2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Oct 1, 2020 at 5:14 PM
    #1471
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    That is the case for me, and yes I am.
    rockmup likes this.
  2. Oct 1, 2020 at 5:20 PM
    #1472
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Using the FRAC you can hook up a mini DVR. You may want to send Lou an email and ask him about your issue. Or, if you want to PM me with your address then I will send you an extra camera that I have.
  3. Oct 1, 2020 at 5:25 PM
    #1473
    runCMD
    runCMD BAMF Nerd
    That's very kind of you. Lou and I just chatted, super nice guy. I tried wiring green to ground as well with no change. Seems like it's only 12V that does anything but not sure why it would flip top bottom instead of left right. I will shoot an email to the camera folks. I have a #30 camera on the way from Amazon that I am going to give a try as well. Will probably connect first by running the wires outside of the truck :).
  4. Oct 1, 2020 at 5:35 PM
    #1474
    French Avocado
    Utah / Wyo
    Best of luck to you.
  5. Oct 2, 2020 at 10:04 AM
    #1475
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Deleted irrelavant post. ;)
  6. Oct 2, 2020 at 10:08 AM
    #1476
    runCMD
    runCMD BAMF Nerd
    doesn’t seem like you’re using the FRAC harness?
  7. Oct 2, 2020 at 10:22 AM
    #1477
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    edit to add... I got it figured out...
    https://youtu.be/UwPnCBQohHo
  8. Oct 2, 2020 at 10:07 PM
    #1478
    runCMD
    runCMD BAMF Nerd
    Had to put my truck back together because I have to use it tomorrow morning. Not looking forward to taking all my trim off and routing more wires Sunday :(
    Beesta likes this.
  9. Oct 3, 2020 at 1:46 PM
    #1479
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I have the OEM rear camera. With these front camera solutions, are there any that require going any further back than the cab of the truck? I have the locking tailgate kit on the way and want to make sure I only run wires under the truck one time.
  10. Oct 3, 2020 at 2:52 PM
    #1480
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I am not aware of any that would require wiring past the cab.
    Beesta likes this.
  11. Oct 3, 2020 at 4:13 PM
    #1481
    runCMD
    runCMD BAMF Nerd
    definitely worth watching his install video through in its entirety before you tackle it.
    Beesta likes this.
  12. Oct 3, 2020 at 6:58 PM
    #1482
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I've watched a few already, but this FRAC mod is going to be later this year, maybe a Christmas present??? We're looking for property to build on so I'm not spending a whole lot on mods right now. My list is growing though! The tailgate lock is kind of an anniversary present from my wife. As I stated previously, I just don't want to have to run wires through the underside of the bed more than once.
  13. Oct 3, 2020 at 9:53 PM
    #1483
    French Avocado
    Utah / Wyo
    FRAC only runs from engine compartment through firewall (toughest part) and into dash. It does not run to the rear. Tailgate lock has completely separate run. If you are going to add light bars to the front grill then you may want to run those wires at the same time as the FRAC wires.
    Beesta and ElNopal like this.
  14. Oct 4, 2020 at 11:47 AM
    #1484
    fbingha
    fbingha New Member
    Bakersfield, CA
    What functionality does FRAC offer over the Anytime Backup Camera kit?
  15. Oct 4, 2020 at 12:24 PM
    #1485
    Description is in 1st post but its the same thing.
  16. Oct 4, 2020 at 12:43 PM
    #1486
    French Avocado
    Utah / Wyo
    With FRAC you get excellent customer service from Lou aka Tundra Tex!
    NoKenDo likes this.
  17. Oct 4, 2020 at 12:52 PM
    #1487
    fbingha
    fbingha New Member
    Bakersfield, CA
    Yeah, I know, but I still would like to know if there are any functional difference between the two. The Anytime Backup kit appears to come with the camera and that nifty switch for about the same price. Nothing wrong with the question. Maybe it's that with the FRAC you can disable vehicle motion for the factory nav, which doesn't apply to me as I used Car Play maps, 2020.
  18. Oct 4, 2020 at 12:58 PM
    #1488
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Lou is currently working on a more OEM looking style switch. However, I understand that that is still a little ways out. I have heard that other members have installed the FRAC with the AnyTime OEM style switch...
    French Avocado and Beesta like this.
  19. Oct 4, 2020 at 1:12 PM
    #1489
    runCMD
    runCMD BAMF Nerd
    I wanted to support Lou so bought the FRAC harness and separately the anytime backup camera switch and their camera. Having problems with their camera that they acknowledged was from a known bad batch. Still waiting on a resolution from them as the code they gave to me replace it doesn’t work.
