2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Oct 16, 2017 at 11:45 AM
    #661
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I just had to torn it off to treat it today :( damn my luck:laughing: so keep it on and installed
    joonbug[QUOTED] likes this.
  2. Oct 16, 2017 at 11:46 AM
    #662
    Oscar2
    Oscar2 New Member
    Oscar
    San Diego
    2017 Tundra Crewmax SR5 5.7L 2WD Barcelona Red
    My understanding is that the GPS info is always used to maintain position. But in addition the vehicle uses its own motion sensors in the wheels to supplement the GPS. So for example, the GPS readings alone would not give a very accurate speed indication when you are just crawling along at a few miles an hour. The GPS readings have a fairly high uncertainty measured in feet or even tens of feet (hundreds of feet in some cases). But supplemented with the internal wheel motion data, such speed readings can be very accurate and not bouncing around
  3. Oct 16, 2017 at 1:16 PM
    #663
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    In summary, The VIM switch should be kept in the 1 or "on" position for normal operation. Turning it "off" or to the 0 position allows access to functions normally locked out while in motion. Once the desired input is completed, VIM should be switched back to the "on" position to resume normal operation.
    If you're interested in a bit more Geek-Speak as to the how and why, then read on.... but remember you had the chance to stop reading here!
    The VIM signal is a pulsed signal that increases in frequency proportionally to wheel RPM. This is combined with 2-axis accelerometer data and a vector solution of speed is calculated. VIM pulse counts are measured over time and heavily influence precise vehicle position updates on the moving map, even with accelerations and decelerations. If VIM is pulsing, regardless of the frequency, then the vehicle is assumed to be in motion and certain features in the HU are disabled; Nav destination, phone pad, setup menus, etc.
    So when the VIM switch is turned to the 0 or "off" position, it turns off the VIM signal to the HU. The HU sees no VIM pulses and thinks that the vehicle is stopped. It also has no speed data to augment the Nav solution.
    This activates "grayed out" functions and it also tells the GPS to quit moving the map vehicle icon. Even though the GPS is still internally calculating the updated position, and the accelerometers are still operational, they are essentially out-voted by the absence of a VIM signal, so map position updates stop. (Google "Kalman Filters" if you're interested in even more nitty gritty).
    When VIM is left in the off position the GPS will update locations occasionally, but it won't be timely or smooth. At least that's my experience.
    Once you turn VIM on again, the pulse signals will return, the Kalman Filter will be happy, and the GPS moving map function will catch up and resume proper tracking.
    Some folks have reported that the moving map continues to work without a VIM signal. That is definitely not my experience and is the reason I recommend that VIM be left on most of the time.
    BlueBottle, tomsinamerica and joonbug like this.
  4. Oct 16, 2017 at 1:39 PM
    #664
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Exactly what I was asking. Thanks for the answer Lou.
  5. Oct 17, 2017 at 11:12 AM
    #665
    Blackdeathtundra
    Blackdeathtundra New Member
    San Antonio, Texas
    2015 TRD Supercharged 1794 edition lifted on 35s
    TRD Supercharger Stage 2 hybrid lift 35” Nitto Ridge Grapplers TRD cat back dual exhaust 5% tint all around Tinted tails & 3rd brake Full LED conversion in & out ICI Magnum front bumper Lock’r Down console vault Spray in bedliner Extang Solid Fold 2.0 Amp Research Powerboards Hadley train horns DAP tune
    Email sent!
    Cfincke and 4x4_Angel like this.
  6. Oct 24, 2017 at 1:57 PM
    #666
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    For those of you who mounted the front camera on the emblem in the grill of your Tundra, how did you run the RCA cable to the passenger side of the firewall? Did you just run it under the hood to the back near the hinge? Pictures? Thanks!
  7. Oct 24, 2017 at 2:31 PM
    #667
    4x4_Angel
    Bree
    Funky Town, Texas
    I'll take pics for ya in a sec!
  8. Oct 24, 2017 at 2:42 PM
    #668
    4x4_Angel
    Bree
    Funky Town, Texas
    so i ran it on the back side of the grill then through here20171024_163339.jpg
    then along the side
    to the firewall....into the bottom "nipple"
    need more info?
  9. Oct 24, 2017 at 8:08 PM
    #669
    Riskyguy
    Riskyguy New Member
    Stewart
    Is your grill a part of the hood? Mine is.
