2012 Tundra vibration
Discussion in '2nd Gen Tundras (2007-2013)' started by Bratch, Apr 12, 2018.
  1. Apr 12, 2018 at 8:24 AM
    Bratch
    Bratch [OP] New Member
    Jimmy
    Have a strange vibration @ 50 MPH:
    2012 Tundra, 4WD, vibration begins in mid 40 (mph) range, peaks @ 50-55, goes away and then reappears @ higher speeds.
    Tires were recently replaced: no change.
    Feels like a driveshaft, but it has never been damaged.
    No noise associated with anomaly.
    Thoughts/suggestions?
    Thanks.
  2. Apr 12, 2018 at 8:27 AM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    Aftermarket wheels by chance?
  3. Apr 12, 2018 at 8:28 AM
    Bratch
    Jimmy
    Nope. all stock.
  4. Apr 12, 2018 at 8:30 AM
    Bratch
    Jimmy
    Additional info: If I shift into Neutral when vibration occurs it appears to go away: leading me to believe there is a relationship with drivetrain (hence my thoughts on driveshaft). I did have the driveshaft balanced, but it was actually worse thereafter...
  5. Apr 12, 2018 at 8:38 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    check carrier bearing first. could be some play causing vibes.
  6. Sep 7, 2018 at 4:40 PM
    Bratch
    Jimmy
    OK, this issue was caused by the driveshaft shop installing an extra bushing for the U-joint.
    Caused the excessive vibration.
  7. Sep 7, 2018 at 4:41 PM
    Bratch
    Jimmy
    Thanks everyone for your input and suggestions.
