2013 Toyota Tundra 4x4 5.7 Electrical problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Jimbob208, Nov 24, 2022.
  1. Nov 24, 2022 at 9:46 AM
    Jimbob208
    Jimbob208 [OP] New Member
    JIm
    2013 White Tundra Platinum 4x4 5.7
    Suspension lift kit, winch and front bumper
    I may have stumbled onto something, these to wires look like the broke probably from the steering wheel moving into position when the key is turned on?
  2. Nov 24, 2022 at 9:47 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just saw the tag.
    Tied up a bit today (Happy Thanksgiving) but I’ll take a look when I can later.
    you’re checking with the key fully in ignition, not just ACC, right? That first relay is ACC and the rest requires full IGN
    2mchfun and Jeff_5_7 like this.
  3. Nov 24, 2022 at 9:48 AM
    Jimbob208
    JIm
    I posted this once but I don't see it, so here it is again. I may have stumbled onto something, these 2 wire are broke maybe from the steering wheel moving into position when the key is turned on?
  4. Nov 24, 2022 at 9:49 AM
    RainMan_PNW
    Casey
    Clark County, WA
    That looks like a clean cut. But if that light green is coming from your ignition switch, that would explain the IGN relays not having power
  5. Nov 24, 2022 at 10:01 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yes as stated if that light green wire that is broken is the one from the ignition switch to the pin 43 of the fuse box that is the reason the bottom 3 relays are not closing.
    Which would explain why the top one is on the orange or beige wire but the rest are not on the light green wire
    2mchfun likes this.
  6. Nov 24, 2022 at 10:14 AM
    Jimbob208
    JIm
    It was about 17 deg out on the day that it quit working, the wire may have snapped from not having enough slack along with the cold weather, going to test it next
  7. Nov 24, 2022 at 10:23 AM
    RainMan_PNW
    Casey
    Clark County, WA
    17F shouldn’t be an issue.
    I’m not familiar with the platinum steering wheel “auto move” feature, but it shouldn’t be designed to put that wiring in harms away. Not saying it didn’t, or something at some point didn’t compromise those wires (something installed over the years?) and eventually they broke when you started it up. Where exactly are those broken wires in context of the truck, and what connector are they running to? I’m curious what the blue wire is as well.
    Jeff_5_7 and 2mchfun like this.
  8. Nov 24, 2022 at 10:47 AM
    2mchfun
    I'm guessing you are going to "stress test" the surrounding wires a bit and try to analyze exactly what is going on. Quite curious.
  9. Nov 24, 2022 at 11:00 AM
    2mchfun
    Good work gentleman! Pretty sure this is solved!
  10. Nov 24, 2022 at 11:18 AM
    Jimbob208
    JIm
    315523875_897478587905624_55431893039881_8fa19e50aa8d244f71944a4901a0b87aee53c393.jpg315530688_867765844340775_71500102947940_d83beb02017a7b9b465a403bad47b6c119f23fb9.jpg
    OMG!!! IT WORKS! I can't thank you all enough, I am so thankful for all your help especially on Thanksgiving day, you guys are quite a teem hopefully I can return the favor or help someone else in the future. I have been working on this truck relentlessly for 3 or 4 days now. My Grandson flew out to my house in Idaho from San Diego to get the dirt bike that restored for him. Our plan was to put the dirt bike in the truck and deliver it to his house in San Diego on Sat. We had already started making alternate plans when the truck failed me. I have 3 toyota's, a 98 4runner with 320k, a 206 Sequoia and my truck and I have never had had to take any of them to a mechanic to have them fixed. Again, Thank you all sooo much for spending you time to help me on Thanksgiving day, enjoy your day and I will be monitoring this Great Forum from time to time. Cheers! Jim
  11. Nov 24, 2022 at 11:20 AM
    2mchfun
    After I looked at the diagram and your harness photos it was pretty much a given. Congratulations! Happy Thanksgiving!
  12. Nov 24, 2022 at 11:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Full EWD of the Power Source system for the 2013.
    If that is your wires coming from the ignition switch, then the blue wire is your AM2 fuse to the ignition switch. This provides power to the IG2 Relay that then powers a bunch of other stuff out of the engine bay fuse block.
    Light Green is the power from the Ignition Switch to the IG No. 1, IG No. 2, and IG No. 3 relays in the cabin that power everything Jeff was referring to.
  13. Nov 24, 2022 at 11:32 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Sweet!
    What part of Idaho? I grew up in Bonners Ferry (far north end).
    2mchfun likes this.
  14. Nov 24, 2022 at 11:47 AM
    Jimbob208
    JIm
    RainMan_PNW likes this.
  15. Nov 24, 2022 at 11:48 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Nice to see it fixed, a broken wire is never easy to track down and very hard to diagnose without a lot of measuring with voltmeter ect.
    Jimbob208[OP] and 2mchfun like this.
  16. Nov 25, 2022 at 4:25 AM
    Jimbob208
    JIm
    RainMan_PNW
    Steering wheel "Auto Move" function - It did look like someone had been there replacing something in the past because the wires were tied down with nylon zip ties which did not look like something Toyota would do. Cycling the function the wires were pulled pretty tight and did not have enough slack.
    RainMan_PNW and 2mchfun like this.
  17. Nov 25, 2022 at 4:29 AM
    Jimbob208
    JIm
    Took her on a road test and everything works fine, Thanks again for everyone's help I am so grateful, I hope you all had a Great Thanksgiving!
  18. Dec 14, 2022 at 10:05 AM
    Jimbob208
    JIm
    Just got back from my 2 week trip to Cali, over 2,600 miles and no more electrical problems. Just wanted to thank you so much all for the relentless work you all did for me, special thanks to
    Jeff_5_7,
    RainMan_PNW and
    2mchfun and Tundras.com for such an awesome forum.
    Merry Christmas to all!
    RainMan_PNW, Jeff_5_7 and 2mchfun like this.
