2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Nov 5, 2021 at 4:13 AM
    #1681
    Peej419
    Peej419 New Member
    Cannot find DVR option that works to tie both cameras into FRAC. Would these 2 options work with FRAC?
    https://www.amazon.com/dp/B08CH91V1W?_encoding=UTF8
    https://www.amazon.com/dp/B09K7P9K1J?_encoding=UTF8
  2. Nov 5, 2021 at 6:00 AM
    #1682
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Putting out the feelers, but I am parting out my truck and have a frac harness + camera cusotm mounted in a MGM trd pro grill in Boise, ID. Don't want to ship everything, so if your somewhat local I'll cut you a great deal.
  3. Nov 5, 2021 at 6:31 AM
    #1683
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  4. Nov 6, 2021 at 9:02 AM
    #1684
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    It looks lik you have link an HDMI to AV converter and and HDMI recorder. The Tundra video is standard analog NTSC video, not HDMI. So if you want to use the HDMI video capture device, you would need to convert the existing analog AV signals to digital (HDMI).
    Also, these devices are single-channel, so if you want both front and rear video to record, you would need two sets of these items.
    bulldog93 likes this.
  5. Nov 30, 2021 at 4:29 AM
    #1685
    daveeasa
    David
    I was thinking the same thing. @Puppypunter might have cool ideas.
    OP, thanks for the inspiration on the switch, I had been agonizing about that for quite some time and I think the simple option is a good one as you’ve done. The ABC switch isn’t an option in my 2002 unfortunately but the round I / II should work for now. Steering wheel controls would be ideal really but a lot of work to add.
    Auto on would make me happy though since I’m running a Pionner 4660 so I can force camera on if I want to do it the hard way but I would definitely appreciate not having to.
  6. Dec 6, 2021 at 12:49 PM
    #1686
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    What are you guys finding most useful with this?
  7. Dec 6, 2021 at 5:23 PM
    #1687
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I have a piece of tape on the floor of my garage running from the door to the wall. If I line the "parking" lines on the camera up with the edge of the tape, I know that I won't scrape my truck on the side of my work bench. (I only have 2" of clearance between the edge of my truck body and the bench.) I have gotten good enough now that I can almost always pull in to the driveway and line up perfectly with the tape.
    bulldog93 and steved0xTD like this.
  8. Dec 6, 2021 at 5:25 PM
    #1688
    parkerbows
    Jack
    yeah I like that, even just getting super close in a parking lot I guess
  9. Dec 6, 2021 at 9:46 PM
    #1689
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    When I can't back into a parking place, I get as close as possible to the front line so my truck is not sticking out into the aisle. These trucks are not short.
  10. Dec 7, 2021 at 3:23 AM
    #1690
    parkerbows
    Jack
    thanks. kind of what I was thinking. going on my want list
  11. Dec 7, 2021 at 5:15 AM
    #1691
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    Me too, I find myself backing up more so I can get right on the line/up to the pole when parking, when I pull in, I leave too much room. Going to install over Christmas break :)
  12. Dec 7, 2021 at 7:41 AM
    #1692
    CGP
    CGP New Member
    Ability to get up-close and personal.
  13. Dec 16, 2021 at 8:24 AM
    #1693
    SWITCHES
    SWITCHES New Member
    08 Tundra crewmax limited 5.7 4WD
    3" leveling kit
    Hey fellas
    I've been watching this thread for awhile (like a fat kid watches cake) And I'm wondering if theres any info on getting a FRAC w/nav bypass harness installed in my 2008 Tundra Limited CrewMax? I was gonna try the LockPick route but, I read if you let the dealership flash the ECM for the recall they snuck in a patch that disabled said Lockpick from interfacing with stock HU .. any guidance is appreciated ..
    TundraTex[OP] likes this.
  14. Dec 16, 2021 at 11:16 AM
    #1694
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness is compatible with 2014 to 2021 Tundras. I designed the FRAC core circuit to work with virtually any vehicle. The issue is getting the circuit interconnected with the correct plug-and-play connectors and harnesses of other vehicles and year models. It could likely be done. But it wouldn’t necessarily be plug and play. I’ll have to give that some thought.
