2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Mar 31, 2021 at 7:07 PM
    #1561
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Seems like it would be a good idea to have a camera that could tilt up and down for on-road/off-road use. I think someone has tried the Natika license plate camera (link below). Does anyone else have an adjustable-tilt camera or solution? If so, do you ever change the tilt?
    https://www.amazon.com/NATIKA-License-Backup-Waterproof-Reverse/dp/B07JCSYPPS/ref=sr_1_4?dchild=1&keywords=natika+license+plate+camera&qid=1617242577&sr=8-4
  2. Apr 1, 2021 at 3:38 PM
    #1562
    3rdTundra
    Central Texas
    Crickets from my last post...
    Looks like this Natika camera that people have used also has the ability to tilt and is higher resolution. Is anyone using the tilt feature after install?
    https://www.amazon.com/dp/B07HNRYHZ6
  3. Apr 1, 2021 at 3:38 PM
    #1563
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    One in a million shot!
    Flipped my switch to use the front camera...
    Uh, what’s this?
    That’s a hell of a bug???
    Let me go clean it off.
    Uhg, that’s not cleaning off.
    Fortunately, after contacting the manufacturer for a replacement camera without the cables, this outstanding company is going to replace the camera free of charge, under warranty.
    https://www.amazon.com/NATIKA-Backup-Camera-Waterproof-Reverse/dp/B07H852D49
    That’s customer service!
  4. Apr 1, 2021 at 3:40 PM
    #1564
    Hightide
    Abalama
    Magic School Bus
    I can’t say that anyone I’ve seen on Tundras.com has done this.
    Try it out.
    Post results.
  5. Apr 8, 2021 at 7:42 PM
    #1565
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    This is why I recommend the NATIKA camera. Great quality (normally), great price, and great customer service.
  6. Apr 8, 2021 at 8:25 PM
    #1566
    Hightide
    Abalama
    Magic School Bus
    Absolutely.
    Even after that impact the camera still worked.
    They exchanged without hesitation.
    TundraTex[QUOTED][OP] likes this.
  7. Apr 9, 2021 at 9:21 AM
    #1567
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    HulkSmurf14 likes this.
  8. Apr 9, 2021 at 9:20 PM
    #1568
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Looks like it should work just fine. The specs say it has a "Standard video connector can connect to any screen or video input." The FRAC harness accepts standard video inputs.
  9. Apr 10, 2021 at 7:44 AM
    #1569
    Occidentalis
    North Florida
    Thanks Tex! I got one of your harnesses second hand and I'm excited to use it. Really appreciate your ingenuity and input.
  10. Apr 10, 2021 at 4:10 PM
    #1570
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Good deal. PM me if you need any installation instructions or if you have any other questions.
    Jr3volution likes this.
  11. Apr 16, 2021 at 6:24 PM
    #1571
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    Installed my FRAC today with the Natika camera... I've got a TRD PRO and the pre-collision sensor is a bit of a challenge to mount by. What are the best TRD PRO mounting options.... The camera post prevents me from moving it any more forward. I used mending braces to mount off the two pre-collision bolts. Looking for better ideas that bring the camera forward.
    Beesta and IndianaGeologist like this.
  12. Apr 16, 2021 at 6:29 PM
    #1572
    Hightide
    Abalama
    Magic School Bus
  13. Apr 16, 2021 at 6:32 PM
    #1573
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I installed mine on the lower valance; worked great there
    rebmo likes this.
  14. Apr 16, 2021 at 6:32 PM
    #1574
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Every man in his life comes to the point and must decide to go high or go low - but I digress. I would try mounting above the TSS between the Y and O just below the top row.
  15. Apr 19, 2021 at 8:13 AM
    #1575
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I finally got my FRAC installed with the Natika camera. My TRD Sport version has no open switch blanks, so I need to mount them under the ledge. The insulated connectors that came on the kit are too tall to allow the panel to push in. I'm going to get some 90 degree connectors and see if it clears. It works well, but I can't button it up yet.
  16. Apr 19, 2021 at 8:38 AM
    #1576
    shawn474
    MoCo, Maryland
    I trimmed the cross brace plastic to allow enough depth to push in the dash.
  17. Apr 19, 2021 at 12:05 PM
    #1577
    French Avocado
    Utah / Wyo
    I am waiting for TundraTex to source a new switch to add before finishing my FRAC project.
  18. Apr 19, 2021 at 12:08 PM
    #1578
    Hightide
    Abalama
    Magic School Bus
  19. Apr 19, 2021 at 12:38 PM
    #1579
    Occidentalis
    North Florida
    Hightide[QUOTED] likes this.
  20. Apr 19, 2021 at 6:41 PM
    #1580
    Army_of_One
    OEM+
    The "Flag Spade Connectors" worked perfectly. My switches are setup and I put all of the panels back.
    TundraTex[OP] likes this.
  21. Apr 20, 2021 at 5:46 AM
    #1581
    coTony
    Tony
    Montrose, CO
    I swapped out the spade connectors with 90 degree spades and it fit with no trouble
    TundraTex[OP] and Army_of_One like this.
  22. Apr 24, 2021 at 3:25 PM
    #1582
    3rdTundra
    Central Texas
    Installed the Front/Rear Anytime Camera (FRAC) harness. Used the same setup as @Tchase . Also added the AJT Design climate control blackout rings while I had the dash apart. Sorry for the poor quality images. Phone camera/display artifacts. Image on screen is clear.
    Here is mounting location.
    First image is with camera 15 degrees down from horizontal.
    Second image is with camera at horizontal
  23. Apr 24, 2021 at 3:26 PM
    #1583
    3rdTundra
    Central Texas
    15 degrees down shows the bumper edges. I can see objects within about 4 inches of the bumper at the break point on the bumper.
  24. Apr 24, 2021 at 3:27 PM
    #1584
    3rdTundra
    Central Texas
    OK. How do you put text between the pictures... Thought I had done that but all the text was above the pictures.
  25. Apr 24, 2021 at 3:28 PM
    #1585
    Hightide
    Abalama
    Magic School Bus
    Just hit edit, click on a picture then hit the space bar.
    It should give a space in between pics.
    Type away.
  26. Apr 24, 2021 at 3:57 PM
    #1586
    3rdTundra
    Central Texas
    Hightide likes this.
  27. Apr 24, 2021 at 6:15 PM
    #1587
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice Job! Great to see another satisfied FRAC customer installation!
    HulkSmurf14 and IndianaGeologist like this.
  28. Apr 25, 2021 at 6:55 AM
    #1588
    coTony
    Tony
    Montrose, CO
    Anything for a 2021 4Runner? Just bought my wife one and she asked me where the front camera was
  29. Apr 25, 2021 at 7:08 AM
    #1589
    3rdTundra
    Central Texas
    See the Frac Website. The 2021 4Runner is listed.
    www.fracv2.com
    coTony[QUOTED] likes this.
  30. Apr 25, 2021 at 7:32 AM
    #1590
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. The FRAC harness is compatible with all 2014 or newer Tundras, Tacoma’s, 4Runners, and Sequoias. Also other select Toyota vehicles that have the same Entune Head Unit.
    coTony[QUOTED] and nlaroy like this.