  10. Oct 24, 2017 at 8:38 PM
    #670
    4x4_Angel
    Bree
    Funky Town, Texas
    No...sorry i should have paid a bit more attention to your truck:)....in that case i would run it on the edge of your hood (ie not going across the engine block) along the hingeand down. definitely make sure there is plenty of slack so you don't top them apart.:thumbsup:
    Sunnier likes this.
  11. Oct 24, 2017 at 9:21 PM
    #671
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I finally got my frac harness installed. It works great now I just need more play time. Lol
    4x4_Angel likes this.
  12. Oct 24, 2017 at 9:45 PM
    #672
    4x4_Angel
    Bree
    Funky Town, Texas
    i mess with my kids while driving. they both can see the screen so I'll flip the camera on (front or back) and it freaks them out
  13. Oct 24, 2017 at 9:50 PM
    #673
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I have only driven it through the neighborhood to play with it so far. I need to borrow a couple small kids to scare with it Lol
    Sunnier and 4x4_Angel[QUOTED] like this.
  14. Oct 24, 2017 at 10:19 PM
    #674
    Sunnier
    Sunny
    San Diego, CA
    Hey, Bree, did I miss you posting pics of your installation, start to finish. I know you mentioned you planned to, when you first completed the mod. If, can you please drop me the link?
  15. Oct 25, 2017 at 2:14 AM
    #675
    4x4_Angel
    Bree
    Funky Town, Texas
    haven't yet....i will let you know when i do though
    Sunnier[QUOTED] likes this.
  16. Oct 25, 2017 at 2:23 AM
    #676
    Sunnier
    Sunny
    San Diego, CA
    Cool, thanks!
  17. Oct 25, 2017 at 2:34 AM
    #677
    4x4_Angel
    Bree
    Funky Town, Texas
    no problem
    Cfincke and Sunnier[QUOTED] like this.
  18. Oct 26, 2017 at 8:23 PM
    #678
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
  19. Oct 26, 2017 at 9:10 PM
    #679
    rhopf79
    rhopf79 New Member
    2017 Tundra Double Cab Limited
    Great video...wish it was out when I installed mine. Would of saved me hours. Love the FRAC harness.
  20. Oct 26, 2017 at 9:35 PM
    #680
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Well I’m glad you were able to figure it out even though I got the video finished later than planned.
  21. Nov 3, 2017 at 1:55 PM
    #681
    gw42
    gw42 New Member
    2014 CrewMax SR5
    Got my kit. Took about 30 mins to install, 15 of which was figuring out how to take the head unit out. Everything works perfectly, thanks Tex!
  22. Nov 4, 2017 at 11:05 AM
    #682
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Excellent! Glad to hear the Plug and Play worked so well.
  23. Nov 14, 2017 at 12:59 PM
    #683
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    Curious so does this effect the automatic reverse camera that pops up when reversing? Or does this make it all manual now
  24. Nov 14, 2017 at 1:23 PM
    #684
    4x4_Angel
    Bree
    Funky Town, Texas
    nope....doesnt effect it. but you can still manually turn it on with the switch if you want
  25. Nov 15, 2017 at 11:13 AM
    #685
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Shifting into reverse always brings up the rear camera view. Even if you have the Front camera selected, the rear cam will override it in Reverse.
  26. Nov 18, 2017 at 7:32 PM
    #686
    delta6b
    delta6b New Member
    2016 limited TRD 4x4
    Backflip Tonneau Cover Bilstein 5160/6112 Fuel Maverick 20x9 +20 Offset Toyo Open Country RT 305x55 R20 Pop & Lock Tailgate Lock Husky X-Act Contour Mats TRD 4x4 Off Road replacement Husky Logo Center Console Safe AJT Design Key Fob ESP Rear Seat Storage FRAC V2 Oh Shit Handle
    Awesome! Email sent!
  27. Nov 18, 2017 at 8:19 PM
    #687
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    30 min. .. damn! I was in my shop for about 4 hours! Lol
    TundraTex[OP] likes this.
  28. Nov 18, 2017 at 8:57 PM
    #688
    4x4_Angel
    Bree
    Funky Town, Texas
    Lol....mine took a couple of hours, but that is also because it was being video taped and pics were taken...
  29. Nov 30, 2017 at 10:55 PM
    #689
    rhopf79
    rhopf79 New Member
    Anyone know a good option for a front camera on a 2018?
    jaredmillerdvm likes this.
  30. Dec 1, 2017 at 4:37 AM
    #690
    4x4_Angel
    Bree
    Funky Town, Texas
    You have the toyota emblem right?
