2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Oct 8, 2020 at 6:52 AM
    #1501
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If it has not been claimed yet, may I have it?
    EDIT: Nevermind, I forgot that I have already ordered a camera. I should have checked BEFORE posting!
  2. Oct 8, 2020 at 2:33 PM
    #1502
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    I'd like it if it's available.
  3. Oct 9, 2020 at 7:02 AM
    #1503
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I'll PM you
  4. Oct 9, 2020 at 11:15 AM
    #1504
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I just ordered the frac harness; thanks to Lou for answering my questions. Now to order the camera....
    TundraTex[OP] and HulkSmurf14 like this.
  5. Oct 13, 2020 at 2:20 PM
    #1505
  6. Oct 13, 2020 at 5:45 PM
    #1506
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Received mine today! I won't get to install it until I get my fence repaired from Sally, but at least it's here!
  7. Oct 13, 2020 at 7:35 PM
    #1507
    t-rey1
    t-rey1 New Member
    Not sure if this was asked, but can you add a media player with this harness to play on the radio display?
  8. Oct 13, 2020 at 7:38 PM
    #1508
    fbingha
    fbingha New Member
    Bakersfield, CA
    No, but there are solutions for that depending on if you want to mirror your phone or play from a thumb drive.
    https://naviks.com/
    If you really are interested, email them, they are very helpful.
  9. Oct 13, 2020 at 9:46 PM
    #1509
    sludgepickle
    sludgepickle New Member
    San Diego
    2018 Silver SR5 DC 4x4
    Just submitted my order! The local TintWorld just did my windows, and they have great reviews. I had a good experience. They also do AV installs, and they said they'd charge me $175 to do this job. I also have a 20% off coupon from the window tinting job...so I'm looking at $140. Seems great to me! I'm semi-handy but scared of pulling apart the dash and don't like wiring! I'll show him the YouTube vid from Lou and let him have at it! Any other tips before I turn it over to them? (2018 DC w/bench)
    TundraTex[OP] likes this.
  10. Oct 14, 2020 at 3:11 AM
    #1510
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @sludgepickle be sure to look at the attachments you'll get with your shipping notice e-mail. I provide a one-page quick install guide and a 6-page detailed installation manual. They provide all the information required for an easy install.
    sludgepickle[QUOTED] likes this.
  11. Oct 17, 2020 at 8:18 PM
    #1511
    shawn474
    MoCo, Maryland
    Just got the frac harness from Lou - incredible customer service and quality product. I got through most of the install tonight but need to finish tomorrow. Can anyone help me with the following questions as it relates to the connections?
    1. The Nakita camera I received seems to be nice quality. I am using this for a front camera so I assume I will cut the white wire loop, as it says in the instructions. Just making sure before I cut anything.
    2. I have connected both trigger wires to the frac harness. I still need to get a ring terminal for the ground. However, I am confused as to where I connect the power wire (says reverse lamp) on the backyard instructions. Do I have to connect this wire or is this accomplished by the frac harness?
    I am including the instructions from the camera hoping that someone can help answer. I just don’t want to fry any electronics or screw up cutting something I shouldn’t. Thanks is advance.
  12. Oct 18, 2020 at 4:42 AM
    #1512
    shawn474
    MoCo, Maryland
    Never mind, I am dumb. It plainly states on Lou’s instructions to terminate and insulate and the red power wire for reverse lamps. That’s accomplished from his harness.
    I will cut the white wire loop and finish installing the switches today.
  13. Oct 18, 2020 at 7:07 AM
    #1513
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    A couple things. The white wire is normally cut for front view, but I like to leave it intact until everything is connected and tested. I’ve heard a few cases where the wire’s function was reversed, so I’d cut it after confirming everything is working and it needs to be cut.
    For the camera connections, all the cameras have some variation In their wiring, but fundamentally you want the red FRAC power wire to provide power to the camera. So for this camera I would connect the FRAC Red power wire to the “B” red trigger wire. Then connect the “D” red wire to the “C” red wire. Then as you said, terminate the red wire in the red/black pair and connect the black to chassis ground.
  14. Oct 18, 2020 at 7:50 AM
    #1514
    shawn474
    MoCo, Maryland
    I cut the white wire and all works great. Thanks Lou.
    But my dumb ass took the grill off, measured exact center and mounted the camera.......which just so happens to be right in front of the pre collision sensor. So I took it off and moved it down below the sensor and all is good now.
