2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Nov 16, 2020 at 6:13 PM
    #1531
    browntundra77
    browntundra77 New Member
    Devon
    DMV
    2017 SBM Tundra Platinum CM
    I would like a frac harness please
  2. Nov 16, 2020 at 6:16 PM
    #1532
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Go to the original post #1 for details and the video. Order it from Lou's website https://www.fracv2.com/order/ You need to buy the camera separately.
  3. Nov 24, 2020 at 4:29 PM
    #1533
    SouthWestGA
    SouthWestGA New Member
    Do you make anything for a 2007 Tundra SR5 with factory backup camera?
  4. Nov 25, 2020 at 10:08 AM
    #1534
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    No I don’t. The FRAC Harness is designed for 2014-2021 Toyota vehicles.
  5. Nov 28, 2020 at 11:29 AM
    #1535
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    OK guys, I FINALLY got my FRAC harness working properly, and it is AWESOME! I cannot tell you how thankful I am for Lou (@TundraTex). He stuck with me through a LOT of troubleshooting, spending way more time with me than I was worth, as you'll see below.
    Let me explain why I would not have been a very good mechanical engineer. The following image is from Lou's manual for installing the FRAC harness:
    See that little word at the top of the photo that says "TOP"? It matters. Here is the photo that would have saved Lou (and me) a LOT of time and frustration:
    See the difference? I didn't until it was pointed out to me. Actually, I need to give Brian, with Anytime Camera, credit for this one. Lou had given up and was going to give me a full refund since we could not get it to work in my truck. I was going to order the Anytime to try it out. I had already bought the Anytime switch and had a camera, so I called to see if I could just order the harness. Brian recognized the issue immediately and the FRAC started working properly immediately after I connected it properly. He even laughed when I told him that he had just talked me out of buying the Anytime harness!
    A bit of really good news to add: Inserting the FRAC harness into the wrong 28-pin port on the head unit does not seem to damage either the head unit or the FRAC harness. It just gets you the following functionality: No camera unless in reverse - head unit operates normally; Front camera when in reverse UNLESS the rear camera is selected on the switch, in which case the rear camera is displayed.
    One more note: I overcomplicated this installation WAY too much by watching EVERY install video I could find, and not paying enough attention to the very good instruction manual that Lou includes with the FRAC harness. I'm pretty sure the installation would have gone more smoothly if I had not watched any videos and just followed his instructions! The only video that I really needed was to show me how to disassemble the dash enough to run and connect the cables.
    Thanks again Lou for all your help!
  6. Nov 28, 2020 at 11:42 AM
    #1536
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Glad to hear that you got it working!
  7. Nov 28, 2020 at 2:15 PM
    #1537
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Bakershack, thanks for your post. I’m very happy that things are working now. Kinda mad at myself for not following the number one rule of remote troubleshooting - Assume nothing! Lesson has been re-learned. Happy FRAC-ing!
  8. Nov 28, 2020 at 4:12 PM
    #1538
    TheBigTimpin
    TheBigTimpin New Member
    Thanks for posting
  9. Nov 29, 2020 at 5:26 AM
    #1539
    Saab95v6
    Saab95v6 New Member
    Finally Had a chance to install my FRAC harness and Front Natika camera . Install went great , though had to call Lou a few times . Lou was very helpful and responsive . We followed lot of instructions from some of the posters on this thread which was very helpful. The Harness is great , wish the switch cables were a little longer to accommodate the switch install under the armrest , but was no biggie , we solder extra length. We also installed the Rago dash mount while I had the stereo out .
    TundraTex[OP] and French Avocado like this.
  10. Dec 4, 2020 at 6:10 PM
    #1540
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Has anyone used the front camera as a dash cam? Like have it constantly on and recording but also have access to use it for parking and such? I’m thinking about a fisheye camera, so I can see the front bumper and the horizon.
    TundraTex[OP] likes this.
