2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Jul 23, 2020 at 1:36 PM
    #1441
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    In my limited with the Nav bar I had no place to go. On this thread this post is a pic I like the location easy to get to
    2014-2020 Front/Rear Anytime Camera - FRAC Harness
  2. Jul 24, 2020 at 3:12 PM
    #1442
    house
    house I blame you guys for my mod spending
    2019 MGM CM Limited 4x4
    Anyone know how to wire this switch up? Got it today and figured one of you had already figured this out. Thanks!
    Beesta likes this.
  3. Jul 24, 2020 at 3:59 PM
    #1443
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
  4. Jul 24, 2020 at 5:11 PM
    #1444
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    What @KERNEL_DALE said. And don’t forget to clip the diode out of the back side of the switch.
  5. Jul 25, 2020 at 6:38 AM
    #1445
    house
    KERNEL_DALE[QUOTED] likes this.
  6. Jul 26, 2020 at 4:42 PM
    #1446
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I posted this with other stuff on the What have you done thread but thought I would add the FRAC portion here.
    Project 4 - While I had the grill off the truck, I added the front camera and will later get the FRAC harness done. Following great advice from @InTheRough I used 1" aluminum angle and created a hanger for the camera on the grill install.
    Adhered to grill with 3M VHB after shaving down lip as recommended by @InTheRough.
    I wrapped the excess wire up behind the TSS and left the coupling for the camera at the same point as the coupling for the TSS in order to permit later separation of the grill. (By the way - the TSS coupling wire is a tight fit.)
    Final outcome is that the camera is not very noticeable.
    Now I need to find time to finish the FRAC install and wash it so I can start driving it.
    InTheRough likes this.
  7. Jul 27, 2020 at 12:58 PM
    #1447
    rareskills
    rareskills New Member
    2020 Tundra Platinum
  8. Jul 27, 2020 at 9:32 PM
    #1448
    French Avocado
    Utah / Wyo
    @rareskills - it is the one listed. (Lou must be on the back porch. He will make certain to send you the correct version.
    rareskills[QUOTED] likes this.
  9. Jul 28, 2020 at 3:57 AM
    #1449
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @rareskills Yes, just select 2020 as your year model and you'll get the FRAC v3 harness.
    rareskills likes this.
  10. Jul 28, 2020 at 6:26 PM
    #1450
    rareskills
    Does anyone know if I use this will it retain the backup camera triggering when I put in reverse, or is it solely toggle? Is it the same if it is an aftermarket stereo like Halo9/8600NEX?
    Beesta likes this.
  11. Jul 28, 2020 at 6:36 PM
    #1451
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    I've found that putting the truck in reverse overrides any switch selected.
    Tchase likes this.
  12. Jul 28, 2020 at 9:00 PM
    #1452
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I designed the FRAC Harness to maintain OEM Functionality, so if you shift into reverse you will always get the rear camera video, regardless of the camera select position. When you shift out of reverse the display will go back to whatever was being displayed before.
    The FRAC Harness will work with aftermarket head units that use plug and play harness adapters to connect to the truck's OEM harnesses.
    bulldog93 and HulkSmurf14 like this.
  13. Jul 31, 2020 at 4:52 PM
    #1453
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Changed out the grill, put on a different camera and made this fixture.
    From a distance you can't tell it is there...
    I know, truck needs washing!
    Beesta, HulkSmurf14 and TundraTex[OP] like this.
  14. Aug 4, 2020 at 7:10 PM
    #1454
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Has anyone found an aftermarket up grade for the rear camera, without having to do major mod?
  15. Aug 23, 2020 at 1:22 PM
    #1455
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
  16. Aug 23, 2020 at 1:28 PM
    #1456
    Beesta
    Beesta New Member
    Jay
    Loudoun County
  17. Sep 20, 2020 at 7:05 PM
    #1457
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    Forgive my laziness, is there an updated recommendation for a camera to use up front?
  18. Sep 20, 2020 at 7:34 PM
    #1458
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    I use anytime backup cam ..
    runCMD[QUOTED] likes this.
  19. Sep 20, 2020 at 9:26 PM
    #1459
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    It’s probably been asked multiple times but how can one eliminate the lines that show visually when putting the truck in reverse?
  20. Sep 20, 2020 at 10:54 PM
    #1460
    French Avocado
    Utah / Wyo
    Natika makes a good camera. They have different styles that come and go on Amazon. I have this one but in black - https://www.amazon.com/Backup-Rear-...atika+front+view+camera&qid=1600667455&sr=8-4.
    Make certain that it can be used as a front camera.
  21. Sep 21, 2020 at 2:43 AM
    #1461
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    I dont think you can since that is in the factory settings
  22. Sep 21, 2020 at 9:21 AM
    #1462
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Rear is set with lines (if still using OEM backup camera) but there should be a line/wire you don't connect for front camera to not show them...
  23. Sep 23, 2020 at 10:35 AM
    #1463
    me_rikey
    me_rikey New Member
    Jake
    Forgive me if I'm missing something here that's blatantly obvious. I've tried searching to no avail, and I'm wondering what's needed to use the FRAC harness on a 2011 Tundra if I am replacing the factory base stereo to an aftermarket such as Alpine/ Kenwood/ Pioneer? Perhaps it won't be necessary if the h/u has RCAs for front and rear cameras, but the VIM bypass would be awesome.
    Thanks!
  24. Sep 23, 2020 at 10:49 PM
    #1464
    French Avocado
    Utah / Wyo
    You would have to ask Lou @TundraTex. I do not think it is compatible with third party units but I have no idea.
  25. Sep 24, 2020 at 5:57 AM
    #1465
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness works with aftermarket Head Units in 3rd Gen trucks as long as a Plug and Play adapter harness is used. The 2nd gen trucks are wired differently.
  26. Oct 1, 2020 at 3:34 PM
    #1466
    runCMD
    runCMD BAMF Nerd
    Well I just finished wiring everything up. After some cursing because I tore the extension cable to my camera trying to get it through the firewall, I ended up fixing by soldering it back together. I am using the Anytime backup camera switch and camera.
    Unfortunately, when viewing the front, it is mirrored. When I apply 12V to the green wire on the camera, instead of mirroring, it flips upside down. Am I SOL here, is this just a bad camera?
  27. Oct 1, 2020 at 4:20 PM
    #1467
    French Avocado
    Utah / Wyo
  28. Oct 1, 2020 at 4:29 PM
    #1468
    runCMD
    runCMD BAMF Nerd
    Looks like a misquote above but yes I’m aware of the loop wire. That’s the green one. I’m assuming when using the extension plug it just combines it to the 12v rail. When I hook 12v up to it, it mirrors top/bottom instead of left/right. Perhaps it hooks to video signal instead? I can try that when I hook my battery back up. Also hardwiring in a dash cam at the moment.
  29. Oct 1, 2020 at 4:47 PM
    #1469
    runCMD
    runCMD BAMF Nerd
    Just confirmed tying the green wire to the yellow signal wire does nothing. Ugh.
  30. Oct 1, 2020 at 4:58 PM
    #1470
    French Avocado
    Utah / Wyo
    I believe the green loop should be cut and not connected to anything. Are you using the FRAC harness?
    HulkSmurf14 likes this.
