2014-2018 Toyota Tundra Hood Grille Knight Rider NSV LED Light Bar Kit - Multi Function!
Discussion in 'Lighting' started by Headlight Revolution, Aug 30, 2018.
  1. Feb 5, 2019 at 2:01 PM
    #61
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    That is exactly where I am as well. I was going to order this late last week until I read about how it impacted the base functionality of the OEM lighting system. Super bummed but such is life.
    4077th[QUOTED] likes this.
  2. Feb 5, 2019 at 2:22 PM
    #62
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    @Headlight Revolution is there a video detailing how this light bar will operate when used in conjunction with an spod or switchpros system? Does use of either bypass the steering column wiring therefore open the unit up to be used as some on here are wishing it could be? It would seem that switching off of the spod or switch pros vs. the factory headlight would eliminate the problem of DRL and “safety” feature of having to engage the high beams to use the light bar.
  3. Feb 6, 2019 at 10:07 AM
    #63
    Headlight Revolution [OP] New Member Vendor
    Atlanta, GA
    There are no videos I can find on the installation, but there are plenty of Tundra owners who have done it so I know it can be done. And for sure, I am sure there is a way to wire it so it does bypass that High beam Saftey feature, it would just need to be wired directly.
    4077th likes this.
  4. Feb 6, 2019 at 10:12 AM
    #64
    4077th
    4077th New Member
    2018 Tundra SR5
    Thanks for the update. You are right, lots of good threads out there to make it how you want it. I am going for it.
    Thanks for all the responses!!
  5. Feb 6, 2019 at 10:23 AM
    #65
    Atlanta, GA
    Of course, If you are going Commando on the Switch-Pros install, let me know! It would be a cool idea to even start a thread on here to refer to for others, and for assistance. :)
  6. Feb 6, 2019 at 8:17 PM
    #66
    AtabeyK
    AtabeyK New Member
    hey guys.
    I've had the light bar for almost 2 years now. and let me tell you, it has been AWESOME!! the DRL's on the light bar are so bright, I can't believed I've driven without these in the past. I have HID 8000K headlights and fogs. and the DRL's from the light bar still add another world of lighting.
    my only issue here is that after about a year, I had an issue with the light bar getting water inside. moisture. talked to HR. sent them pictures as they requested. they had me send back the light bar to them at MY OWN EXPENSE, and then they would send me a new one asap. after about a week, no response, no light. I called. someone said they'd call me back, never did. called again. said they are shipping I should see it next week. another week later, still nothing. called again, they said someone messed up, and they are sending asap. finally I got a whole new kit at no cost!. I only needed the light bar, and was told I was going to get only the light bar, and got a whole kit so I have the extra parts now. Anyways, the story doesn't end....
    I installed the new light bar. and now my DRL's on the light bar do not work.
    also, when I used to pull back on my high beams, to flash my high beams, the light bar used to come on FULL. now they don't, it only comes on full when I push my high beams forward, to leave them in there, not able to flash them by just pulling back and letting go on the light stick.
    I called HR and I can't even get anyone on the phone. I emailed. they came back and said make sure all my pin connectors are good, not loose, and connected. not corroded. I checked all of them, and they are all good. connected. not loose. and all connected. not bent. still same issue, nothing changed.
    I have been trying to call them for a week now, to get an answer as to what to check next, and nothing! I waited on hold on Monday, 2/4 for 48 minutes!!! it was ridiculous.
    I honestly think HR, needs to work on answering their phones, and customer service to keep current customers HAPPY, before trying to sell more and more products just to leave customers like they left me in the dark. just my 2 cents.
    I hope HR see's this comment and actually finally helps me out...that would be great...but one can only hope....
    good luck everyone, and i'll keep everyone updated if they do or not.
  7. Feb 7, 2019 at 6:21 AM
    #67
    Atlanta, GA
    I sincerely apologize about the delays and lack of communication on our end, 400+ phone calls & 500+ Emails to get to per day between 9 Salesman makes it very tough to keep up with everything! Please check your PMs! This is the first I have heard of this situation, I would love to help where I can!
  8. Feb 7, 2019 at 6:45 AM
    #68
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Very similar if not same in regards to calling HR. If they are that busy, and cannot adequately respond to or answer their phones, they should just say so, and state - the best way to contact us is via email.
    Awaiting one more item from them to arrive today, and if it does not perform, or perform as advertised, I'm done with them. Spent/wasted too much $ on their stuff to continue getting the same results and responses.
    YMMV.
  9. Feb 7, 2019 at 7:12 AM
    #69
    Atlanta, GA
    Our main funnel is Phone calls and Emails, this is why replies are slow is because that is where our heaviest communications traffic comes from, whereas here is slow, so I can get back to you usually within the hour of reaching out. I apologize for the poor experiences you have had thus far, If you have any questions for me or wish to chat, I am just a PM away! Once more, I am sorry for any issues or inconveniences you have had in the past, hopefully we can make things right for a brighter future.
  10. Feb 11, 2019 at 3:07 PM
    #70
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    @Headlight Revolution Installed my bar yesterday and everything seemed good. The only issue I encountered today was that when I use my blinker both DRLs flash. I’m driving an ‘18 CM Sport. Any idea how to fix that?
