2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. May 15, 2020 at 10:24 PM
    #1321
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    The camera is straight on. It is off center by 3 inches, which I can live with. The rear camera is not on exact center either.
    cheers.
  2. May 17, 2020 at 5:03 PM
    #1322
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    how did you secure it? I am trying to follow what you did since I have the limited grill
  3. May 17, 2020 at 5:42 PM
    #1323
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  4. May 17, 2020 at 6:37 PM
    #1324
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Would you please post a picture of the underside with the switches mounted? Thanks.
  5. May 17, 2020 at 7:09 PM
    #1325
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice job. Clean installation!
  6. May 17, 2020 at 8:01 PM
    #1326
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  7. May 17, 2020 at 10:03 PM
    #1327
    WAtundra4x4
    Den
    Wet side WA
    I used the camera referenced in 1305 post of this thread. I used a steel 1/16inch thick L bracket to hold the camera via the mount threaded post. The L bracket was screwed into the plastic of the grill. Stainless sheet metal type screw so it would go into the black plastic V but not the long so it hit the chrome piece. It was held on there well, but decided to reinforce the screw with some Black Steel Epoxy. I basically filled in the V groove with the steel epoxy putty under the bracket and around the screw. It should help with any vibrations also. The steel epoxy is amazing, it will hold the threads of the screw if you have to remove it later.
    I used the camera in the 1305 post, as it was rated IP69 if I recall correctly. That’s a very good rating wrt being waterproof. Having designed test equipment for ultrasonic systems in the past, water splash and immersion can be treacherous for electrical hardware.
    TundraTex[OP] likes this.
  8. May 17, 2020 at 10:06 PM
    #1328
    WAtundra4x4
    Den
    Wet side WA
    see post #1. I used that method also. You have to solder the wires on as there is no room for connectors.
  9. May 18, 2020 at 6:57 AM
    #1329
    shhernandez74
    Samuel
    Thanks for the info! You wouldn't happen to have a picture of the results would you?
  10. May 18, 2020 at 9:00 AM
    #1330
    French Avocado
    Utah / Wyo
    @John175 Thanks. I like the pop rivet - makes for a very nice clean look. I see the pic in post #1 of the switches as well. This is the method I want to use on my 2020 when the harness becomes available.
  11. May 18, 2020 at 9:43 AM
    #1331
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I cut off about 10" of the supplied harness and soldered that to the switches. I then put male connectors I picked up at Lowes on the cut off end on the harness. That enables me to disconnect the entire panel if/when I make changes. (pardon my hot glue skills)
    The Red line is about 10" from my bumper.
    TundraTex[OP] and French Avocado like this.
  12. May 18, 2020 at 4:06 PM
    #1332
    WAtundra4x4
    Den
    Wet side WA
    I took a photo up close. It’s an L bracket that traverses two horizontal members. Keep the camera high to get just a little of the lower bar. I did some editing of the photo to contrast the Bracket. 37B481E9-6160-435A-B0B6-6E805E8EE476.jpg
    dandrilla and Beesta like this.
  13. May 19, 2020 at 2:25 PM
    #1333
    mountainpete
  14. May 19, 2020 at 3:36 PM
    #1334
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
  15. May 19, 2020 at 3:43 PM
    #1335
    mountainpete
    What camera did you use?
  16. May 19, 2020 at 3:52 PM
    #1336
    KERNEL_DALE
    Norcal
    19’TRD-PRO
  17. May 19, 2020 at 8:42 PM
    #1337
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    @TundraTex hey there the last couple days I’ve requested an invoice so I can order a harness. Am I doing something wrong?
    Thanks!
  18. May 22, 2020 at 6:17 AM
    #1338
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I’ve been offline for a couple days. Did you send an order through the website? If not, you can do so at www.FRACv2.com.
  19. May 22, 2020 at 6:18 AM
    #1339
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    We can only ship to U.S. states and territories.
  20. May 22, 2020 at 6:27 AM
    #1340
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I did both times, but my hotmail can be problematic. Want me to pm my email address?
  21. May 22, 2020 at 6:54 AM
    #1341
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Invoice is headed your way. Thanks for the order!
    Tchase[QUOTED] likes this.
  22. May 22, 2020 at 7:08 AM
    #1342
    Daxoto
    Daxoto New Member
    2020 PRO
    Any updates on a system for the 2020 Pro?
  23. May 22, 2020 at 7:09 AM
    #1343
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Paid thank you!
    TundraTex[QUOTED][OP] likes this.
  24. May 22, 2020 at 7:23 AM
    #1344
    mountainpete
    That’s really disappointing.
  25. May 22, 2020 at 7:25 AM
    #1345
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Any friends or family in the states?
  26. May 22, 2020 at 7:27 AM
    #1346
    mountainpete
    Not really. My work usually takes me to the USA a few times a year but 2020 is a new reality.
  27. May 22, 2020 at 7:32 AM
    #1347
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Fingers crossed, I'll get everything wrapped up this holiday weekend and get the proto-harness out to my local 2020 "Beta" installation tester! If that all works out, I should be able to get my production parts in and start taking orders in 2-3 weeks.
    831Tun likes this.
  28. May 22, 2020 at 4:20 PM
    #1348
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Hope @TundraTex doesn’t mind. If so, please advise and I will delete post.
    @mountainpete We purchased the FRAC harness a few months ago for our 2019 Tundra. We never got around to install it. We recently installed an Alpine Halo9 with front and rear cameras. We no longer need the FRAC harness. I can ship to you for the same listed price + HALF of standard shipping to you. I will pay the other half of shipping (assuming its not crazy $$$) and will throw in the camera that we bought it with. Let me know if interested. Below is the camera that we bought.
    Backup Camera Night Vision - HD Car Rear View Camera - Parking GuideLines ON Off - Wide View Angel - Waterproof Reverse Auto Back Up Car Backing Camera - High Definition - Fits All Vehicles https://www.amazon.com/dp/B07JL8DGNQ/ref=cm_sw_r_cp_api_i_h2fYEb0S02QXF
  29. May 23, 2020 at 6:55 AM
    #1349
    mountainpete
    Thanks Ray - if it will fit an 18 SR5 with non JBL navigation, I’m interested! Sending you a PM.
    rmvcard0303[QUOTED] likes this.
  30. May 23, 2020 at 9:59 AM
    #1350
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    It is compatible @mountainpete. Thanks for helping out, Ray.
    831Tun and mountainpete[QUOTED] like this.
