2012 Tundra question from a new guy
Discussion in '2nd Gen Tundras (2007-2013)' started by McTundra12, Feb 22, 2016.
  1. Feb 22, 2016 at 7:08 PM
    McTundra12
    McTundra12 [OP] New Member
    '12 CrewMax TRD
    Notta
    Help me understand my 2012 Tundras drivers multi-information system. I am a new Toyota guy coming from the lands of Silverado, so the ingnorance is hopefully excusable. I bought a 2012 SR5 TRD Crew Max last week and I am getting more frustrated trying to use the info/ setup/reset buttons on my dash. Apparently this truck does not have the multi-informational display but has the buttons but parking sonar does work. What options do I have? Install a factory LCD NAV unit?
    This has not been a very enjoyable experience jumping over the the Yota, back up camera shows a blue screen and cuts out and a beat shield fell off on the way home from the dealer. Thanks for any help.
  2. Feb 22, 2016 at 7:23 PM
    Meaning the info button doesn't change what's on display? Wonder if it was added, but never connected?
    Oh, and welcome!
  3. Feb 22, 2016 at 7:26 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    A friend of mine just had a rear veiw camera problem (intermittent blue screen when put in reverse) diagnosed on his 2011. Dealer said there was an interference problem with the wiring. His issue was covered under warranty.
    I have a 3rd gen so I don't know what your info system is like. If you don't get a quick answer on here, I would check out the manual if you have it.
    Seems like you are off to a rough start, you will love her though! Have that dealer replace the heat shield, that's a bad first impression you are getting.
  4. Feb 23, 2016 at 3:26 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    This truck doesn't even have a display as far as I can tell. In the cluster there is only a small display for the odometer and the dash only displays the time/temp and sonar. The manual doesn't help me that much other than it gave examples of the multi-display cluster and the one without. I think I will stop by a Toyota dealer and see if they can help sort through everything with me.
  5. Feb 23, 2016 at 5:33 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Is this the buttons you are talking about?
  6. Feb 23, 2016 at 5:35 AM
    csuviper
    Broomfield, CO
    If so all that does is change the temp display up by the clock on the center top of your dash between temp, average mph, instantaneous mph, miles to empty and blank.
    TheBeast and MotoTundra like this.
  7. Feb 23, 2016 at 6:11 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    Those are the buttons, with the addition of the sonar button. Pressing the top three buttons does not change the display on the dash like I assume it should. They are connected behind the buttons.
  8. Feb 24, 2016 at 4:44 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    Well, the new girl is at a Chevy dealership now getting my problems diagnosed and repaired. I sold my Silverado to get away from Chevy and it turned out I bought a Yota from a Chevy dealer. Hopefully they can get everything sorted out.
    I saw on YouTube where a guys Tundra was displaying the information my previous posts referred to up on the dash where the time/temp is located. Is that where the fuel mileage etc should be displayed if my truck doesn't have the display under the speedo?
  9. Feb 24, 2016 at 5:28 AM
    Delmarva
    Delmarva Former Mayor
    Tucson, AZ
    12 TRD RW
    Yes I believe so... if I've read that correctly.
  10. Feb 24, 2016 at 9:46 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I keep that stuff off, It depresses me when I see the avg MPG, I do not watch it!
  11. Feb 24, 2016 at 10:10 AM
    Delmarva
    Tucson, AZ
    12 TRD RW
    :laugh:
  12. Feb 25, 2016 at 4:23 AM
    vulcanguy
    vulcanguy New Member
    2011 Black Limited Luccese TRD
    To Come
    on My 2011 the lcd for mileage avg mileage trip meters etc. is controlled by those buttons but appears in the center of the inst. cluster ! Mine does also have Sonar option like Yours .
  13. Dec 30, 2017 at 10:20 AM
    Gtfour43
    Gtfour43 New Member
    Oahu
    If my SR5 doesn't have the info button can it be added? Are all trucks pre wired already? Right now I only have the setup button. TIA
  14. Dec 30, 2017 at 10:59 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    I think you can add the button but you will need to add the correct wiring and harnesses also. There are a few YouTube videos showing this, it requires removing you dash so you can get to the back of the display.
    Correct me if I’m wrong.
