2012 to 2014 ECM software update
Discussion in 'General Tundra Discussion' started by George14, Jan 26, 2015.
  1. Jan 26, 2015 at 6:11 PM
    George14
    George14 [OP] New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    did any one receive a recall on the ECM up date
    [​IMG] 2012-2014 Tundra ECM Software Update
    Got a letter from Toyota yesterday for "Certain 2012-2014 Tundra ECM Software Update". I have a 2014 Crewmax that the VIN falls into this category. Is this the same issue as the AIP? My letter states this:
    In the subject vehicles, the Engine Control Module (ECM) may set a Diagnostic Trouble Code (DTC) if debris/ice becomes lodged in the air switching valve. If this occurs, the Malfunction Indicator (Check Engine) light could illuminate and the vehicle could enter a "Fail-Safe" Mode (also known as "Limp-Home" Mode). If this occurs the vehicle's power and speed will be reduced, which could inconvenience you and require immediate repair. The ECM calibration has been updated to reduce the possibility of this condition occurring.
    PDF is attached (thanks to @Jack Burton)
    Check your VIN here
  2. Jan 26, 2015 at 6:31 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I just got mine yesterday.
  3. Jan 26, 2015 at 6:41 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Not yet...
  4. Jan 26, 2015 at 8:33 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I havent seen one....
  5. Jan 26, 2015 at 8:47 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    What are they being recalled for?
  6. Jan 26, 2015 at 8:55 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Not yet, but I'm working away from home for a couple years. What's the deal?
    MotoTundra likes this.
  7. Jan 26, 2015 at 9:14 PM
    T-Rex266 Sushi, and Teslas Staff Member
    This. And what years?
  8. Jan 26, 2015 at 9:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Huh? Haven't heard of a recent recall.
  9. Jan 27, 2015 at 2:29 AM
    George14
    West Virginia
    None
    ECM Software update
  10. Jan 27, 2015 at 4:13 AM
    tommyboy123
    tommyboy123 New Member
    mark
    okla city
    2012 black v8 crew
    2inch front level lift Weather Tec mat front and back Plastic Dip 20 inch wheels, Magnafow 22 Exhaust.
    Got mine yesterday call today for appointment 2012 to 2014 models ECM SOFTWARE UPDATE
  11. Jan 27, 2015 at 8:24 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Got it a few days ago. I'll wait until my next service appt in a couple months and have them do it then. Here's a copy of the letter.
    Edit by @Bob: I added the attachment to the first post as well
    Bob, MotoTundra and T-Rex266 like this.
  12. Jan 27, 2015 at 8:45 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    I'm always afraid of these type of "updates"... I always assume they are making things worse. This probably isn't the case but its just how I feel. For the record I have not received anything in the mail yet.
  13. Jan 27, 2015 at 1:40 PM
    Mike Tread lightly.
    south carolina
    All this is doing is resetting the curve for the cel to come on.. Giving the ecm more room to play...
    FunkinTundra[QUOTED] likes this.
  14. Jan 27, 2015 at 3:42 PM
    FunkinTundra
    Cody
    2012 Tundra 5.7 CM
    Oh:) not quite sure what that is but sounds ok...
  15. Jan 27, 2015 at 4:32 PM
    Mike Tread lightly.
    south carolina
    I will explain alittle better..
    The ecm is programmed with a set of values for normal engine operation. Anything beyond those values is abnormal operation to the ecm flagging the check engine light or ecl to come on to say took im seeing a problem here fix me... (Example here) If the value say is 15 to 35 but the sensor is reading 37 the ecm will kick the cel on... By reprogrammed the ecm the value in the example is now 10 to 45 now the cel will not come on, and maybe keeping the engine from going into lip mode till it gets repaired.
    This is not uncommon for ecm to be reprogammed when the programmers find a problem, programmers are not perfect they are human like us. It only takes one line or one symbol wrong to screw the ecm up or glitch it..
