configured.
    Tripleconpanna and bulldog93 like this.
  20. Sep 10, 2023 at 8:10 PM
    #1910
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    It’s possible. Though if the alternator is charging properly you should have plenty of voltage when the engine is running. Have you measured the running voltage?
  21. Sep 10, 2023 at 9:27 PM
    #1911
    MadMaxCanon
    Yeah it's normal. My cold start volts is low 9s though
  22. Sep 11, 2023 at 5:08 AM
    #1912
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You mentioned earlier that going over bumps in the road would cause some of the issues you’ve been seeing. That points to a loose or intermittent connection someplace. Since you’ve already check the RCA connections, I would re-check all the power and ground connections. The FRAC is powered by ignition voltage, so if you used the FRAC cam power lead to power your front camera, and your alternator is producing good charging voltage, then the low battery shouldn’t affect it.
  23. Sep 11, 2023 at 6:58 AM
    #1913
    MadMaxCanon
    Makes sense. I am going to install the new battery later this week, hopefully it helps, but I dont think it will. I really wanted to avoid getting behind the head unit again but at this point i dont think I am going to be able to avoid it.
  24. Sep 11, 2023 at 7:23 AM
    #1914
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Not sure what power/ground connections you have in the engine bay and grill area for the camera, but you might want to look at those as well.
  25. Sep 12, 2023 at 6:38 AM
    #1915
    brutalitybob
    brutalitybob New Member
    just popping in here wondering if this is going to be possible and available soon for the 2022+ tundra. Sign me up on the waitlist if so
  26. Sep 13, 2023 at 5:11 PM
    #1916
    Devdog86
    Devdog86 New Member
    Brad
    Pennsylvania
    I would check with @TundraTex first but according to the description on the website for the 2020-2021 harness it will work on some 2022’s without the 360 degree panoramic view
    system.
    https://www.fracharness.com/
  27. Sep 13, 2023 at 9:10 PM
    #1917
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    What @Devdog86 said... Unfortunately the connectors that Toyota switched to in 2022 are not commercially available yet. Once they are, I'll be able to start building the FRAC Harness for the panoramic and Multi-terrain-monitor vehicles.
    Yota802, Tripleconpanna and bulldog93 like this.
  28. Sep 14, 2023 at 6:32 AM
    #1918
    brutalitybob
    Awesome thanks for the headsup! Ill stand by awaiting your work once those connectors become available. :)
  29. Sep 14, 2023 at 9:32 AM
    #1919
    TRD4x4Liberty
    TRD4x4Liberty Dog hauler
    NYC area
    Heavy Metal Crown - Black TRD PRO Sequoia
    Original.
    Awesome.
  30. Sep 25, 2023 at 6:06 PM
    #1920
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I’m interested as well.
