2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Sep 25, 2021 at 9:24 AM
    #1651
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    The wires on your kit are long enough. That’s where I installed the switches on my 2019 (and I wish I had on the 2021).
    AZTundra[QUOTED] likes this.
  2. Sep 25, 2021 at 9:29 AM
    #1652
    okcowboy
    okcowboy New Member
    Like this? I will probably move mine to this location on my 2021 because it is really nice to have them right under my fingers. I use the front cam every time I pull into the garage to help me line up just right because I only have 2” of clearance on my passenger side.
    bulldog93 and AZTundra[QUOTED] like this.
  3. Sep 25, 2021 at 9:31 AM
    #1653
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the heads up. I remembered you said that they were lengthened, but I didn't read through to see where you had them mounted. That should work out perfect then. :thumbsup: Hoping to have the time next weekend for the install along with some other goodies that have been waiting.
  4. Sep 25, 2021 at 9:33 AM
    #1654
    okcowboy
    okcowboy New Member
    AZTundra, it’s a little tight in the console but it works.
    AZTundra likes this.
  5. Sep 25, 2021 at 9:33 AM
    #1655
    AZTundra
    Paul
    Phoenix, AZ
    Exactly what I was looking to do. I think that is the perfect place to mount them. Very convenient and also hidden.
  6. Sep 25, 2021 at 5:08 PM
    #1656
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I misread your question. I thought you were asking about the credit card spot. I do not believe there is enough room behind the panel where your red boxes are.
  7. Sep 25, 2021 at 7:16 PM
    #1657
    AZTundra
    Paul
    Phoenix, AZ
    Yes, there is enough room to fit them in that location. I took it apart to get started on the install, but ran out of time. Will hopefully continue on it tomorrow or else next weekend.
  8. Sep 25, 2021 at 11:13 PM
    #1658
    AZTundra
    Paul
    Phoenix, AZ
    Can anyone confirm I won't be using the red or black cable for anything? Only the yellow rca and the trigger wire need to be connected behind the dash. This is a Nakita camera.
    bulldog93 likes this.
  9. Sep 26, 2021 at 8:10 AM
    #1659
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The Reds are common. So you only need to connect the red to the FRAC Harness red power lead. However you need to connect the camera harness Black wire to a good ground.
    Bakershack and AZTundra[QUOTED] like this.
  10. Sep 26, 2021 at 8:20 AM
    #1660
    AZTundra
    Paul
    Phoenix, AZ
    So just ground the black wire and cut/cap off the red wire? Then connect the trigger wire and yellow rca to the frac?
  11. Sep 26, 2021 at 8:47 AM
    #1661
    Lou, any progress on the new switch?
    @TundraTex
  12. Sep 26, 2021 at 8:49 AM
    #1662
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Exactly!
  13. Sep 26, 2021 at 8:52 AM
    #1663
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Kinda... I could not find a manufacturer that wasn't flaky. So I'm working on a different design solution. This will be a momentary push button switch that rotates through each display mode. i.e. Off, Front, Rear, Off Front, Rear, etc... with each push...
  14. Sep 26, 2021 at 9:23 AM
    #1664
    :thumbsup:
  15. Sep 26, 2021 at 11:25 AM
    #1665
    AZTundra
    Paul
    Phoenix, AZ
    Thank you sir. :hattip:
  16. Sep 26, 2021 at 3:57 PM
    #1666
    Islandboy_671
    Islandboy_671 #gotte'y sibesa-hu
    Toby
    Lacey, WA
    2016 SR5 Tundra TRD Inferno
    8" ReadyLift w/ Bilstein Coil-overs and Rear Shocks, BAM 8" Exhaust, Stillen CAI, Coach-Builder Steering Kit and 3" Rear Shackles, Tech12Volts Remote Start and JBL speaker Upgrade system, Pioneer DMH-WT8600NEX HU, 3W Liners window mod, Morimoto XB LED Headlights, RC 30" Light Bar, RC 2" x4 cube LED's, HRS Smoked Sequential Tail Lights, Mammoth Guards Kryptek Gap Guards, Fab Fours Matrix Front Bumper, Fab Fours Vengeance Rear Bumper...
    Question for knowledge… so i already can do anytime rear camera with my HU setup and my question is do I need a FRAC harness if i already have a second connection for a camera hookup and the rear anytime camera?
