2012 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by william.schwan, Jul 22, 2022.
  1. Jul 22, 2022 at 8:32 AM
    william.schwan
    william.schwan [OP] New Member
    Bill
    Hey everyone! I was driving my 2012 Tundra yesterday when all of a sudden my dash lights started flickering and a half mile later, dead. Charged the battery, replaced the battery posts and still nothing. Thoughts? I thought maybe the alternator but battery remains charged. Help
  2. Jul 22, 2022 at 11:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Sounds like a battery going bad. Id have it load tested and checked, it may be charged but still low on volts or if bad cells, will not handle load. If it is in fact good, test your alternator output. Check those and if still an issue report back. Battery going out in a Tundra does the errors and lights thing just like that.
  3. Jul 22, 2022 at 11:47 AM
    william.schwan
    Bill
    Would symptom be the same after I put a battery charger in boost, but nothing happened, no power at all. Puzzling
  4. Jul 23, 2022 at 7:35 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Did you check the cables to make sure they are securely attached. My positive had come loose once and it did the same thing.
  5. Jul 23, 2022 at 7:38 PM
    william.schwan
    Bill
    I replaced the negative and cleaned up the positive, but no resolve
  6. Jul 23, 2022 at 7:39 PM
    If that's the original battery I would say there are some dead/weak cells. Try a new battery first.
  7. Jul 23, 2022 at 7:40 PM
    william.schwan
    Bill
    I think I asked earlier that if I put the charger in boost, wouldn’t I see some power at least chimes etc?
  8. Jul 24, 2022 at 5:10 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Not on the Tundra (yet), but I have definitely experienced batteries so bad they will not function even with 12v applied to them. I assume some kind of internal short.
    I hope that answers your question.
  9. Jul 24, 2022 at 5:11 AM
    william.schwan
    Bill
  10. Jul 24, 2022 at 5:33 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    If that battery is ten years old I'd say that someone got their monies worth! That'd be pretty good going if it's the second battery.
