2013 Corolla rattle
Discussion in 'Other Toyota Vehicles' started by Outbound, May 20, 2020.
  1. May 20, 2020 at 2:34 PM
    Outbound
    Outbound [OP] SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    The Woman's car seems to have developed a metallic rattle when it's betwen 1800 - 2000rpm. It almost sounds like a loose heat shield or something. I'm not able to get under the car for a little while, but does anyone have any ideas what else it could be if I don't find anything loose?
  2. May 20, 2020 at 2:37 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    On pavement???
  3. May 20, 2020 at 5:16 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah. Mainly when slowing down at a stop light or crawling forward in a drive thru.
  4. May 20, 2020 at 7:13 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Kinda of sounds like a rusted heat shield...like you said. I had a Honda with very similar symptoms that had a rotted shield.
  5. May 20, 2020 at 7:22 PM
    owb2gp
    owb2gp New Member
    ID
    Had that same noise with my work vehicle. Was a damn tumble week stuck up next to the heat shield.
  6. May 20, 2020 at 7:31 PM
    Outbound
    Aaron
    Northern Alberta
    Good stuff, thanks guys. I've gotta get my hands on a set of ramps to get the car in the air. Reason #73 why cars suck: you can never easily access the underside.
    BlackSheep likes this.
  7. May 20, 2020 at 7:31 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Hopefully its not top end noise :fingerscrossed:
  8. May 20, 2020 at 7:34 PM
    Outbound
    Aaron
    Northern Alberta
    God I hope not. It sounds more central, either under the dash or right under the seating.
  9. May 20, 2020 at 7:37 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Oh Good, let's hope its some sacrificial shield or hangar somewhere that worked loose.
  10. May 20, 2020 at 7:40 PM
    Outbound
    Aaron
    Northern Alberta
    That's what I'm hoping. The car is a 2013, but only has about 42,000 miles on it.
  11. May 20, 2020 at 7:42 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Dayummmm
    Short commute, eh?
  12. May 20, 2020 at 7:47 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah. Our city is roughly 10 miles east-west, about 7 miles north-south. I can get almost anywhere in under 15 minutes. LOL. We bought the car with around 26,000 miles on it 2 years ago. Not sure what the previous owner did, but we pretty much just use it to run errands and make a 650 mile round trip to the big city a couple times a year for the most part.
  13. May 20, 2020 at 7:48 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Damn, and here I burned through my entire ToyotaCare in a year's time. :anonymous:
    Outbound[QUOTED][OP] likes this.
  14. May 20, 2020 at 7:49 PM
    Outbound
    Aaron
    Northern Alberta
    My 2005 Tundra has under 115,000 miles on it...
  15. May 20, 2020 at 7:51 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    :eek: I'm on track to outpace you by 250k miles in that amount of time.
  16. May 20, 2020 at 7:53 PM
    Outbound
    Aaron
    Northern Alberta
    Would you believe I paid $15K Canuckistani Pesos for each vehicle? The Tundra 3.5 years ago, the Corolla 2 years ago. :D
  17. May 20, 2020 at 7:54 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Damn dude! Thats not even two bald eagle's worth here in Freedomland.
  18. May 27, 2020 at 12:01 PM
    Outbound
    Aaron
    Northern Alberta
    Quick update to this. I got the car jacked up today and I think I fixed the issue. The thin sheet metal heat shield that is above the exhaust appears to have been the culprit. I'm guessing a rock kicked up and bent the shield just enough that when the hanging exhaust vibrated, it contacted the heat shield causing the rattle. I bent the heat shield farther out away from the exhaust and the noise has disappeared.
    Cpl_Punishment and owb2gp like this.