  17. Sep 27, 2021 at 5:21 AM
    #1667
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    That depends on your Head Unit. If you already have anytime Backup and an option for a second camera, that might have an anytime function as well. You can test this by plugging your existing camera into the second port to see if it works.
    If this doesn't work and if you want an anytime front camera as well, then the FRAC Harness will provide that with your aftermarket HU as long as it is wired with plug and play adapters to your Tundra factory harnesses.
    Islandboy_671[QUOTED] likes this.
  18. Sep 27, 2021 at 5:44 AM
    #1668
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    I like the sound of that one!
  19. Sep 27, 2021 at 9:19 AM
    #1669
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Finished installed the FRAC and the camera
    Does anyone know if our Stock HU output 720p display? I installed the camera, it say to cut the "Purple wire" to display it in 720p
    So, I cut the "White and Green" wire cause to use the Front Camera only and to remove the guidelines.
    Thanks in advance.
  20. Sep 27, 2021 at 4:34 PM
    #1670
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Has anyone put a phone mirroring kit in line with the FRAC?
  21. Sep 27, 2021 at 7:45 PM
    #1671
    Islandboy_671
    Toby
    Lacey, WA
    Thanks @TundraTex... I have the Pioneer DMH-8600NEX with the brake bypass and the HU hack paired with the Maestro RR. I will hook the other camera I have and see if it does work already and post an update upon completion!
  22. Sep 28, 2021 at 5:17 PM
    #1672
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If you do it’ll work just fine. The FRAC Harness passes all signals from the factory harnesses through to the head unit. The mirroring pins are completely separate from the FRAC pins so there will be no conflicts.
  23. Sep 28, 2021 at 5:40 PM
    #1673
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Thanks for the reply and thanks for all you've done with the FRAC, love mine.
  24. Oct 3, 2021 at 1:41 PM
    #1674
    AZTundra
    Paul
    Phoenix, AZ
    Finished the FRAC Harness install today. Last step was just getting the right size hole drilled for the switches. My step bit only went to 3/4" and that wasn't quite big enough. Used a larger step bit from my father in law and it took one step up. 13/16" is the right size if anyone else needs to know. The switches fit nicely right under the center console armrest.
    bulldog93, twotrack, BLONGTX and 5 others like this.
  25. Oct 3, 2021 at 4:36 PM
    #1675
    SAGE63
    San Diego County
    Put my switches here...
    bulldog93, steved0xTD and AZTundra like this.
  26. Oct 3, 2021 at 6:03 PM
    #1676
    steved0xTD
    I've got the kit but haven't installed yet, I really like this placement.
  27. Oct 3, 2021 at 6:54 PM
    #1677
    AZTundra
    Paul
    Phoenix, AZ
    I feel it's the perfect spot for them. They are tucked away, but also right at your fingertips when you want to use them. You'll need to lengethen the wires a bit to reach that spot, but it's well worth it.
    BLONGTX and steved0xTD[QUOTED] like this.
  28. Oct 4, 2021 at 12:16 AM
    #1678
    Islandboy_671
    Toby
    Lacey, WA
    *UPDATE from my last post* So I was able to hook up a second camera to my Pioneer HU and I'm able to view the front camera anytime along with the rearview camera without having to use a FRAC harness. @TundraTex, Thanks for the insight on that one and now just need to find a good mounting place for the front camera.
    TundraTex[OP] likes this.
  29. Oct 4, 2021 at 1:52 PM
    #1679
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice Job on the install! The switches are designed for a 20mm hole which is closer to 25/32. But obviously 13/16 is close enough!
  30. Oct 5, 2021 at 12:19 PM
    #1680
    steved0xTD
    I have got the FRAC harness along with the Natika camera and getting ready to install, as I would especially like the ability to see the front camera when parking. I saw something about the 2022 where the front camera comes on at low speeds automatically and I was thinking of hooking up something like that. I could use an extra switch to enable/disable this functionality, and it would work similar to the auto high beams. Front camera switch on + auto on, it stays off and only comes on under 5 mph (or some threshold). Front camera switch on + auto on disabled, the behavior is just like the current operation. I could do this with a small arduino board and a GPS, but I wondered (but haven't yet searched) on if there is a way to tap into the OBDII line (or other line?) and query the car for the speed (but without running a dongle). The arduino + gps wouldn't be too expensive, would have to run an antenna somewhere to get decent reception as I don't think it would pick much up buried under the dash. Before I get going on this, has anyone else already done it?
    Thank you,
    1794TX likes this.
