2012 Tundra Low Range t-case timing?
Discussion in '2nd Gen Tundras (2007-2013)' started by RyPox, Jan 14, 2020.
  1. Jan 14, 2020 at 4:39 PM
    RyPox
    RyPox [OP] New Member
    Riley
    Ive read multiple threads of the timing for this thing and im sure ive tried them all is there anyone here that has had any luck as for a good way to put them on? Ive tried pulling the lower motor letting it sit there and shift it from 2wd to 4hi and then back to 4lo letting the motor move how it wants and then putting it back in, but the 4lo light still sits there and flashes. The 4lo motor will also sit there and pulsate like its bound or its trying to shift even farther than it can. Even at that point I have taken the motor off tried moving it a tooth back on the shaft and same result up to even 5 teeth on the shaft.
  2. Jan 16, 2020 at 10:15 AM
    RyPox
    Riley
    Never mind I figured her out