  11. Feb 12, 2019 at 11:14 AM
    #71
    BlackdOutTundra
    BlackdOutTundra New Member
    2019 Black Tundra Limited TRD
    Any chance you can assist me? I ordered the light bar and got everything installed then noticed the “swipe” switch is sticking when you push it in. It then gets stuck completely in and will not release and has to be prayed out. Like the spring is stuck or something. I just need a new swipe button. Emailed and tried calling a few times but after 15 mins on hold it kicks you off the phone.
  12. Feb 12, 2019 at 4:59 PM
    #72
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    @Headlight Revolution This is why I’m not buying your product! For a grand, you should be giving him the VIP treatment.
  13. Feb 13, 2019 at 10:49 AM
    #73
    Atlanta, GA
    Can you check your PMs for me, my man? I apologize, I was out since Monday for Family reasons but I am more than happy to make this right for you! I dearly apologize for the delays and poor service, Sir.
  14. Feb 15, 2019 at 2:55 AM
    #74
    Blackrr
    Blackrr New Member
    2016 Inferno SR5 TRD
    What the!? likes this.
  15. Mar 1, 2019 at 8:57 AM
    #75
    Atlanta, GA
    NSVs currently out of stock, but we will have plenty more in just under 3 weeks! PM me and let's talk! Free 2nd Day Air shipping on all orders! :)
  16. Mar 3, 2019 at 10:12 PM
    #76
    FDC7
    FDC7 New Member
    2016 TRD PRO
    Can’t believe I missed both the epic group buy with bonuses and Black Friday deal! Any possibility of another group buy in the future??
  17. Sep 12, 2019 at 7:52 AM
    #77
    Atlanta, GA
    Bumping this thread, does anyone have any questions about this bad boy Light bar? :) Install Qs, General Spec Qs, Etc? Let me know!
  18. Sep 12, 2019 at 8:12 AM
    #78
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    How much does it cost
  19. Sep 12, 2019 at 8:15 AM
    #79
    When's next group buy or sale of this NSV light bar?
  20. Sep 12, 2019 at 8:44 AM
    #80
    Atlanta, GA
    Cost on these guys are $998 Shipped. There is an additional USB port option for an additional $55 for the interior panel that is SO useful! With that option, you are looking at $1,053 Shipped!
  21. Sep 12, 2019 at 8:45 AM
    #81
    Atlanta, GA
    I am not sure to be honest! There isn't any in the near future, I will see what can be done though!
    ShooterReady likes this.
  22. Sep 12, 2019 at 9:09 AM
    #82
    Mrpgfernandez
    Mrpgfernandez New Member
    Pristine
    2018 Tundra Crewmax
    Hi there. I have a 2018 tundra. I purchased the NSV light bar from Head light Revolution. It came in yesterday. I installed the light bar but the hood bulge in the corners isn’t going in all the way. It’s not as aligned as if it didn’t have the bar inside it. I’m worried that water might get in the opening corners and mess up my electrical wirings. Please help. I don’t want to have to return this light bar due to this problem. Thanks
  23. Sep 12, 2019 at 9:15 AM
    #83
    Atlanta, GA
    Can you email us pictures of this problem? We can definitely get you taken care of!
    Sales@Headlightrevolution.com
  24. Sep 12, 2019 at 3:01 PM
    #84
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  25. Sep 15, 2019 at 9:57 PM
    #85
    Tundramax2016
    Tundramax2016 New Member
    Socal
    2016 Tundra Limited Crewmax
    6” Procomp stage 2 suspension lift
    My light bar came in last week, installed it but only the swipe function works when I lock/unlock my truck. I’m having trouble trying to figure out why it doesn’t function like it is supposed to. I have a 2016 Tundra Limited Crewmax with the amber DRLs. I’m also not clear whether I have the second or third generation light bar. Perhaps you can enlighten me. I would hate to spend additional money to have it installed by a shop. Please help!
  26. Sep 16, 2019 at 7:22 AM
    #86
    Atlanta, GA
    Want to shoot us an email on this with pictures of the bar itself and the wiring? We can definitely help you out on this!
  27. Sep 16, 2019 at 9:21 AM
    #87
    Tundramax2016
    Socal
    I did, last Thursday. I called and spoke to someone and they advised that I do that. I have yet to receive a response.
  28. Sep 26, 2019 at 5:24 PM
    #88
    Levinger79
    Levinger79 New Member
    Knoxville TN
    2016 White Tundra Platinum
    Im in once you fire up another group buy. Cant get myself to drop 1k on a damn light. But get it under 800.... In.
  29. Sep 26, 2019 at 5:50 PM
    #89
    Mrpgfernandez
    Pristine
    2018 Tundra Crewmax
    Hi there. I just bought my NSV bar light last week and installed it easily. I have no mechanic skills but directions on paper were easy to follow. I bought mine for $800. I called Headlight Revolutions company and really begged for a discount. Cuz they know I’ve spent a lot of money over there on my truck. Just buy it. Omg I get so many compliments about the knight rider light. I also get a lot of people who get mad at me cuz the knight rider light is very bright. And it annoys them.
  30. Sep 27, 2019 at 4:09 AM
    #90
    Tundramax2016
    Socal
    Bought mine about a month ago, installed it and it adds a new level of appreciation. This thing is sick!!