    All in all, Lou’s harness is worth every penny, very high quality and easy to install (when you pay attention)! Thanks Lou
    HulkSmurf14 and TundraTex[OP] like this.
  15. Oct 19, 2020 at 10:59 AM
    #1515
    sludgepickle
    San Diego
    Front Camera location: 2018 honeycomb grill - obvious choice seems like right below the Toyota "T" badge. 2nd choice maybe between the gap in the black plastic of the bumper cover. Thoughts on both spots? I think I'll put it right below the T badge, but later if I put a light bar in, that spot seems prime for a bar, so I may move the camera down to the black bumper cover gap...
  16. Oct 19, 2020 at 2:50 PM
    #1516
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I like the spot right below the emblem. Keeps the camera high enough to see the ground closer to the front bumper. The lower you mount it, the more the bumper can block the view.
    ElNopal and sludgepickle[QUOTED] like this.
  17. Oct 20, 2020 at 6:47 AM
    #1517
    shawn474
    MoCo, Maryland
    8FBF37D7-94D2-4824-B7E8-F3EDAC447CAC.jpg I installed the switches for the front camera last night after work. They’re out of sight and are functional. I had to notch the plastic cross member behind the trim panel to allow for the spade connectors to recess far enough to snap the trim back in but was easy and painless. Attaching a picture to show the finished product
    Tundra805 and TundraTex[OP] like this.
  18. Oct 20, 2020 at 10:08 AM
    #1518
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Awesome work. Nice clean installation. I really like that location for the switches.
  19. Oct 23, 2020 at 5:27 AM
    #1519
    Saab95v6
    Saab95v6 New Member
    I am ready to install my FRAC and the Natika [​IMG] , Ktemple do you or any one here know what size L bracket is been used here , So I can go to the box store ones and get the right size ,instead of making multiple trips when I have the dash apart . Thanks in advance .
  20. Oct 23, 2020 at 7:56 AM
    #1520
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Here is the idea I came up with.
    I used the following from Lowe’s to mount my camera for my honeycomb grille...
    2” mending braces
    3” mending braces
    misc. machine screws
    I used the two OEM mounting points for the pre-collision sensor to avoid drilling into the grille. This allows for rigidity and holds the camera securely. It has almost been a year and so far, so good. Hope this helps, best.
    dandrilla, jsquared22, Drootz and 7 others like this.
  21. Oct 23, 2020 at 8:53 AM
    #1521
    Saab95v6
    Saab95v6 New Member
    Thank You !!!
    ElNopal[QUOTED] likes this.
  22. Oct 23, 2020 at 8:55 AM
    #1522
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Saab95v6[QUOTED] likes this.
  23. Oct 23, 2020 at 12:31 PM
    #1523
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That looks great! I'm going to modify this idea to fit my 1794 grill. Unfortunately there is no way to perfectly center the camera in the grill, but I will only be offset by about 1 1/4" with where I plan to put it.
  24. Oct 23, 2020 at 1:40 PM
    #1524
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    When I first mounted my front camera it was too high. I purchased the license place camera and mounted it just above the plate.
  25. Nov 15, 2020 at 8:24 PM
    #1525
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @TundraTex - what is the timing on your camera switch? (And VIM switch too) I would like to add those to my install. I have to say that parking in the garage using the FRAC is much better than the hanging tennis ball!!
  26. Nov 15, 2020 at 8:39 PM
    #1526
    French Avocado
    Utah / Wyo
    @Saab95v6 - Sorry I am slow. If you have not yet installed your camera then you can look at post #1446 which shows that I used 1" x 1" aluminum angle 1" long (as Lou suggests) then trimmed the plastic on the grill and used 3M VHB to mount it. Not as sturdy as the master @ElNopal 's solution but works very well.
    ElNopal likes this.
  27. Nov 16, 2020 at 7:27 AM
    #1527
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Sadly, the manufacturer seems unable or unwilling to produce a switch that meets my spec and quality standards. Not to mention maintaining a promised schedule. I’m back to the drawing board on this. It’s extremely frustrating dealing with these companies sometimes.
  28. Nov 16, 2020 at 8:01 AM
    #1528
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Gracias, Steve for the compliments. :hattip:
  29. Nov 16, 2020 at 8:12 AM
    #1529
    ElNopal likes this.
  30. Nov 16, 2020 at 9:11 AM
    #1530
    French Avocado
    Utah / Wyo
    Thanks for the update Lou. We appreciate your quality. I will have to watch Christmas Vacation instead!
    TundraTex[QUOTED][OP] likes this.
