2012 Tundra loss of oil after oil change - possible engine damage?
Discussion in 'New Member Introductions' started by BigBH, Jul 18, 2016.
  1. Jul 18, 2016 at 9:15 AM
    BigBH
    BigBH [OP] New Member
    I own a 2012 Tundra Crewmax with a 5.7. I have 120,000 miles on it. I recently had my oil changed at a place that I have been using for a while. I have had good results with this place, and had no reason to doubt the quality of work. It was at the end of the day on a Friday, and I know they rushed it out of the door. When I got about 10 minutes down the road, I heard a tapping sound in my engine and noticed that the oil gauge was showing the level was a little low. I pulled over as soon as I saw this and had it towed back to the facility. I never got any light or indication that it was low other than hearing a tapping and seeing the oil level gauge low. The O-ring on the filter had been cut during install, therefore the loss of oil. My question is, should I have my engine checked by another Mechanic to make sure that no damage was done? The guy at the shop that performed this work said that there is a shut off of some sort to protect the engine from damage in a scenario like this, but I want to make sure my engine will be OK, as I plan on driving this truck for a long time. Any thoughts, feedback, suggestions would be much appreciated from this first time poster.
  2. Jul 18, 2016 at 9:28 AM
    GTABurnout
    GTABurnout New Member
    If you actually heard the engine tapping I would venture there has been damage done. If what you heard was not actual engine noise you may be ok.
  3. Jul 18, 2016 at 9:37 AM
    BigBH
    If it were you, would you have it checked out by another Mechanic? I just don't understand why I did not get any warning on the instrument cluster, etc. I would like to think that a check engine light or something would have alerted me.
  4. Jul 18, 2016 at 9:47 AM
    TheBeast The Beach
    well their mistake so have them check it for free and if you don't like the outcome, have another shop look at it
  5. Jul 18, 2016 at 10:10 AM
    GTABurnout
    It is odd that the trucks low oil pressure didn't alert you to a leak in the oil filter assembly. I say take it to the dealer.
  6. Jul 18, 2016 at 10:31 AM
    Mike Tread lightly.
    south carolina
    Check engine light is really for sensors(ECM or wiring) not oil pressure...
    Most oil pressure sensors are near or on top of the oil pump... If the pressure is low in most cases it doesn't turn on till engine damage has already happen.. I have seen this in Ford and gm engines before..
    To answer you question tho.. has damage happened.. depends on how long the engine ran with minimum oil pressure was reached and below minimum for how long before noises start.. noise tells you the oil layer is gone..
    ColoradoTJ likes this.
  7. Jul 18, 2016 at 5:12 PM
    Yep. Whats to say that shop you took it to is not going say there is no damage to avoid this.
  8. Jul 18, 2016 at 5:26 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    How much oil drained out? Metal on metal and expanding internal parts would not be good.
  9. Jul 18, 2016 at 6:31 PM
    I would totally stay away from the place that changed your oil. Totally inexcusable. Have the dealer check it out. Make oil change place pay for it. If there is any damage..........small claims court.
    trayday, T-Rex266 and ColoradoTJ like this.