  11. Dec 4, 2020 at 6:32 PM
    #1541
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    On the trails, I’d would have it on to see what’s in front of me or as I descend. I’m not sure if anyone has recording capabilities.
  12. Dec 5, 2020 at 4:34 AM
    #1542
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You can easily accomplish DVR and dash cam functionality. The FRAC Harness provides the front and rear camera video signals on RCA connectors. You can connect a mobile DVR video in line with the FRAC harness and power the DVR with the front cam power lead from the FRAC Harness. In this configuration, the DVR would record any time the ignition is on. If you want the front cam and DVR recording all the time, you can power them directly from the battery rather than the FRAC power lead. If you were to do something like this, I would put a switch in the DVR/Cam battery power line to be able to turn off dash cam mode if you were going to be parked somewhere that you didn't need to be recording and drawing on the battery.
  13. Dec 5, 2020 at 1:34 PM
    #1543
    Top Cat
    Top Cat New Member
    Rick
    2018 Tundra (1794)
    Custom rack, drivers side grab handle, bed mat,
    Ordered mine.
    Thanks.
  14. Dec 28, 2020 at 6:57 AM
    #1544
    19crewmaxTRD
    Seth
    Ordered my the harness, going to looking into 12v dvrs
  15. Jan 24, 2021 at 8:56 PM
    #1545
    Lou, any update?
  16. Jan 24, 2021 at 9:55 PM
    #1546
    French Avocado
    Utah / Wyo
  17. Jan 25, 2021 at 4:17 AM
    #1547
  18. Jan 25, 2021 at 3:45 PM
    #1548
    French Avocado
    Utah / Wyo
    Worthy inquiry. @TundraTex - Lou any luck with a new supplier?
    Tundra805 likes this.
  19. Jan 26, 2021 at 10:01 AM
    #1549
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nothing firm yet. I do have additional inquiries in the works but the stupid China-virus has made a slow process even slower.
    Jim LE 1301 and Tundra805 like this.
  20. Jan 27, 2021 at 9:08 AM
    #1550
    French Avocado
    Utah / Wyo
    Thanks Lou - just waiting (impatiently)
  21. Mar 7, 2021 at 2:41 PM
    #1551
    Hey Lou, any updates? :fingerscrossed:
    HulkSmurf14 likes this.
  22. Mar 14, 2021 at 9:06 AM
    #1552
    trevorstuart24
    trevorstuart24 New Member
    Any options for 2nd gen?
  23. Mar 14, 2021 at 10:06 AM
    #1553
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Sadly, no updates. Still working it.
  24. Mar 14, 2021 at 12:27 PM
    #1554
    Thanks Lou.
  25. Mar 14, 2021 at 1:02 PM
    #1555
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    No. The FRAC Harness was designed for 3rd Gen vehicles.
  26. Mar 27, 2021 at 7:46 AM
    #1556
    Yzed608
    Yzed608 New Member
    Wisconsin
    Does anyone know the FOV of the OEM backup camera? I'd like the same for the front so you can still see the bumper corners. Every camera I've seen so far mounted for the front you can only see in front of the truck not the corners.
  27. Mar 30, 2021 at 4:47 PM
    #1557
    trevorstuart24
    Id guess 170 or 180 but idk for sure
  28. Mar 31, 2021 at 8:19 AM
    #1558
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    @TundraTex or anyone else "in the know"; I have recently decided to upgrade my head unit to an Alpine ILX-F309 from the stock nav head unit.......Will the FRAC operate with the new head unit? Or will I have to find alternative ways to wire the front camera? Thanks in advance for any help
  29. Mar 31, 2021 at 1:56 PM
    #1559
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I’ll have to research that specific HU to give a final answer, but in general, as long as you are using plug and play adapters for an aftermarket unit, the FRAC will continue to function as designed.
  30. Mar 31, 2021 at 5:42 PM
    #1560
    shawn474
    MoCo, Maryland
    Ok thanks - I will give it a whirl and report back.
