2012 Tundra 4 wheel drive problems after leveling kit
Discussion in '2nd Gen Tundras (2007-2013)' started by ALLIDOISWIN, Apr 28, 2016.
  1. Apr 28, 2016 at 8:18 PM
    ALLIDOISWIN
    ALLIDOISWIN [OP] New Member
    Tyler
    Westminster, CO
    2012 Tundra Hid's silver 2.5 in leveling kit
    I need some help.... I installed a 2.5 in leveling kit on my truck and didn't do the diff drop. I now have a popping sound coming from the front end when I select 4wd. Any body out there??? Do I just need to do the diff drop?
  2. Apr 28, 2016 at 10:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You need to try to set the cv axle bearing back correctly. You may have pulled it out when doing the lift. Figure out which side is popping and pull the stearing, sway bar, lower shock mount and lca apart and play around with the cv to get it back together correctly.
    Black Wolf likes this.
  3. Apr 29, 2016 at 5:09 AM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    Thank you for such a quick reply... So when I was doing the lift I noticed when I was putting it all back together, it wouldn't go back without me spinning the actual rotor about a quarter turn to get the angle I needed. It all seemed to have popped into place just fine... So do you think I need to do that again?
  4. Apr 29, 2016 at 6:50 AM
    csuviper
    Broomfield, CO
    That's what I'm thinking unless you have done damage to the CB joint already.
    @LOTSOFTOYS @thefatkid
  5. Apr 29, 2016 at 6:57 AM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    How would I know if it is damaged? It's not leaking or anything yet
  6. Apr 29, 2016 at 9:49 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Not sure, I'd go over eery thing bolt u touched
  7. Apr 29, 2016 at 9:55 AM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    Cool thanks guys
  8. Apr 29, 2016 at 10:00 AM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    So after all I do not need the diff drop kit?
  9. Apr 29, 2016 at 10:13 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    3" and under normally needs no diff drop.
  10. May 2, 2016 at 6:25 PM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    I pulled both sides off and made sure the were turning correctly. I noticed the passenger side was slightly hanging up. Pulled the CV out so I could adjust it and it's still doing the same thing. I don't know what to do... Anyone wanna buy this truck from me? Just kidding! Let me know if you have any other ideas. I'm thinking the passenger side CV is trashed
  11. May 2, 2016 at 6:59 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    see my post klunking sound in front end. i had the same thing on my drivers side when i did mine, i put in a after market cv drive shaft and all is good now. when i opened up the old cv boot i found that the snap ring came apart and the roller ball bearings fell out, you can rebuild the cv drive shaft, probable cause is that you over extended the drive shaft same as i did when i did my 2.5
  12. May 2, 2016 at 7:04 PM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    I didn't find the post.. I'm just going to buy a new CV for that side one of my friends told me it had to be the CV.... So glad it's not the diff! Thanks man
  13. May 2, 2016 at 7:09 PM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    Maybe these trucks are just problem children. I had a Tacoma and that thing was friggin bulletproof
  14. May 2, 2016 at 7:17 PM
    swede78
    Lars
    westminster co
    Nothing yet
    you can open up the cv boot repack the bearings install the snap ring greaser up put the boot back on with a large hose clamp or v band if you have the tools and keep for a spare, thats what im going to do
  15. May 2, 2016 at 7:25 PM
    ALLIDOISWIN
    Tyler
    Westminster, CO
    Yeah I found a new CV and it's only $60.
  16. May 2, 2016 at 9:39 PM
    csuviper
    Broomfield, CO
    I replaced my cv axles on my Tacoma from a place called "cvj axles" in denver. Reasonable price with exchange of core.
  17. May 3, 2016 at 12:39 PM
    Katoomon
    Katoomon New Member
    Great Basin
    2016 SR5 Silver Sky DC
    TRD wheels, Dicoverer AT3's, pop-lock tailgate, 6112/5100 Bilsteins, Leer shell (lock wired to tailgate), Bedrug, GPS mod,
    there are posts in other threads about the front swaybar causing noise after a lift. Not likely to have a swaybar on 4WD but do you have one?
  18. May 3, 2016 at 12:50 PM
    csuviper
    Broomfield, CO
    Sway bars are on the front on all Tundras 2WD and 4WD. Its and independent suspension thing.