    EDIT to add: Lou gave me great support on the phone when I was troubleshooting the camera problem, even though it wasn’t an issue with his hardware.
    French Avocado likes this.
  20. Oct 4, 2020 at 1:30 PM
    #1490
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Yeah not too fond of the switch .... i didn’t even bother hooking up the illumination part of it ... not liking how its amber and i have no amber lights on my dash switch.
  21. Oct 4, 2020 at 1:45 PM
    #1491
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Jay, I have found that the “amber” is eventually taken over by the “blue” with time. Maybe it is an “eye-thing” or simply getting used to it but I would highly suggest connecting the illumination wires from one of the neighbor switches (ie; the VSC) to see if your opinion changes.
    I used posi-taps as to not blemish the factory wires too much and ran them to the camera and other switches in the NSV Panel. This way your “blue light” will illuminate AND dim with the illumination circuit dimmer in the instrument cluster...
    IIRC, the camera switch blue wire goes to the pink off the VSC switch and the grey from the camera switch to the white on the VSC switch...
    77BDB80E-0766-4290-BC1D-E188554AC761.jpg 6191373B-C1A6-494B-A58E-5F29964E5FDB.jpg A3CF53E8-2600-4B7C-A68F-E89993E98943.jpg
  22. Oct 5, 2020 at 9:05 AM
    #1492
    runCMD
    runCMD BAMF Nerd
    Another reason to just go through Lou for the support. The FRAC is working great and Lou called me from the AIRPORT while he was travelling.
    The camera I bought from Anytime is defective - when I submitted a contact form on their website I got no reply. I emailed direct and was then provided a code to use to get a camera to replace the original. At first they were out of stock; then they changed the listing and there was some available, but the code didn't work; now it works but they still want to charge shipping. I've emailed several times along these iterations and gotten no reply so I am just disputing the cost of the camera on my CC charge. I have no doubt the sapphire preffered card will uphold it, they've already credited me the money.
    Just want to re-iterate that @TundraTex 's product and support were great and this is an endorsement to go through him instead of the other options :)
    EDIT to update: ABC got real communicative once I did the dispute. Did the refund and shipped me out a replacement camera.
  23. Oct 5, 2020 at 9:13 AM
    #1493
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    Wired up and installed the FRAC this weekend on the 1794. Put the camera through one of the open winch mount slots on the bottom of my ADD Stealthfighter Everything went very smoothly, absolutely zero issues. Thanks Lou!
  24. Oct 5, 2020 at 9:33 AM
    #1494
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Hey guys. I was off the grid this past weekend (Bow Season for Whitetails) so I’m just now catching up on the posts. I appreciate the kind words and endorsements. My FRAC Harness business is a side gig, and I have a very full-time day job, but since I am accepting hard-earned money from my customers I feel obligated to provide the best product and customer service I can. It’s nice to know it’s recognized. Thanks again!
  25. Oct 5, 2020 at 9:44 AM
    #1495
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I don’t know all the features of the other product, but I believe the FRAC Harness is the easiest plug and play design to install. That is subjective opinion, but many customers and installers have told me the same thing. Another feature of the FRAC harness that some others don’t have is to automatically override the front cam whenever you shift into reverse. This maintains OEM functionality without having to deselect the front cam manually. Then as you mentioned, I include the VIM feature that others charge additional money for. And finally, I treat my customers like I want to be treated. Hope this answers your question.
    Tundra805, TOYOTARIG, NoKenDo and 2 others like this.
  26. Oct 5, 2020 at 9:45 AM
    #1496
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You’re welcome! Thanks for the report.
  27. Oct 5, 2020 at 7:27 PM
    #1497
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  28. Oct 8, 2020 at 5:18 AM
    #1498
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Just realized I hadn't update the thread title to reflect compatibility with the 2021 vehicles. That's now been updated. The 2021 models are using the same Head Unit wiring as the 2020 models.
    Tchase likes this.
  29. Oct 8, 2020 at 5:45 AM
    #1499
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Ill check this out Matt ... just finished my Bed lights yesterday and got few more mods before i head back out ... thanks buddy
    ElNopal[QUOTED] likes this.
  30. Oct 8, 2020 at 6:46 AM
    #1500
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I have the FRAC harness and love it.
    I also have this camera that I'm not using:
    https://www.amazon.com/gp/product/B06XNM7GNS/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    I'll give it to anyone who wants it. Just let me know.
    It is brand new. I hooked it up to make sure it works, but went with the one that mounts in the emblem. I changed to a 2018+ grille and thought I would need this, but rather than figure out mounting, I just drilled a hole in the emblem and mounted my old camera there. In the meantime I let my return window expire.