    Take toyotas advice get the upgrade on the ecm done.. Give toyota credit they found a problem and fixed it ( cant say that for many company's)
  16. Jan 27, 2015 at 5:20 PM
    bakersTRD
    bakersTRD New Member
    Rich
    Latrobe, Pa
    2012 Barcelona Red Tundra DC 4x4
    Weather Tech floor mats, Trifecta bed cover, BedRug bedliner, factory bug shield, side steps, Rock Warrior shift knob, Pro Comp Prorunner SS leveling kit and rear shocks
    Got mine today
  17. Jan 27, 2015 at 9:44 PM
    TruckyTruck
    Gary
    Sure enough, I got a letter in the mail on this today. I agree with mike that is good they are actively updating the ecu. But.... They reflash the whole ecu. I may just stick with what I have for a while. Having a flex fuel that isn't having any of the alcohol density calculation problems, it makes me a little leery of making any changes.
  18. Jan 28, 2015 at 5:07 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Has this been on 4WD only? Are there any of my 2WD fellows getting this "love note"?
  19. Jan 28, 2015 at 5:19 PM
    Virgils12
    I don't no on the 4x2 thing. Wouldn't think that would matter.. The recall it's self is good till February 28 2016
  20. Jan 29, 2015 at 3:29 PM
    tommyboy123
    mark
    okla city
    2012 black v8 crew
    Yea got my notice goterdone next day took all of 20 minutes thanks tommyboy 2 wheel drive
  21. Feb 5, 2015 at 7:05 AM
    Jaygunner
    Jaygunner New Member
    Jay
    The update actually is for a fix for FFV (e85) trucks. ECM is flashed so that ecm properly calibrates the % of alcohol in fuel. Many FFV trucks are reading higher levels of alcohol levels than are actually there. This causes poor starting and poor performance. The reflash involves updating to 30ck0600 (TSB-0058-13). Had mine done Tuesday and the performance increase is much better.
  22. Feb 5, 2015 at 12:33 PM
    TruckyTruck
    Gary
    Why dont they come out and say that then? Did you read that somewhere or did someone tell you that?
  23. Feb 5, 2015 at 4:01 PM
    Jaygunner
    Jay
    I got same letter as most in reference to air valve. Tech updated ecm and put sticker under hood with date of 2/3/2015 and update of 30ck0600. Look it up and you will find that it's all about alcohol issues on FFV (e85) engines. Also under TSB oo58-13
  24. Feb 5, 2015 at 5:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    OEM Upgrades: TRD PRO BBS Wheels TRD S/C, Viktor G Tune and +2 psi pulley TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats
    Buuut....aren't they sending these letters out to non-FFV owners as well?
  25. Feb 6, 2015 at 7:46 AM
    Jaygunner
    Jay
    Maybe but I haven't seen anything to back that up, but I've been wrong before.
  26. Feb 6, 2015 at 9:12 AM
    Virgils12
    I got one and mine is not a ff.
  27. Feb 6, 2015 at 2:20 PM
    Jaygunner
    Jay
    Guess that makes me wrong.
  28. Feb 6, 2015 at 3:27 PM
    Mike Tread lightly.
    south carolina
    Sounds like the update is not just for one thing like air switch valve...Using that a excuse to pull in the trucks in also. ... Sounds like they had programmer error like i said in my early post...
    from a early post thats a firmware update... see if im right..
    For the guys who have had it done notice does the idle normal or high when you get it back?
    If it idles high is a firmware reprogram. If it idles normal then is a flash...
    Edit calling a mod csuviper.. if your truck is in the recall this might fix your hypertech issue you where having.. ...
  29. Feb 6, 2015 at 9:34 PM
    csuviper
    Broomfield, CO
    Thanks mike. Haven't got the letter but was thinking of scheduling to get it completed.
    Mike likes this.
  30. Feb 9, 2015 at 6:01 PM
    csuviper
    Broomfield, CO
    Mike and T-Rex266 like this.
