2012 Sequoia Platinum
Discussion in 'Sequoia Builds' started by omgboost, Mar 29, 2020.
  1. Apr 23, 2021 at 8:38 PM
    omgboost
    omgboost [OP] The Accountant
    East Coast
    farnsrocket[QUOTED] likes this.
  2. Jul 12, 2021 at 10:15 AM
    omgboost
    East Coast
    I decided to move the rear light bar outside so I don't get any light bleed in the trunk when it's on. Also less stress on the liftgate cover.
    Posted this in another thread but I'll update here as well. Just bleed my brakes today. Not sure if I got all of the old fluid out since it was super hard to tell from the color and I did not see any air bubbles come out. I used a turkey baster to squeeze out the old fluid in the reservoir and then bled about 16 ounces from all 4 brakes. Most of the 16 ounces are the rear brakes. Once I pressurized the reservoir, the brake fluid started to bleed out when I loosened the bleeder valve on the brake calipers. I would go back to the reservoir to check brake fluid level and top it off whenever I changed to do the next caliper. I didn't remove the wheels, I was able to get to all 4 wheels by crawling under the car. The front wheels were a little tight but doable.
  3. Jul 16, 2021 at 2:04 PM
    omgboost
    East Coast
    Got 4 Michelin LTX M/S2 tires installed at Costco yesterday.
    Bought the new spark plugs from Advance Auto Parts at the end of 2019 when they had a discount. Got 8 for $60. Finally went to replace spark plugs today. Not too bad. First time doing it. Was a little nervous about it but when I was actually doing it, was pretty easy. It was refreshing to work on the car without having to be on my back looking up at the underside. There were a few tight spots but nothing too difficult. Did not know when, if ever, the spark plugs were changed but was coming up to 120K miles so it was time. Looks like the rear 2 plugs had some oil when I was taking it out.
    20210716_140859 - Copy.jpg 20210716_142536 - Copy.jpg 20210716_143557 - Copy.jpg 20210716_144429 - Copy.jpg 20210716_145309 - Copy.jpg 20210716_151157 - Copy.jpg 20210716_151757 - Copy.jpg 20210716_152357 - Copy.jpg 20210716_153411 - Copy.jpg
    OhEmmBee and farnsrocket like this.
  4. Jul 18, 2021 at 5:27 AM
    farnsrocket
    farnsrocket New Member
    Good deal! I did mine on my 14' with about 112k miles. The one by the air filter sucked and I had to take the filter off and unhook some wiring harness to get to it. Most seemed OK, a couple had some oil on the threads and this one looked like a shipwreck!
    :notsure:
    S. Equoia and omgboost[OP] like this.
  5. Dec 7, 2021 at 1:00 PM
    omgboost
    East Coast
    Installed Morimoto XB headlights and turned the car into a reindeer.
