2012 Tundra USB Port Upgrade
Discussion in 'Audio & Video' started by JMcDoodle, Feb 8, 2021.
  1. Feb 8, 2021 at 8:32 AM
    JMcDoodle
    JMcDoodle [OP] New Member
    Jeff
    I'm looking to upgrading my original USB ports to new 2.1A ports and also putting an additional USB port to the left side of my steering wheel. Has anybody installed a USB similar to the one linked below? It has a factory harness clip, but I'm unsure if the 2012 is pre-wired to accept that on the left side. Any help/advise is much appreciated.
    https://www.amazon.com/gp/product/B01CTOKI06/ref=ox_sc_act_title_1?smid=AXLVUUCJK6134&psc=1
  2. Feb 8, 2021 at 9:22 AM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    personally, im not a fan of the built in usbs. the tech has always and will always continue to progress, and no matter what charging rate you get now, in a few years they wont be ideal. even now, quick charge 3.0 devices are wanting 3.0a,a nd the 4.0 standard is already in the pipelines.. and PD devices want 4 or 5 amps. granted, you can still charge at a slower speed, but if you want max charge, the best way to go IMO is a plug in your cig lighter.
    but, if i was going the route you are, i would at least look at something compatible with either PD or QC 3.0. otherwise you're already going to be using old tech.
    just my .02.
  3. Feb 8, 2021 at 10:35 AM
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    I used one that looks almost identical to that one but has one port that is a passthrough data port that goes to my aftermarket head unit. I'm unsure what you mean by prewired, but most of the USB charge ports that you add you have to tap into wires, and I have never found one that is plug and play if that is what you are looking for. I installed mine in the center of the dash and taped it into the cigarette lighter circuit to power the charge port.
    For a different $0.02, while all the quick charge technology is convenient for the fastest charging possible, I have heard there are a lot of downsides to charging your devices at a high current and that batteries will last longer if you charge them consistently at lower amps. One thing that I don't like about the ports is the obnoxiously bright lights that come on every time I turn on the truck now but that is pretty minor.
    https://www.amazon.com/Charger-Char...through+audio+usb+port&qid=1612809002&sr=8-35
  4. Feb 8, 2021 at 10:50 AM
    JMcDoodle
    Jeff
    Thank you both for your perspective. When I mentioned pre-wire I meant Plug-and-Play. I'm not a big fan of tapping into factory wires if I don't have to, but in this case it seems that may be the only way to add a USB to the drivers side. My goal is to have my phone/GPS on the left of my wheel without having to stretch a cable from the center counsel. I think wiring a 3.0a may be the best bet for today's technology, but your right idiggplants, that tech will soon be replaced with something else. It will at least solve the wire hanging over the wheel issue I'm having.
    [​IMG] Thanks!
    APalmTree likes this.
  5. Feb 8, 2021 at 10:56 AM
    idiggplants
    PA
    2013 DC 4wd
    thats actually why i prefer to use a cig plug for charging. i have one that has a qc charger, and a slow speed charger. i typically charge using the slow charger, but if i need to get as much charge into my phone as i can, i go with the QC. (some phones allow a toggle between qc and normal charge as well.) and while slow charging is better for the battery, the far greater impact is how you use/drain your phone.
    APalmTree[QUOTED] likes this.
  6. Feb 8, 2021 at 10:59 AM
    idiggplants
    PA
    2013 DC 4wd
    for something like this, if you are really against tapping into wires, you can either run a pair of wires direct to the battery, or you can buy a socket that plugs into the fuse panel that will pull power from one of the fuse locations. aka, one that is powered only when the truck is on.
    but imo its very straight forward pulling + and - from any of the 12v outlets. just use some decent crimp connectors and youll be fine.
    JMcDoodle[QUOTED][OP] likes this.
  7. Feb 9, 2021 at 11:07 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I installed this:
    https://www.amazon.com/gp/product/B07L9QST54/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    and this:
    https://www.amazon.com/gp/product/B07FD2Z6GF/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Cut off both OEM connectors to the 12V outlets in the dash and crimped on terminal lugs to connect the USB plugs.
  8. Feb 9, 2021 at 11:21 AM
    BlueCrushSC16
    Charleston, SC
    Installed.
    qqtip2 likes this.
  9. Feb 9, 2021 at 1:26 PM
    JMcDoodle
    Jeff
  10. Mar 9, 2021 at 5:55 PM
    qqtip2
    qqtip2 New Member
    Fort Worth TEXAS- Ketchikan Alaska
    2013 White Tundra Crew-Max 5.7L 4X4 Off Road Package
    I have the same PX6 Fast boot. did you get Russian software for it yet?
    How did you connect your USB charger?
  11. Mar 9, 2021 at 6:11 PM
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    I just installed that exact port a few days ago. You will have to tap into some wires. I had some Posi Taps laying around so I just used those. Or, like @idiggplants said, run to a battery or fuse set up. I couldn't tell you how charging is though lol. I use mine for a usb plug light. I thought the missus might use it to charge, but she prefers the cig lighter. I did the DIY center console/armrest wireless charger mod. My phone stays in that compartment because it fits perfectly and I try to avoid my phone while I drive.
  12. Mar 14, 2021 at 2:55 PM
    CamTundra
    CamTundra New Member
    Camilo
    2008 Tundra SR5
    The lights are a real issue, first I bought it I thought they were cool, but after a while, it is a little annoying for sure (obviously on a night trip), by the way I could stop looking at your radio, I noticed you have a 2007 SR5, I have and 2008 SR5 lower trim with no NAV or JBL, I wonder how did you get the info system to display on the radio, was is easy? @BlueCrushSC16
  13. Mar 14, 2021 at 6:47 PM
    BlueCrushSC16
    Charleston, SC
    I have the Phoenix Automotive PX6 Tesla style radio with Sergey's custom firmware. That's how I got it done. It was fairly easy, but I have been dealing with, electricity, electronics, and software throughout my career.
    The LED usb doesn't bother me at night because the light is blocked from the bottom of the radio.
  14. Mar 14, 2021 at 6:53 PM
    BlueCrushSC16
    Charleston, SC
    Yes, I have Sergey's firmware. As far as the USB chargers, I cut off the OEM plugs that went to the OEM 12V outlets and soldered on new ones for th USB plugs I chose.
  15. Mar 15, 2021 at 9:43 AM
    roughneck421
    roughneck421 New Member
    2012 4wd Crewmax
    basic/regular
    For the guys with the PX6, can you get actual Android Auto/Carplay on those head units or just the phone mirroring (which I do not like)?
  16. Mar 15, 2021 at 10:00 AM
    BlueCrushSC16
    Charleston, SC
    You can buy a dongle(s) to get Android/ Apple carplay.
  17. Mar 15, 2021 at 10:29 AM
    roughneck421
    2012 4wd Crewmax
    basic/regular
    I'm going to buy one of those dongles and use it on my older android 7.1 deck, if it works well then I will get the PX6.
    Did you buy yours through Phoenix or somewhere else and any pros/cons I should know?
  18. Mar 15, 2021 at 11:31 AM
    BlueCrushSC16
    Charleston, SC
    I don't use any version of carplay. I bluetooth my phone to the PX6 unit and I have a Hum x module from Verizon wireless ($15/ month) to give me WIFI to the PX6 itself which has all the apps my other android devices have.