  15. Dec 17, 2021 at 5:08 AM
    #1695
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If you are serious about wanting a FRAC Harness for your 2008, I will look into what it takes to make it happen. I'll need more info on your head unit amp configuration and camera display though. PM me if you're interested.
    Lou
    SWITCHES[QUOTED] likes this.
  16. Dec 17, 2021 at 5:19 AM
    #1696
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I installed the frac last weekend and it's awesome!
    Has anyone had issue with water or moisture getting in the camera through the wire hole? I know it's IP rated but was thinking about putting a glob of silicone to fill the hole.
  17. Dec 17, 2021 at 5:25 AM
    #1697
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad the FRAC is working out for you! The Natika cameras are pretty well built. They usually are epoxied internally to keep the water out, but if a dab of silicon makes you feel better, do it!
    MadMaxCanon[QUOTED] likes this.
  18. Dec 17, 2021 at 5:26 AM
    #1698
    MadMaxCanon
    I figured that's how they get their IP rating but I am nothing if not a huge supporter of overkill.
    TundraTex[QUOTED][OP] likes this.
  19. Dec 17, 2021 at 5:29 AM
    #1699
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    LOL, spoken like an engineer. Make it so!
  20. Dec 22, 2021 at 3:59 PM
    #1700
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Spent a good part of the weekend doing a website update. It's not quite ready for publishing, but I though I'd give y'all a snapshot of one of the new items that will be available in January.
  21. Dec 27, 2021 at 10:01 PM
    #1701
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    This is awesome. I’ll be ordering this after the first of the year, along with the new OEM style switch.
    So when can we expect a cargo camera in the third brake light above the back window? :boink: :D
  22. Dec 28, 2021 at 9:27 PM
    #1702
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Posted this in a fresh thread, but including it here for those following this thread...
    After much effort I have now sourced an OEM Style FRAC Camera selection switch (Pic Below)
    To celebrate this momentous event and to thank all of my previous and future forum customers, I will be offering Tundras.Com members free shipping on all paid orders from my website www.FRACharness.com now through the end of January.
    Use Promo Code TUNDRAS.COM at checkout to receive free shipping.
    The switch price has been reduced to $25 (or $20 if ordered with a Full FRAC Harness kit).
    I have spiffed up the website a bit and added standard Credit Card payment options. It's been reviewed and tested, but please let me know if you see any typos or encounter any difficulty in the ordering process.
    Wishing you all a Very Happy New Year!
    - Lou
  23. Dec 28, 2021 at 9:38 PM
    #1703
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I should also mention that I reduced the FRAC Kit price to $170 (plus applicable sales tax and shipping).
    French Avocado and bulldog93 like this.
  24. Dec 28, 2021 at 9:44 PM
    #1704
    HamHands
    Website looks great! I’ll be ordering in January.
  25. Dec 28, 2021 at 10:11 PM
    #1705
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Installation instructions are also now available on-line at the website's Installation Help page.
    bulldog93, cowboyjack and daveeasa like this.
  26. Dec 31, 2021 at 9:38 AM
    #1706
    BLONGTX
    BLONGTX New Member
    SAN ANTONIO
    2019 Crewmax 4x4
    So I have my frac roughed in for testing, when I switch from the "rear camera view" to "OFF" using the switch it flashes a quick view of the front camera before turning the frac off. Does anyone else have this problem, and is there something I can do to troubleshoot this?
  27. Dec 31, 2021 at 9:40 AM
    #1707
    MadMaxCanon
    This happens to me too. Pretty sure it's because it's a dual throw switch and maybe it's sensitive. It doesn't seem to be a problem though.
    BLONGTX[QUOTED] likes this.
  28. Dec 31, 2021 at 10:29 AM
    #1708
    steved0xTD
    The install guide mentions this as normal behavior due to different head unit and FRAC relay speeds or something. I haven't installed mine yet so I haven't seen it myself yet.
  29. Dec 31, 2021 at 11:03 AM
    #1709
    BLONGTX
    BLONGTX New Member
    SAN ANTONIO
    2019 Crewmax 4x4
    Got it, thanks folks. Sounds like it's going to work well then.
  30. Dec 31, 2021 at 11:08 AM
    #1710
    How did I miss this? :facepalm:
