2012 tundra bed dimensions
Discussion in '2nd Gen Tundras (2007-2013)' started by andrew, Mar 23, 2014.
  1. Mar 23, 2014 at 2:48 AM
    andrew
    andrew [OP] where's the beer?
    andrew
    2012 rockwarrior
    stock
    Well, I have a 2012 tundra rock warrior, and want to know if someone happens to know the bed dimensions for a 2012 tundra rock warrior 2nd gen. It's the 6.5 ft bed I believe. I need the bed width, and length, and depth if anyone has them. unfortunately my truck is a bit away from me right now, and i wont be seeing it for a while. It'd be much appreciated!
    :cheers:
    benrichardson87 likes this.
  2. Mar 23, 2014 at 11:01 AM
    DC or CM?
  3. Mar 23, 2014 at 1:31 PM
    andrew
    andrew
    2012 rockwarrior
    stock
  4. Dec 11, 2019 at 4:59 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
  5. Dec 30, 2022 at 5:16 PM
    macdo
    macdo New Member
    2004 RCLB
    Resurrecting an ancient thread. I have a 2004 Reg Cab LB, which measures above at 96.25" long with widths at cab and tailgate being 61.5".
    Would it work to use a canopy for one of the newer trucks given the slights changes in dimension? We're talking less than 1 1/4" difference at the tailgate.
  6. Feb 23, 2024 at 2:40 AM
    PAlittlematty
    PAlittlematty New Member
    Central PA
    2021 CrewMax TRD OR
    I’m looking for a fiberglass cap for my truck. Trying to cross reference things and find what might be compatible. Looks like bed dimensions have stayed the same or very close from 2007 through 2015. So what has changed to 2021? Shape?
  7. Feb 23, 2024 at 12:58 PM
    rphass17
    rphass17 New Member
  8. Feb 23, 2024 at 1:01 PM
    rphass17
    rphass17 New Member
    Try posting or searching in here. You are probably looking to get a 14-21 body style tundra topper, the biggest difference is at the end of the bed rails and the way the back window would land on the tailgate. 07-13 Trucks have a smooth tailgate.
    https://www.tundras.com/forums/tonneau-covers-caps-and-shells.68/
